Question about Boston Acoustics TVee Model Two TV Speakers
Tvee 2 sound bar started hissing. have had for several years. is it repair time or should i replace/
3 Suggested Answers
  • 6 Answers
SOURCE: need the Boston tvee sound bar repaired. Making
The sound bar system was not adequately tested before release and it's obvious. The sub seems to disconnect and reconnect randomly. This also happens when the bar is off. It makes a large bassy pop every so often when it shuts down. It's woken me up at night when it decided to turn on and off. Occasionally I have to power cycle the sub or even change the frequency in order to re-establish a wireless connection. All of this is an occasional occurrence and poses more of an annoyance than anything. It's crappy to have to say that "It works most of the time." It's too bad because the concept is fantastic, and now I question the quality of Boston Acoustics.
Posted on Feb 21, 2010
SOURCE: I have a TVee model 2 from Boston Acoustics
Hi jdmowen,
I see that you need help since you lost the hardware for setting up you TVee Model Two Speakers.
What hardware are we speaking of? check the links I have provided, one of the links will be the manual and the other links will be where you can get the parts that you might need.
Manual
Parts Boston Acoustic Website
Parts Reseller
Parts Other Resellers
I hope this will help.
send me a message if you need a specific part maybe we can get info for it.
mvincentc
Posted on Jul 04, 2011
Programming time warner remote to boston tvee volume
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process. Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com) Using Pre-Programmed 3-digit Code method -Turn on soundbar - Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit. - Point remote control toward the soundbar and enter code (447 for Boston Acoustics) - Press the device button again to store the code. The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me. Step 2: Program your remote from the Boston Soundbar. - Press the power button and the volume up button simultaneously until the indicator light flashes orange. Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming. - Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange. - While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed. - Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote. Good luck, I hope this helps. -Deidre.
Dec 05, 2012 | Boston Acoustics TVee Model 25 Sound Bar...
Volume on Boston sound bar will not go up very high
There is a internal problem with it, Take it in for repair, out put transisters are probally fried,
Dec 02, 2012 | Boston Acoustics TVee Model 20 Soundbar...
Tvee model 25
Have you checked all your wire connections? To make sure thier not loose.
Aug 05, 2012 | Boston Acoustics Tvee Model 25 Sound Bar...
Tvee 20 subwoofer has distinct hum noise. Any advise?
1.Check the input cable or change it and see the result.
2.Test the subwoofer to a computer.
May 29, 2011 | Boston Acoustics TVee Model Two TV...
All static from the sound bar. adjustments don't help. tried different cables - that didn't help. System is not usable at this time.
The manual...
http://www.retrevo.com/search?q=Boston+Acoustics+TVee+Model+Two
Page 7
Distorted sound from the Soundbar.
Change the Trim Level switch setting to a higher number.
Check the signal source to be sure the distortion is not originating there. <<<<<<<<<
The woofer seems to have interference with its wireless signal.
Try changing settings of the Wireless ID switches on both the soundbar and bass unit. <<<<<<<<
The bass unit could be too far from the soundbar to get a good signal. Try moving it closer.
What is the source device that results in static? How is it connected?
Feb 08, 2011 | Boston Acoustics TVee Model Two TV...
After pressing the power on button it starts to turn on but then makes a hissing sound and goes into standby mode. It takes several attempts before the screen wont make the hissing sound and finally stays...
You have a monitor with a failing power supply. The Viewsonic VG2021M monitor uses the DAC-12M033 power supply board. After several years of use the capacitors in the power supply start failing and not keeping a charge. The capacitors are on the output side of the power supply and help filter and stabilize the voltages. When they fail the power does not settle when you turn it on so you have to do the on/off/on/off to get it to start. If you can solder then you should be able to repair your monitor. Check out the article on our site at: http://www.ccl-la.com/blog/index.php/repairing-the-westinghouse-lcm-20v5/ it is for the Westinghouse LCM-20V5 but they both use the same board so the repair information is the same. If you don't want to do the repair yourself we do offer a repair service for this unit, it runs $32 plus shipping. You can get more information on this service here:
http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Jul 01, 2010 | ViewSonic VG2021m LCD Monitor
Starts and idles fine but has loss of power during driving and I hear a hissing sound I never heard before
A hissing sound is usually a vacuum leak in the intake system. Look for loose hoses (with the engine running) and the source of the hiss. If you find a nipple hissing, it may have lost a cap (it may be a vacuum test port) that prevents air entry.
An aside note: be sure to change the timing belt at the proper time. If it breaks while running, the engine with suffer severe valve and piston damage (many penny!)
Nov 25, 2009 | 2001 Daewoo Lanos
Need the Boston tvee sound bar repaired. Making popping and cracking noise when power is on.
Haven't fixed it yet. Going to find a electronics repair shop locally and have them repair it.
Thanks.
Apr 11, 2009 | Boston Acoustics TVee Model Two TV...
Not enough IR range to use remote
Get yourself a very thin and small screwdriver. The type that comes in the eyeglass repair kits. Remove the cloth/plastic grill from the front of the sound bar. Locate the IR sensor in the center of the bar. Pry the dark red filter off the IR sensor and leave it off.
Problem solved, greatly increases range. I have read that there is a clear replacement cover you can buy but whats the point?
Nov 15, 2008 | Boston Acoustics TVee Model Two TV...
Suround sound dvd
Get a Boston Acoustics Tvee Soundbar System.
Dec 06, 2007 | Boston Acoustics TVee Model Two TV...
Boston Acoustics TVee Model Two TV Speakers Logo
21 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
