Question about Dell Inspiron 5100 Laptop
When turning on power it shuts down - Dell Inspiron 5100 Laptop
  • Dell Master
  • 2,072 Answers
If it is shutting off as opposed to restarting it is most likely a heating problem or possibly dead fan. There are fail safes in computers that will cause them to shut off if they can't detect a fan or are too hot.
Posted on Dec 02, 2012
How do i check to see what is causing my receiver to shut off
The amp protection circuit has been activated. Remove the power cord from the wall outlet immediately. Disconnect all speaker cables and input sources, and leave the AV receiver with its power cord disconnected for 1 hour. After that, reconnect the power cord and reconnect an input and a pair of speaker wires onto the unit. If the receiver still does not turn on than you will have to bring it in for service. Turn up the volume and if the receiver doesn't shut down, power off the receiver and add another pair of speakers. Power up the unit again and turn up the volume. If it doesn't shut down, power off the unit again. Now connect all your input sources and turn on your receiver. If the unit shuts down again, your unit will need to be further serviced at an authorized Onkyo service center.
Sep 25, 2014 | Onkyo Audio Players & Recorders
I have a Gateway Solo Pro 9300 laptop. Whenever I shut it down, the power light turns orange, and the backlight is still lit. Other than that, the hard drive and fans turn off. What does this mean. How can...
That means the computer is in 'Sleep' mode. To completely shut down the laptop, you can press the power button once and it will do a normal shut down.
May 08, 2011 | Computers & Internet
My lenovo T400 will not shut down even when all applications are closed. I have to manually shut it down with the power button
Hi guest, try to turn off the pc by using the power button. Then remove the cables and battery on the laptop. Then push & hold the power button for 5 seconds. Reinsert the cables and battery then turn on the pc.
Check if you will be able to shut down your pc using the operating system..
May 15, 2010 | Lenovo ThinkPad T400 PC Notebook
I shut my computer down at night, but can't get on Internet next
There is no reason to shut down either the router or modem. My router and modem has power 24/7 with no issues for many years. Just leave them powered.
Mike
Apr 24, 2010 | Computers & Internet
Monitor turns itself off
hi, you must have enabled power saving options. Thats why your monitor shut down. you can disable, just do the same:
1.Right click on desktop
2.Select properties.
3.Select "ScreenSaver".
4.Select "Power" under Monitor power option.
5.There select "never" from Turn off monitor (drop down menu).
Now your monitor will not turn off automatically.
Sep 19, 2009 | Dell Inspiron 531s Desktop Computer
E500 won't shut down
It is probably not shutting down because there is a program running that will not shut down. Unnstall programs you no longer use and do a virus scan, often the programs that refuse to shut down are malicious. Holding down the power button for 5 seconds should shut down the computer (it signals the motherboard to power down). As for the black screen, not enough detail for me to say.
Jan 02, 2009 | Compaq Armada E500 Notebook
My Philips Freevents sometimes wont turn on and when it does it shuts down without me shutting it down
If the computer shuts down with no warning then it could be your power supply is faulty, which explains it not turning on sometimes. Just check the back of the PC to make sure it is plugged in properly (TURN OFF ALL POWER TO THE PC BEFORE CHECKING). if this does not help, get it looked at by your local qualified computer technician if you don't know how to replace a power supply. Also, a connection to the motherboard to the Power button may have a fault somewhere, which also means take it in for a look if you don't know what to do. If it does give you warning with 'Windows is shutting down' it can be the following things.
1- Your power button on the PC is sticky and movement causes the computer to think you have pressed it and so it shuts down, which can also explain why it wont turn on all the time. Just use some household grease cutter and spray it on the outside of the button, turn off the power supply to th computer and press it in and out a few times to get it back to working order
2- A Virus is shutting your computer down on you, but this does not fully explain why it won't turn on but this could be an effect of the virus so use a virus checker to see if this is the case
3- Your computer system is getting too hot and usually a computer has setting which shuts it down before permanent damage happens. Check your PC fans to make sure they are running and feel around where your computer sits to see if its warm or hot and replace the fans or put your PC in a cooler environment
Hope This helps
Nov 18, 2008 | Computers & Internet
Shutting down
what is happening is it is hibernating not shutting down, open up acer empowering technology and go to the power settings or click on the battery icon in taskbar and click power options, then there will be instructions that say when i turn off; power off and not hibernate as probably selected.
Aug 29, 2008 | Acer Aspire 3690-2196 Notebook
Shuts down after power up 50ux53k bought new 1998
Refer to owners manual will tell you what blinking light means. But at the front not at the back.
Dec 16, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Dell Inspiron 5100 Laptop Logo
43 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
