Question about Goldstar Microwave Ovens
Wattage for goldstar 3850W1D041
Trying to find wattage for Microwave ,We foster kittens and we heat up disk to keep kittens warm.We need wattage for setting.
  • Guest123
    Guest123 Oct 16, 2013
    It's an 1100-Watt machine. Real model number is GMS-1120TW (or GMS-1120TB for black). The manual is available on the LG websitehttp://www.lg.com/ca_en/support .
MicrowaveSvc
  • 9098 Answers
SOURCE: Need Mount for Goldstar MV1526W microwave
You can contact LG via their world portal here: http://lgservice.com/
Posted on Nov 05, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: wattage
The output power for model MA-780 was 700 watts, so I'd bet yours is either 600 or 700 watts.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 04, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: GoldStar MH-1357M microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
Posted on Jun 23, 2008
SOURCE: Goldstar MV1501W not heating or turntable, light/display does wrk
micro switch is bad .remove top vent cover 4 screws,after removing plastic vent panel you will see 1 screw above display time window,remove this screw and lift up the complete button time control panel slightly and pull towards you to remove.there are 2 connections on this panel 1 is a 12 pin connector and a 2 pin power connection remove both put control panel aside.now there are 3 micro switches where the door pins close into the oven lock,remove 2 screws that hold the micro switch housing,on the bottom of housing you will see a small clip gently pull to the right and push back to remove .there are 2 switches on bottom of it and 1 on top. the 1 on top is normally open and closes when door is shut but like mine it stayed open and resulted in (light s display but no turntable)soon as i replaced upper microswitch it runs perfect.i hope this helps .MODEL MV1501W GOLDSTAR
Posted on Jan 01, 2009
  • 1214 Answers
SOURCE: microwave doesnt heat food
Microwave not heating problems are the result of one or more of the following problems -
1) Bad fuse
2) Bad diode
3) Bad capacitor
4) Bad transformer
5) Bad magnetron.
You would need to have special equipment to test the 2nd, 3rd, and 5th items.
Reply back of any other questions/help you may need.
Posted on Feb 03, 2009
What is the wattage for ER-4010
Most home Microwaves draw about 12-14 amps. You could figure your wattage at about 1680 watts. Calculated by factoring the voltage of most units 120V times the typical amperage draw of 12-14 amps. so wattage is volts times amps or (12-14 X 120) 1440-1680 watts
Sep 21, 2017 | Goldstar Microwave Ovens
Please I need the wattage of GoldStar microwave Model ER-868 so I can heat a heat pad for a sick animal
Wattage really doesn't matter much for what you want to use it for. Start with 2 minutes and test. If it's not hot enough add 1 more minute
Jun 09, 2016 | Goldstar Microwave Ovens
What is the wattage of a goldstar ma- 960m microwave
The Goldstar MA-960M (also 961M and 963M) is 850W, 0.9 Cu.ft. The MA-1080M (1081M and 1083M) is 850W, 1.0 Cu.ft; MA-1280M (1281M and 1283M) is 900W, 1.2 Cu.ft; MA-1523M is 900W, 1.5 Cu.ft. Source: Technical Specifications listed in original user manual for MA-960M.
Jan 31, 2014 | Goldstar MA-960M Microwave Oven
Whats the wattage on a goldstar ma 7802
look on the tag on the rear cover and take your input voltage and current and multiply them for unit wattage i.e. 120 volts X 8 amps = 960 watts
Sep 26, 2009 | Goldstar MA-7802 Microwave Oven
Do you know what the wattage is of the Goldstar MA-685M Microwave Oven? I checked the back panel and the door panel and it is not listed there.
600 watts, according to the repair manual.
Sep 27, 2008 | Goldstar MA-685M Microwave Oven
Wattage
Jan 02, 2008 | Goldstar MA-782M Microwave Oven
Microwave Ovens Logo
144 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
