Question about Health & Beauty
I have a yellow nomad noricar e 2 wheel scooter. It will charge just for a minute. It wont hold a charge. Not sure how old it is. Is it the battery? What could be wrong? Where is the battery located?
2 Suggested Answers
  • 21 Answers
SOURCE: Hi, fitted my scooter with two brand new 40 amp hr
What type and what voltage were the old batteries removed from the scooter?
Posted on Apr 07, 2011
Testimonial: "Thank you for the help, - the link didn't work but i'm slowly getting to understand things now."
Pride V10 ****** wont hold a charge. It runs out of power afetr 10 minutes,
hi, well how old is the V10 ? please remember a pair of batteries is only as good as the charger...
Regards
Rob
www.gewizrepairs.co.uk
Jul 10, 2014 | Pride Mobility Victory 3 Wheel Electric...
I have a golden companion II 3 wheel scooter with new batteries, the problem isafter a complete charge the scooter starts off fine but gradually loses power as indicated by meter in 5 to 10 minutes. A
hi ,there are two parts to batteries holding power and preforming well, firstly how good are the batteries, secondly how good is the charger ?, good batteries and a bad charger will make the batteries appear bad...
Regards
Rob
Feb 22, 2014 | Golden Technologies Golden CompanioN II -...
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Mar 15, 2013 | Pride New Mobility Victory XL 4 Wheel...
Battery wont charge
could be to hold not holding charge anymore.
Mar 19, 2012 | Pride Celebrity X 4-Wheel Electric Scooter...
1.)I always charge my batteries while connected to the scooter. Which is better? To charge them on or off the scooter.? Mine is a 2005 GoGo Ultra made by Pride. 2) Also my batteries do not hold a...
It makes no difference if you charge on or off board. The batteries are easy enough for your son to change just alot of screws to take out of the case. Just replace the old batteries with the new ones and if it has a heat sensor make sure that it is placed on one of the new batteries. take your old batteries to a battery store and they can recycle them for you. Hope this helps
Feb 22, 2011 | Pride Mobility Products Go Go Ultra X 3...
Wont hold a charge. Batteries checked out ok. Could it be a short? Is this common?
If the batteries have been volt tested OK and they wont hold a charge, check your charger to make sure it is functioning properly. If there was a short, the scooter most likely would not work or would give a flashing light code. Batteries typically will not hold a charge when they are damaged, have been sitting unused for a while or if there is a mechanical issue that is causing dtrain on the motors. Check the air pressure, bearings and ensure there is no noise or vibration that may indicate a motor failure. If all those check OK, replace the batteries.
Nov 04, 2010 | Pride New Mobility Victory XL 4 Wheel...
Try to use scooter, clicking sound, then moves bout 4 inches. charged batteeries all night.
How old are the batteries? When you connect the charger, if the charger indicates the batteries are charged within a few minutes and the battery power does not last more than 1-2 hours or less, it may indicate that that the batteries will not take a charge anymore and need to be replaced.
If the battery indicator on the scooter says the batteries are charged but the scooter still will not move, make sure the freewheel lever is in the drive position.
If you continue to have issues, contact your sales person or the manufacturer to schedule a service call.
Oct 19, 2010 | Sonic 3 Wheel Scooter
I just bought a new battery charger cable called (Sealed Lead-Acid Charger) to replace an older (Lead Acid battery charger). The New Battery charger will charge for about 2 to 5 minutes and then stop...
ismail the charger you bought should do the job. By stop charging do you mean the light on the charger turns from yellow to green? Your scooter has small batteries 12/12 and don't require along period of charging. Now the scooter has a heat sensor for the batteries and will cut off charging when temp of the batteries gets too high. The older charger could have overcharged your batteries and made them weaker instead of stronger. I would suggest you replace the batteries (2 12/12AH) and charge them with the new charger. Remember to reinstall the heat sensors on each battery when replacing. If you have a digital voltmeter set it to 200 v dc and put the leads into the 2 outer plugs in the charger port on the battery pack. You should read 24-26 volts dc when the batteries are fully charged anything less would mean weak batteries. Hope this helps you
Oct 03, 2010 | Pride Mobility Products Go-Go Elite...
Health & Beauty Logo
321 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
