Question about Xerox DOCUMATE 510 Flatbed Scanner
My Xerox Documate 510 adds a line from top to bottom down each scanned document. The line only appears when something is fed into the paper feeder and does not happen when scanned single sheet at a time on the flatbet.
  • Anonymous May 22, 2009
    This just saved me buying a new scannner thanks
You probably have something on the scanning bulb when it goes through the feeder. The scanning bulb is directly to the left of where you use the flatbed. Clean that glass with a dry, clean cloth and you should be back in business.
Posted on Mar 05, 2009
I get the message that says "no paper in auto
Not sure if you get this message on the machine or in the software on you PC. It could be a software setting if it's on the PC that tells it where to pull the docs from. If it's a scanner message it could be an object blocking the paper sensor telling it something is in the feeder. Check the feeder paper path for anything that does not belong there or carefully blow out the paper path with compressed air. Sometime dust collection does this.
Feb 03, 2011 | Xerox DOCUMATE 510 Flatbed Scanner
I could not find the icon for the One Touch Visioneer scanning software for my Xerox Documate 510 so I uninstalled the software and re-installed and now I can't find anything. I am completely unable to...
  • Welcome [ What's in the Box ~ The Xerox DocuMate 510 Scanner ~ What You Need ~ Documentation ]
  • Installation [ Before You Begin ~ Step 1: Assemble the Scanner ~ Step 2: Install the Software ~ Step 3: Connect the Power Supply ~ Step 4: Connect the USB Cable and Turn on the Power ~ Additional Applications Available with Your Scanner ~ View the User Guides ~ Register Your Scanner and Check for Updates ]
  • Scanning [ Loading Documents to Scan ~ Load a Stack of Documents ~ Load a Single Page ~ Scan from the One Touch Button Panel ~ Check the Scan Settings Before Scanning ~ Using the One Touch Panel ~ About the One Touch Button Panel's Names and Icons ~ The Default One Touch Settings for Your Scanner ~ Configuring the One Touch Buttons ~ About the One Touch Properties Window ~ Selecting New Settings for a Button ~ Setting Destination Application Properties ~ Selecting Document and Page Format Options ~ Scanning with Optical Character Recognition (OCR) ~ Renaming a One Touch Button ~ Selecting Options for a Button ~ Creating a New Scan Configuration ~ Editing or Deleting Scan Configurations ~ Configure Before Scan ~ Scan and Burn to a CD ~ Scanning with Event Forwarding ~ Creating an HTML Web Page from Your Scanned Documents ~ Transferring Scanned Documents to Storage ~ Checking the Hardware and Setting the Lamp Power Saving ]
  • Scanning with the TWAIN Interface from PaperPort [ Accessing the TWAIN Interface from PaperPort ~ The Two TWAIN Interface Options ~ Scanning from the TWAIN Basic Interface ~ Scanning from the TWAIN Advanced Interface ~ Adjusting the Image with the Advanced Interface ~ Adjusting the Resolution ~ Adjusting the Brightness and Contrast ~ Adjusting Gamma, Saturation, and Color Hue ~ Adjusting Input Size ~ Creating a New Advanced Interface Profile ~ Display the Device Configuration ~ Setting Up PaperPort to Work with Your Scanner ]
  • Scanning with the WIA Interface [ Fine Tuning Your Scans ]
  • Maintenance [ Clearing Paper Jams ~ Care and Maintenance ~ Cleaning the Scanner Glass ~ Cleaning the Automatic Document Feeder ~ Replacing the ADF Pad Assembly ~ Replacing the Roller Assembly ~ Troubleshooting ~ Error Light Troubleshooting Codes ~ Uninstalling Your Scanner ~ Uninstalling the Scanner and One Touch Software ~ Uninstalling the PaperPort Software ~ To Install Another Driver ~ Xerox DocuMate 510 Scanner Specifications ~ Xerox DocuMate 510 Parts List ]
PLEASE SEE THE COMMENTS ON INSTRUCTIONS TO REINSTALL
Jan 25, 2011 | Xerox DocuMate 510 Document Scanner
Black line in the middle of the output - scaned document
A black line down a scanned page indicates a dirty scan glass. Lift the top of you scanner like you would putting a page or book down to scan. On the end of the scanner that has the document feeder you should see a thin piece of glass the is separate from the larger glass pane. This is the document feeder glass. Now check it over for a very small mark of ink or dirt. You can use regular glass cleaner to wipe this glass just spray it on a piece of cloth not the scanner then wipe. You may have to wipe and then try scanning several times if the ink or marker is died on. while you are cleaning you should also clean the main glass pane, it will make the scans clearer and crisper.
I hope this helps, if so please rate our solution.
buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 05, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
I have a xerox documate 510 scanner I can not scan more than one page at a time through the feeder
Clean the rubber rollers with Iso Propyl Alcohol. If worn out replace them. Fan the papers so that they are not sticky. This should work.
S. Mohan
Aug 27, 2009 | Xerox DOCUMATE 510 Flatbed Scanner
Line down center
Often this is merely a mark on the scanner glass. When using the automatic document feeder the light/sensor will stay in one spot and motors will feed it. Make sure to clean the glass in this part usually left of the large glass area is a smaller strip see if there is a mark on the glass there.
Jun 11, 2009 | Xerox DocuMate 510 Document Scanner
When scanning color document, blue tone is present as background shade
Have long experince with PixEdit program using Kodaks. PixEdit usually comes around it after a firmware upgrade on the scanner. Not sure about this specific model but at least OK on other models of Kodak.
Sep 25, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
DOCUMATE 510
check on the flat bed part along the top. there are two white strips that go side to side. the top white strip is wider than the bottom strip right underneath it. On the thinner of the two strips, check for small black marks, can be very small. This creates a black line in the document. You can clean it with a fingernail & a tissue
Jun 25, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Line through image
There is some contamination on that side of the glass. Look on the side where you feed in the paper in the scanner.
Only takes a smallest of spots on the glass where the lamp parks in the document scanner mode.
Clean that throughly and see if maybe there is something on the bottom of the seal glass. Like i said, it can be a very small very hard to see mark on the glass.
Jan 30, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Xerox DOCUMATE 510 Flatbed Scanner Logo
450 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
