945-GC1-M3 Rev3.1 15-K76-013103 motherboard make
I need wiring diagram for PWR switch and PWR Led
  • 56 Answers
SOURCE: Connection Diagram for MSI N1996 motherboard
GOTO MANICATURE WEB SITE TECHN SUPPORT MOTHERBOARD LAYOUT DIAGRAMS
TRY MOTHERBOARD.ORG
IM PRETTY SURE THAT MSI DOES HAVE A WEB SITE ON THE INTERNET
CANDYMANGANDY
Posted on Jan 27, 2009
joecoolvette
  • 5660 Answers
SOURCE: i have an 945gzt-m v 1.0 and dont know were the pwr sw wire goes
Yes.
First, let's orient the view of the motherboard, so we are both looking at it the same way.
The processor is at the top middle, and the Front panel header, is to the very bottom right hand corner.
Right next to the motherboard mounting hole.
The Front Panel header goes across the bottom edge of the motherboard, lengthwise.
Looking at the top row of pins on the Front Panel header, No.2 Pin is at the far left. Pins 2, 4, 6, 8 and 10, go across the top.
Looking at the bottom row, No. 1 Pin is at the far left. Pins 1, 3, 5, 7, and 9, go across the bottom.
The power switch wires go to Pins 6 and 8.
The HDD LED wires go to Pins 1 and 3.
The power LED wires go to Pins 2 and 4.
On the power switch wires, the Positive (+) wire goes to Pin 6. Just in case this wire is marked.
(Doesn't really matter which way it goes, because it's a switch!)
On the HDD LED wires, the Positive (+) wires goes to Pin 1.
On the power LED wires, the Positive (+) wire goes to Pin 6.
Posted on Apr 15, 2009
nivlek_821
  • 60 Answers
SOURCE: I have a Emachines w2888 my PWR S/W ,PWR led &
http://img406.imageshack.us/img406/8789/56743980.jpg
try to search here...P and Q port if theres an indicator for the s/w and leds....
Posted on Nov 07, 2009
  • 113 Answers
SOURCE: desperately need specs.& a diagram for hdd
What is the part number of your motherboard?
Look on the motherboard for a part number. Usually it is a combination of letters and numbers.
Common motherboards are Gigabyte, MSI, ASUS, Asrock, etc
Type that part number you found on your board into Google. You should be looking for a weblink that points to the manufactures website. eg www.gigabyte.com
If you wish, write down the part number of the board and then go to the manufacturers website eg www.asus.com and then type in your part number.
You will be looking for the motherboard manual once you locate the motherboard on the website. If you do have the manual it is usually shown where the computer case leads go in that manual.
One another note, often with a magnifying glass you can work out what leads go onto what pins on the motherboard pin assembly. for eg the speaker connections are usually marked SPKR (or something similar) and the adjacent pins will be for the RESET, LED, POWER etc etc
Good luck, ask for more help if you need it.
Cheers,
Steve
Posted on Apr 14, 2010
  • 33 Answers
SOURCE: Problem with the MSI 7050
Sorry, I can't find a color diagram. But check page 2 of the HP support manual, this shows all the jumpers and board connectors. You can download the manual from the link below:
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00358730/c00358730.pdf
Posted on May 20, 2011
Problem with the MSI 7050 v2.0 (HP dx5150) Motherboard Front panel wiring colour diagram please.... PWR LED, HDD LED, PWR SW, AND RST SW
You should read manual of the moterboard, there is wiring diagram that you need. But however, i suggest to you - take it to the expert, if you don't know how to do it.
May 20, 2011 | Intel Motherboard
I need the wiring diagram for power,reset,lights
there is no need for the wiring diagram
if you check *********** board properly
you could find written in small font like
PWR SW for power switch
RST SW for rese switch
HDD LED , PWR LED etc
May 05, 2010 | Wintergreen Lindows Webstation (M810L11L)...
Where do i put the hdd pwr, led pwr and the power swich on the motherboard
you have to consult the motherboards manual and look under "wiring-diagrams", if its a used motherboard there should be a product number on the motherboard itself and you could search on the net through another computer for the pdf.manual or "tech-specs" of that paticular motherboard, the manufacturers website should have all that info
Oct 10, 2009 | E-Machines W4885 PC Desktop
Optimized intel server board 2000 Need Diagram for
On most motherboards the front panel connections are printed in the connectors on the motherboard. When you connect the various LED indicators and when you power up and they do not light up then just switch the connectors around, because they are are polarized.
You can go to the motherboard WEB site to download a manual, the manufacturer and model number is printed on the motherboard.
Jun 28, 2009 | Intel Computers & Internet
Need Diagram for the pwr,reset,pwr led,hdd led speaker connections on the motherboard. Model p5s 800-vm.
Hi there.
On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW.
Have a look at these pictures for an idea >>>>>>
Please post back with the results and any more advice if needed.
Good luck and thanks for using FixYa!!
May 27, 2009 | ASUS Computers & Internet
I have an 945gzt-m v 1.0 and dont know were the pwr sw wire goes
Yes.
Apr 15, 2009 | ECS 945GZT-M (V1.0) Motherboard
Emachines t3830 I need the schematic for MB I umployed the wire for the push bottom without looking at the way they were plug. Now I do not know the correct aligning of the push bottom wires.
If you look at the motherboard there is usually a diagram labeled "FRONT PANEL HDR" that will tell you which pins are for: HDD LED, PWR LED, RESET, PWR ON. etc.
The chart / diagram may be a few inches away from front panel header.
the following example is from my emachine T2893 that I had opened because it won't power up.
the motherboard at the header connector labels pin #2 and with that you can figure out the other
pin numbers
example of diagram on motherboard (Confirm the pin numbers on your motherboard)
J9G1 PINS
| HD LED | 1 - 3 |
| PWR LED | 2 - 4 |
| RESET | 5 - 7 |
| PWR ON | 6 - 8 |
Hope this helps you figure which pins to hook you switch up to.
Jan 18, 2009 | E-Machines eMachines T3830 PC Desktop
Emachines t2865 power led diagram
The header connections that you are looking for are on the edge of the motherboard near the battery. Look for a group of gold contacts sticking straight up at you. The silkscreen tells you which header are for what light or switch. You will see one that says "PWR LED". Another says "PWR SW" Another says "HDD LED". They are printed very small. You will see others in that vicinity that say "SAST1" and "SPKR". Ignore them.Look along the edge where the battery is mounted some are located around the nearby corner but still along the edge. All should be on the edge nearst the front of your machine. Others may be along the edge facing the bottom of your machine.
Jul 28, 2008 | E-Machines eMachines Desktop PC
Wire connections/installation
the +/- wires don;t really mater ! but as a general rule, the writing on the cable connectors should be facing you !
i don;t realy understand what u don;t understand, it-s easy, u guide u're self from the diagram on the motherboard (the one u tried to draw) (in the first raw on the left u put the power led cable, under it the reset cable .....)
there is no problem if u get them wrong, u can't damage anyting, so u can try until u get them right
Jan 20, 2008 | Soyo SY-K7V Dragon Motherboard
Computers & Internet Logo
133 people viewed this question
David Payne
David Payne
