Question about Pure Digital Flip Video Ultra Camcorder
Flip side HD will not charge
The battery is not charging. Power in/off not operating
SOURCE: Brand new Flip Ultra HD. Giving error "Check Battery Pack Chargin
check the contacts on the bottom of the pack. for some reason, the plastic sheathing covers the positve contact of one of the batteries. i took an xacto knife and cut a small hole to expose that end. after that, voila, no more charging problem. i woke up to a full charge this morning!!!
Posted on Aug 08, 2009
SOURCE: I am charging my new Flip Ultra HD battery pak for
1) remove the battery pack from the camcorder
2) connect the camcorder to a powered USB port on your computer
3) when the "Connected" indicator comes on, insert the battery pack into the camcorder
4) safe eject your camcorder from your computer
5) reconnect your camcorder to your computer
6) the battery pack should now begin to charge within the camcorder
Posted on Oct 03, 2009
SOURCE: Flip Ultra HD red light won't turn off after
UNIT: ultraHD
PROBLEM:
I just had this problem: I turned it on, started to record a video, but it hung up on frame #1, with the record red light stuck on. And I couldn't do any of the following: restart the recording, play already recorded videos, turn it off, connect to PC.
SOLUTION:
I removed the battery for about 30 seconds, then replaced it. my UltraHD flip works great now.
Posted on Feb 03, 2010
SOURCE: my flip mino HD has been charging for 3 hours and
Is it plugged in directly or with a USB extension cable? Some cheaper cables are not sufficient to charge it.
Posted on Mar 19, 2010
SOURCE: flip video won't charge
If you look on the bottom of the camera there is a button that slides from a locked to an unlocked position. Slide it to unlocked and then slide down the back of the camera (the side with the lens) there is a removeable rechargeable battery pack. Remove it for a moment and then put it back in. Try plugging back into the USB port. This should work.
Posted on Mar 22, 2010
Flip ultra hd 3 U32120 wont charge
I had the same problem with the battery not charging. I used a sharp knife to scratch the contact points on the battery and all was good. Thanks for the support in this thread.
Nov 30, 2013 | Pure Digital Flip Video Ultra Camcorder
I have a flip slide hd S1240W that has not been charged up in a long time. I have tried to charge it and attempted to reset and then charge. All that is happening is a red flashing light but nothing at...
Try removing the batteries, plugging into your computer, popping the batteries back in, and removing. Wait 5 minutes, and plug back in! This should have an affect!
Oct 06, 2013 | Flip Video SlideHD S1240W HDMI Camcorder
I just bought my 11 year old an ultra hd 2 hr flip video, we cannot even get it to power on, any suggestions?
You need to first Charge your camcorder battery pack.(mine had to charge over night) the first time.  Plug the little arm that extends from the camera into a USB 2 port on your computer and make sure your computer stays ON during the charging, otherwise the camcorder will not charge.
A red light will come on during charge and goes off when charged. If it does not come while plugged in try a different USB port.  Screen should light up temporarily and Red light showing charging on front of camcorder.
IF YOU HAVE ALREADY DONE THE ABOVE, and are having the problem, pull the battery pack out and reseat it back in there again.  maybe connection not good.  OH, and I think mine had plastic covering the metal connections you may want to check that too -remove if so----- BUT the entire white plastic around the batteries STAYS IN PLACE do not remove that.
If that still doesn't work I would try regular AA batteries in it if in fact you have The FLIP ULTRA HD it will take regular batteries too.    IF they work - then maybe you got a defective Rechargeable Battery pack and should contact Flip Video at   http://www.theflip.com/en-us/
Feb 13, 2011 | Pure Digital Flip Video Ultra Camcorder
I'm having a hard time getting my Flip HD to charge. It is brand new and this is the first time I've had to charge it. Sometimes the red light is on and steady and other times the red light is flashing. ...
I had this charging problem with 2 new Flip Ultra HD cameras...red light flashing..nothing on the screen after plugging in the USB port.
I removed the battery..plugged camera into USB port..pc recognized the camera... installed flipshare software..updated software...plugged battery back in..all good.
Why on earth the book doesn't mention these steps is beyond me.
Oct 11, 2010 | Pure Digital Flip Video Ultra Camcorder
Failure in the camera's USB ports
Finally I solved it!!!!
Situation: My Computer (MAC And PC) wasn't recognizing the FLIP ULTRA HD, because it has a corrupted file, but couldn't format because there was no communication between camera and computer
Solution:
1. Charge your batteries until get the FULLY CHARGED icon (Green Battery)
2. then remove the batteries without unplugging the USB 3. Voila...computer recognize the USB
4. Format the Camcorder with the Following tutorial: http://www6.nohold.net/CiscoFlip/ukp.aspx?vw=1&docid=763c871b45fc4b20b5a671b24c909
20e_Reformatting_and_Reinstalling_FlipShare_
on_a_Flip_Camcorder.xml&pid=4&respid=0&sni
d=2&dispid=0&cpage=search
5. Install software in camera...
6. CONTINUE VIDEO CLIPPING!
Jun 28, 2010 | Flip Video Flip Ultra Camcorder
My flip mino HD has been charging for 3 hours and will not turn on. I've tried resetting the battery and it still won't turn on
Mar 18, 2010 | Pure Digital Flip Video Ultra Camcorder
Flip videp ultra hd - red light blinking while charging
i have the same problem too. whenever i try to charge it through the dock. the red light continuously blinks and it won't charge.
Aug 22, 2009 | Flip Video Flip UltraHD 8GB High...
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Flip ultra hd not charging
I had the same problem, but it seemed to be a bit more sporadic. I'd occasionally get the "Charging Paused - Check Battery Pack" error. The battery pack itself looks a bit strange, since the white plastic covers the bottom, right side and it seems that there is no possible way for the battery to make contact with the camera. However, I saw the following suggestion on another site (which the poster claimed came from Flip technical support), and this technique worked for me:
May 20, 2009 | Pure Digital Flip Video Ultra Camcorder
Flip video won't charge
Jan 09, 2009 | Pure Digital Flip Video Ultra Camcorder
Pure Digital Flip Video Ultra Camcorder Logo
21 people viewed this question
Top Pure Digital Video Cameras Experts
Ron Dufek
Ron Dufek
sharky633
sharky633
tomikles
Level 1 Expert
Are you a Pure Digital Video Camera Expert? Answer questions, earn points and help others
