Question about Neff H7871 Convection/Microwave Oven
LAMP VAN MICROWAVE OVEN KAPOT HOE VERVANGEN???
Neff H7871 800 watt Convectie / Microgolfoven Oven
MicrowaveSvc
  • 9098 Answers
SOURCE: Power Problems on NEFF H7871 Combi Microwave
It would seem there is a bad connection in the fuse holder or in the wall socket or in the microwave itself. Maybe you can narrow it down to the microwave by trying other devices in the wall socket. If it's the microwave, it's time to call for serivce.
Posted on Dec 14, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: lamp broken
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to line level (mains) voltage, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
In many over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
You should be able to find replacements lamps by taking the old one to a local home improvemeant center or department store or an applaince parts store.
Posted on Nov 25, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: neff h7871
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 06, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Neff H7871 inner glass broken
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Posted on Dec 07, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: neff microwave h7871 arcing
This antenna is called the stirrer here in the US. Its purpose is to stir the microwaves to ensure even cooking.
The cover is usually made of plastic, as opposed to ceramic, and it keeps grease and food particles off the stirrer to protect it from arcing, which can damage the surfaces and the magnetron.
The stirrer, stirrer cover and the area around it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available in appliance parts stores and hardware stores.
Also, the stirrer will arc if it is not turning when the oven is cooking. That may mean a bad stirrer motor.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron and stirrer.
You can download Neff manuals here.
Even if you don't find your exact model, they should all have contact info for Neff in case you need to call them to get spares / parts.
Posted on Dec 15, 2008
Hot air function not working
If it's not addressed in your owner's manual, you will need to take the cover off the oven to find and replace it.
The owner's manual will also give you contact information for your manufacturer so you can contact them to find local or nearby parts distributors.
Dec 20, 2011 | Neff B7740N0GB Microwave Oven
My neff h5430nogb 900 watt oven is not heating. it makes all the right sounds and the timer comes on but it doesn't heat? can you help
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 24, 2011 | Neff H5430 Convection Microwave Oven
I can not find a model number on my microwave but I know it is 800 watts/convection. Can you please tell me how to change the light bulb - I have removed the glass covering but cannot see how to access...
I would browse the manufacturers web site until you find your mode.
The bulbs are normally accessed from either an inspection cover in close proximity to the lamp or by removing the outer cover.
Hope that helps
Dec 23, 2010 | Neff H7871 Convection/Microwave Oven
Does not turn the plate inside the microwave mw 5649 neff but still heating
Basic
heatman101
Nov 09, 2010 | Neff H5430 Convection Microwave Oven
Why does my microwave oven keep cutting out and clock needs resetting before it can be used again
Check the screws in the mains plug and the wall socket. If there is no problem there, check the fuse holder in the microwave itself for bad contacts.
Hope this helps.
Nov 04, 2010 | Neff H7881N2GB 800 Watts Convection /...
Neff 5470 used for 20 min then just cut out
Take it back to where you bought it from and get a new one!
May 19, 2009 | Neff H5470NOGB 900 Watts Microwave Oven
Oven Glass replacement HTHB84K
You can find their support and spares links via their Belgian site or British site.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 22, 2008 | Neff B7740N0GB Microwave Oven
NEFF 7871 electrical problems
neff built in microwave cannot open the door
Mar 02, 2008 | Neff H7871 Convection/Microwave Oven
Interior light gone out
There is usually a little window inside that might remove with screws, or even snap in. That should allow access to the lamp. Check the manufactures website under product support for more info.
Jun 24, 2007 | Neff H7871N2GB Convection / Microwave Oven
Neff H7871 Convection/Microwave Oven Logo
621 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
