Question about Acer Computers & Internet
Aspire M1100 boot up problem
My acer M1100 will not boot up... comes up with a error = Windows could not start because of a computer disk hardware configuration problem.could not read from the selected boot disk.Please can anyone help Thanks
  • 70 Answers
Method 1
Edit the Boot.ini file to restore or correct the Default entry and to ensure that the other entries in the [Operating Systems] section of the Boot.ini file point to the appropriate directories.
Method 2
Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
1. Use the Windows XP CD-ROM to start your computer.
2. When you receive the message to press R to repair Windows by using the Recovery Console, press the R key.
3. Select the Windows installation that you want, and then type the administrator password when prompted.
4. Type bootcfg /rebuild, and then press ENTER.
5. When the Windows installation is located, the following instructions are displayed:
Add installation to boot list? (Yes/No/All)
[Type Y in response to this message.]
Enter Load Identifier:
[This is the name of the operating system. Type Windows XP Professional or Windows XP Home Edition.]
Enter OS Load options:
[Leave this field blank, and then press ENTER].
After you perform the preceding steps, restart the computer, and then select the first item on the boot menu. This should allow Windows XP to start normally.
After Windows XP has successfully loaded, the Boot.ini can be modified to remove the incorrect entry.
Method 3
1. Start the computer by using your Windows XP CD-ROM. Press any key to boot from the CD.
2. After the setup files are finished loading press R to repair using Recovery Console.
3. When you are in the recovery console, select the installation to log on to (usually number 1), and then press ENTER.
4. Login to the Administrator account by typing the password for this account, and then press ENTER.
5. At the recovery console command prompt, type the following command, and then press ENTER:
For Uni-Processor systems:
expand <cd-drive>:\i386\ntoskrnl.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
For Multi-Processor systems:
expand <cd-drive>:\i386\ntkrnlmp.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe
Note In these two commands, the <cd-drive> placeholder represents the drive letter of your CD drive, and the <hd-drive> placeholder represents the drive letter of the hard disk on which windows is installed.
6. If you receive a prompt to overwrite the file, press Y.
7. Type exit, and press ENTER at the command prompt.
Method 4
Start the computer by using the Recovery Console, and then run theCHKDSK /rcommand.
Note You do not have to include the /p switch in the Chkdsk command-line because the /r switch causes the Chkdsk utility to locate bad sectors and recover readable information. This command implies the /p switch..
Posted on Jan 11, 2009
Why do not restored disks work for Acer Aspire M1100?
Turn off the computer Henry then turn it back on and hold down the alt key and tap F10 and make sure you remove any disks from the CD drive.
It would appear that the hard drive is having boot sector issues.
http://www.ezsystemrepairs.com
Nov 08, 2012 | Acer Aspire M1100-U1402A Refurbished AMD...
Forgot password do not have reset disk to main account
Go to microsoft website and download ERD (error rescue disk) for the operating system that you are using. Then write the image to a disk using Nero or any burning software. Then boot you computer from the cd. Then you will go to the Adminstrative Tools and go to locksmith then its going to give you an option to reset your password. Then you are going to use the newly created password to login.
Dec 11, 2011 | Acer Aspire M1100-B1300A Refurbished AMD...
I have a Acer aspire desktop computer m1100 and when I bought it did not come with a recovery disk and I did not make the cd because I was unaware of how to do it. Now the computer will not boot with out a...
by default the hard drive should have a recovery partition. go to the support section of the manufactures website and you should find detailed instructions of how to boot to the partition. if that option has been corrupted, you can purchase a recovery disc directly from acer. i've ordered nearly a hundred for customers in the past and have never paid more than 20.00 for a disc or disc set.
below you will find a link that will allow you to enter your product serial number and direct you to the purchase of a factory recovery cd/dvd.
https://secure.tx.acer.com/RCDB/Main.aspx?brand=acer
Jan 21, 2011 | Acer Aspire M1100-U1402A Refurbished AMD...
Acer aspire wont start past boot screen
May be the hard drive is not detecting properly on the computer.
Try resetting BIOS.
If that doesnt help, try checking your hard drive on a different computer or using some 3rd party HDD checker.
Nov 05, 2010 | Acer Aspire M1100-U1402A Refurbished AMD...
I have an Acer Aspire M1100 Desktop. I purchased it about 2 years ago. Unfortunately it did not come with a recovery disk so that i may set the computer back to factory (out of the box) settings. I was...
Unfortunately Acer no longer has recovery media available for this model Aspire. However they still have the drivers available for download so, the easiest way to get this machine as close to it's original condition as possible is as follows;
First and formost: Make backup copies of all file, pictures, music, videos, etc. that you need to keep.
Next: Download the drivers for this system by going to www..acer.com. Once you're there, select USA and click on the Service & Support Tab and click on the driver download link.
Then, make the selections for you computer i.e.; desktop, aspire, m1100, and windows operating system.
Now download all of the drivers you need for your computer and put all of these drivers on a cd, dvd, or flashdrive for later use.
Re-install Windows and allow the installation process to re-format the hard drive during the installation.
Finally, re-install any programs and data that you have and install the drivers.
Take your time and it should all fall into place. It should all take you a good half a day or less. Good Luck!
Sep 17, 2010 | Acer Computers & Internet
My acer 1 when started up keeps going to a checking file system screen and just keeps doing a disk check
For that when you power up the computer press F8 key then enter in "Safe mode"
Then go to start menu->run
Type in run "chkdsk /r"
then press "y"
then restart computer then it fix error on harddisk.
After completion of disk checking it load windows but if still not load windows then you need recovery disk or windows disk then boot computer with it then repair old windows.
Nov 15, 2009 | Acer Aspire One PC Notebook
Laptop start up error
This error comes when there is memory issue .
Harddisk issue or RAM issue.
For that if you have windows recovery disk you need to run disk checking program
Most of this error comes becuase of hardddisk error.
Boot your computer with windows xp disk then enter in recovery console mode then type in prompt "chkdsk /r"
then press "y"
then it checks disk andf fix error if found any error on harddisk.
then you can boot your windows.
Thanks for using fixya.
Please rate my solution if it hleps.
Pls let me know if you need more assistanse.
Many Thanks .
Jul 24, 2009 | Acer Aspire 4315-2963 Notebook
BIOS doens't start
try clearing the CMOS by removing the motherboard battery for half an hour, male sure you remove the power cord from the back of the machine first
post back and let me know how you get on
kind regards
Dec 02, 2008 | Acer Aspire M1100-U1402A Refurbished AMD...
Computers & Internet Logo
436 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
