Question about Nokia N Cell Phones
Nokia memory card not present usb connection may not work as expected
Hi i have nokia c5-03.there is no memory card present in my phone.but when i connect my phone to pc through cable the erroe comes in there (memory card not present usb connection may not work as expected) anyone know what's the reason is this... plz help!
mortega
  • 43 Answers
SOURCE: N95 8GB.Problem in connecting the phone through USB cable
I suspect the message you're receiving is:
"Unable to Activate Data Transfer Mode. Mass memory is in use by another application."
It's likely that several applications are running in the background of your phone. I believe the N95 runs on the Symbion OS. I'm not sure how to walk you through pulling up a task manager application to manually close the running applications, but the simple answer to this problems is for you to turn your phone completely off and turn it back on again. This should close all the applications that were running in the backgound.
Hope this helps.
MO
Posted on Jul 13, 2008
SOURCE: unlock 1 GB micro sd memory card of Kingston Made
I hav a kingston 1gb micro sd card i have forgotten password.plz. help how to unlock the card?
Posted on Aug 12, 2008
my memory card is locked .i use a nokia 3110c model. please give me the solution
Posted on Oct 31, 2008
EASY
Posted on May 12, 2009
anandg27
  • 1272 Answers
SOURCE: i have nokia xpress music 5130 and it gives me
I myself own this awesome music phone.
Find the answers below:
1) As it shows less internal memory, it seems that you have transfered some data like mp3, video clips through bluetooth to this phone and it was saved in the recieved folder which autmatically saves in phone memory. Try saving the data to memory card and you will get the phone memory free.
2) Check the above reason for this same issue.
3) You need to select proper connectivity mode under settings of this phone. Go to settings and then open connectivity folder. Here select the connection mode.
Make sure to install the latest PC suite software on the computer. This can be downloaded from the NOKIA website.
Regards
Anand
Rate it, if it helps.
Posted on Jun 23, 2009
How to restore my full nokia 5130c-2 30mb internal memory?
To solve this problem, follow step
1-download this original backup 2-store the backup file in memory card using Nokia Pc suite after connecting your phone by usb cable.
3-Select Menu > Settings > Sync and backup and then Restore backup
4-Select the backup file already stored on the memory card and restore it to the phone.
Hope problem is solved.
http://www.techyv.com/questions/nokia-5130-xpressmusic-internal-memory-problem
Dec 22, 2011 | Nokia 5130 XpressMusic Red Unlocked Import...
My mobile is nokia s40 series name is nokia 5130c-2 in my mobile i have 2gb memory card before 3 to 4 months i have entered a password in order to protect my memory card but at present i hav forgot it. i...
Im afraid you'll have to format your memory card plugging it into a computer unless you can still access it through your phone and backup your data first.
Mar 18, 2011 | SanDisk 2GB microSD Memory Card
My memory card is not being connected to pc using memory card reader???? my phone is nokia N 72... my phone is not working so basically i want to know how should i get the data from my memory card..
Use Nokia PC Suite, not only get data from your phone memory card, you can also install application and games or back up your contacts by this software.
- First download the software from here :
http://www.softpedia.com/get/Mobile-Phone-Tools/Nokia/Nokia-PC-Suite.shtml
- Install the software
- Open PC Suite and click connect any device
- Connect your phone via USB cable or bluetooth
- if its connected, you'll see your phone folder in Windows Explorer
- Copy your data from or to your phone/PC
If you feel this answer helpful RATE please. Thanks for using Fixya
Jan 29, 2011 | Nokia N72 Cellular Phone
How to reformat Nokia 5220 Xpress Music?
sometimes will cannot format your memory card,if any of the files present in your memory card is opened by your phone and in use. Also be aware of the fact that if you format your memory card, not only the data present in it will be wiped out but also the mobile softwares/applications installed onto your memory card.
If you couldn't format from your mobile, remove it, put it into a suitable adator, insert into the memory card reader, connect to your PC and format it. Simple...
I hope this is helpful to you.thanks
Jul 24, 2010 | Nokia 5220 XpressMusic Cellular Phone
Can't format Nokia 5220 xpress music!!
Sep 16, 2009 | Nokia 5220 XpressMusic Cellular Phone
Nokia 5610 how to format the memory card with using the computer and to do it without it i tried the one that said reset factory settings but it didnt work
Hi, I guess you must be using microSD memory card. Just connect the mobile and computer using USB cable, provided alongwith mobile phone. On connecting two windows will open, one for phone memory and one for memory card. Carefully note the memory card drive (e.g. G: or H:)
Open MyComputer and right click on that memory card drive (G: or H:), drop down menu will open and select "format" and click format. In this manner,your would be able to format your memory card.
Sep 16, 2009 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
I have a Nokia 95 that came with a 1gb card. I replaced it with a 4gb card and it has always worked perfectly. I have recently bought an 8gb card and uploaded some music and photos to it. However when I...
Some phone have a limitation of memory reading capability, example the 3660 128mb of memory card works fine, but when you replaced it with 1 gig it cannot recognized it. Maybe your phone have 4gig capability only, read your manual or ask to your nearest nokia hub or dealer. Thanks
Aug 12, 2009 | Nokia N95 Cellular Phone
Memory car id not formatted as like mssage given by the cell phone nokia 3500c when i m opening memory card
hi thanks for using fixya!
Unfortunately, there is no master password for the memory card. I suggest, if your memory card is working properly to other phones, you should check your phone perhaps it is not reading the memory card. It is better to bring your phone to the Nokia Care Center to further check the error.
Regards!
May 30, 2009 | Nokia 6233 Cellular Phone
Mobile startup failed . contact the retailer
hi,
Your phone's memory card must be infected with virus or has some fault. Please remove the memory card and try to start the phone again. If it goes through, please back up the data in your memory card and format it. In most cases, this procedure solves the "Phone start up failed. Contact the retailer" error.
I'd advice you to format your phones internal memory as well, it will flush out any errors present. save your "phonebook" data somewhere and Make sure your phone's battery is fully charged if not plug the charger in and proceed. NB: interrupting this process might render your phone useless. So, be careful.
To format press *#7370# it will prompt you for security code, enter it and the phone will reboot. Your phone will be reset to "factory settings."
Jan 13, 2009 | Nokia 6600
Unlock 1 GB micro sd memory card of Kingston
HI, all you need to do is to get a usb box and good flash file, insert the memory card in th usbox then flash it.
Engineer Raphael.
Sep 06, 2008 | Nokia 6300 Cellular Phone
Cell Phones Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
