Question about Kenmore 43142 Front Load Washer
Kenmore 417-4314220 door stuck
The door is locked shut. how do i open it?
4 Suggested Answers
onthejob5130
  • 640 Answers
SOURCE: Kenmore HE3 lock latch stuck with door open
ok nice details..all you can do is replace the lock latch,,its not to costly,,change the catch while your there,,,lock part number is,,8181700 and catch part number is 8181651..it will be better just to replace it in the long run ,,,onthejob..
Posted on Jan 04, 2009
blueextc3221
  • 15935 Answers
SOURCE: washer is stuck on spin and the door wont open. It is locked.
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 11, 2010
KevinWhite
  • 1902 Answers
SOURCE: my front load kenmore washer is stuck on control
Hello & Welcome to FixYa
This is a common issue with washer however; your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the DRAIN/SPIN button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
Posted on Oct 08, 2011
The door on my kenmore front loading washing machine is open but the lock is stuck in the on position
Turn off the electric to the dryer,the lock should open,close the door and turn electric back on, make sure the lock's not obstructed
Nov 13, 2014 | Kenmore Washing Machines
Door will not open and oven will not shut off
The door latch will open after the shut down, therefore go to the home circuit breakers and shut off the power to the oven. Wait a few minutes and try to open the door. If still locked, reset the power to the on position and see if the oven rest and shut down properly and the door lock released.
Dec 31, 2013 | Kenmore Ovens
Our Kenmore Microwave Hood combo model # 401.88529011 door sticks and is very hard to open off and on
Possible that the door lock is jammed, it can also be due to jamming of the door switch or the plastic lock being stuck on.
You need to remove the front panel , and reset the door assembly.
Jan 25, 2013 | Kenmore Microwave Ovens
My front load kenmore washer is stuck on control lock when unplugged it start at 14min when plugged back in on the spin cycle and when it reaches 2min the machine shut off and the control lock flashes door...
Kevin
Oct 04, 2011 | Kenmore HE3T Washer
Kenmore 75565 gas oven door is locked. While baking, my son
Had to loosen the lock -- loose enough that the door opened. Only thing that worked. Of course then door wouldn't shut! Cut off the lock and will have to replace.
Feb 10, 2010 | Kenmore Kitchen Ranges
Door won't open
the lock switch is probably stuck. make sure machine is off but plugged in still. Push in on the door while gently giving a couple of thumps around the lock area and the lock will probably "click" open.
Aug 16, 2009 | Kenmore Elite 45986 Front Load Washer
Door will not shut
replace failed lock asm. get the german one.
Jul 04, 2009 | Kenmore Elite 45986 Front Load Washer
Door Lock Problem
with panel off reach up to lock location pull down on small tab door latch will click (at this point door would pop open if it were closed ) retry operation to see if ok if code dl reappear may to replace door lock if f11 may need new control module under top rear..ck wires first ..good luck
Sep 09, 2008 | Kenmore Elite 45986 Front Load Washer
Door lock
try crc into lock
if no good replace door lock
Nov 16, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 43142 Front Load Washer Logo
15 people viewed this question
fordexpert
Mike Squire
Robert Rankin
