Question about Kenmore Dryers
Remove lint from kenmore dryer 110.64992301 - Kenmore Dryers
scottowa
  • 87 Answers
SOURCE: Clothes dryer (Kenmore) only blows cold air
What is the model number on the inside by the door. It's most likely a thermal fuse or the element. Do you have a way to check fuses by a meter or something? There are usually 2 thermal fuses on the pipe with big red wires where the element is. Usually they go out if not the element.
Posted on Apr 13, 2009
jsrock516
  • 5911 Answers
SOURCE: Clean Dryer Lint Vent in Kenmore elite HE4
If you wish to clean the interior cabinet of the dryer follow these steps:
1. UNPLUG the dryer. Dangerous voltages are still present even with the dryer turned off.
2. Open the dryer door and remove the lint screen. IMPORTANT: You must remove the lint screen first in order to remove the blower fan housing.
3. Remove the lower toe panel directly below the dryer door by removing the screws under the bottom front edge of the panel. With the screws removed, the panel will drop down, then come off. NOTE: For better access, you can prop the front feet of the dryer up (a 2x4 works well).
4. Loosen the screws on the blower fan housing directly below the drum and remove. There's usually a small clip holding the cover in at the bottom that you may need to pull out to release. NOTE: You may also have to disconnect the auto dry sensor plug (yellow wires with white plug - use a small screwdriver to release the locking tabs) and/or ground wire to accommodate removal of the cover.
You should now have access to the dryer interior and the blower fan squirrel cage motor. Take the time to clean out the blower fan housing cover as well. A long bristle brush made for dryers works well at removing any lint inside the dryer in the hard to reach places, followed by vacuuming.
NOTE: After cleaning, you may experience a slight burning odor. This is normal as lint gets stirred up in the cleaning process and can settle on the heating components. The odor should dissipate after a short period of use.
If you have any questions, please let me know. I hope this helps you.
Posted on Sep 29, 2009
  • 2328 Answers
SOURCE: Kenmore series 90 electric dryer: exhaust air is
that's normal,obviously you haven't cleaned out your dryer and vent line,nobody ever tells the customer when you buy your dryer that it should be cleaned out at least once a year so you don't have a fire more so if it's a gas dryer with an open flame inside the dryer,you gotta vac out the inside where the motor is,clean out the duct that the lint filter slides into and blow out the vent line,i use a leaf blower to clean out the vent line,take it off the back of the dryer,stick the leaf blower in the line if it's a long run if it runs through the wall and to the outside flapper and blow all the **** out of it,also if you have a shop vac put it on blow and blow off the motor,you won't believe how much lint comes off the motor even though it looks clean,so vac out the inside of dryer,clean out the lint filter duct and blow out the vent line
Posted on Dec 18, 2009
  • 454 Answers
SOURCE: kenmore 70's dryer, not heating,
Maybe timer, try a different heat cycle.
Posted on Feb 06, 2010
  • 157 Answers
SOURCE: kenmore dryer model 76901690 76901 how do i remove
UNPLUG THE AC POWER CORD. Take a metal wedge with a cloth cover. Carefully drive into the grove about 2 inches from top in front of unit above the door. The top will pop up. A locking post is located on each corner. Raise the top like a clothes washer lid. Vacuum the inside. Remove the exhaust tubing and vacuum inside the dryer exhaust port & tubing. If this don't resolve your problem you have an electrical or belt problem. Check your belt by rotating the drum with your hand when you have the top up. Please reply to my suggestion. Thank you.
Posted on Feb 12, 2010
My kenmore gas dryer end buzzer goes off and dryer shuts down before cycle is complete
Instructions Things You'll Need:
  • Kenmore gas dryer
  • Vacuum with hose attachment
  • Replacement fuse, if necessary
    Dryer Not Heating
  1. Remove lint from your dryer's lint screen. Remove the lint screen from your Kenmore dryer and vacuum the area behind the lint screen with your vacuum's hose attachment.
  2. Check to make sure that the dryer temperature is set appropriately, and has not inadvertently been turned to "Air Fluff."
  3. Ensure that the gas valve on the supply line to your Kenmore dryer is completely open.
  4. Check the room temperature in your laundry room to make sure that it is at least 45 degrees. Your Kenmore dryer will not operate properly at temperatures below 45 degrees.
  5. Make sure that the dryer outlet grill is not blocked by a fabric softening sheet.
  6. Dryer Not Running
  7. Check to see that the dryer cord is properly plugged in to the electrical outlet.
  8. Check your fuse box to make sure that the fuse is not blown, or check your circuit breaker to make sure that it has not tripped. Replace the fuse if necessary or throw the circuit breaker.
  9. Check the outlet itself to make sure that it functions properly by plugging in a portable device.
  10. please comment on these solution on how it works by rating or voting.
Dec 30, 2010 | Kenmore Dryers
I need to figure out how to get the front panel ff of my daughter's kenmore dryer Mod #96093800 to clean the lint from inside. Also the dyer heats up but doesn't get hot. any suggestions
First you have to remove the back and then top of the dryer, then you will have to remove the drum. After the drum is removed you may see screws along both sides on the inner corners of the front. (You may not have to remove the front once drum is out.) Remove these and the front should come off. There is usually lint jammed in the front tube if this dryer has a lint trap under the door, thus causing the heat not to circulate through the dryer.
Feb 21, 2010 | Kenmore Dryers
How do I clean the lint out of the Kenmore Eite He3 past the lint screen?
Remove lint screen. Remove bottom front kick panel (usually three to four screws on very bottom front), There is a metal lint filter air duct assembly that has three to four screws holding it on. Usually one on each upper side of the duct, and one that has a bent metal bracket holding the bottom to the blower housing. This metal duct is dead center in the dryer under the door and ducts over to the bottom left. Remove the screws and pull the duct down and out. You can now clean this assembly. Needless to say, always unglug the dryer or turn it off at the circuit breaker before doing this job. I recommend that you do this at least once a year on the dryer, and clean out the washer lint and coin catcher at least once a year. Good Luck, Appliance Specialists.
Dec 20, 2009 | Kenmore Elite HE4 Electric Dryer
Sep 29, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer model 64781 no heat
if it is a top mount lint filter you can remove the back to get to it,if lint trap is inside the dryer you get to it in the front-do you have a meter?mike
May 21, 2009 | Kenmore Dryers
Lint filter will not go back in kenmore soft series dryer
Lint could be preventing the screen from re-inserting into the slot. Unplug the dryer and use a coat hanger with some duct tape on the end looped around so that it attaches to the hanger and has a sticky side for the lint at the bottom. Remove lint and try re-inserting the screen.
Apr 30, 2009 | Kenmore Dryers
Dryer not drying cloths
HI thanks for your question. the lint filter housing is full of lint. remove the lint screen. 2 screws. remove. pry top up with a flat screw driver, from the almost the corner. lift the top up. pull dryer away from the wall remove the air duct that the lint filter goes in clean out the lint. thanks the appliance doc
Oct 16, 2008 | Kenmore 73952 Gas Dryer
How to replace heating element, kenmore model 110.60912990
lint screen in door ? remove bottom apnel ..top lint screen remove rear panel both cases ckd thermal fuse on top end also
Jul 03, 2008 | Dryers
Kenmore dryer (electric )
Almost always a thermal fuse.
If your lint screen is in the door, follow these directions:
Disconnect the power. Remove the lint screen. Slide a putty knife in between the toe panel and the bottom of the door three inches from either side. this will release the clips at the top. Tilt the toe panel out at the top and lift it off the clips on the bottom.
Remove the two 1/4 in screws at the top of the metal triangular box around the lint screen. There may be one more ***** near the bottom right of the box holding a gold bracket in place. Remove that ***** or lift the box off the black metal clip at the bottom.
You can now reach the thermal fuse. It's the white plastic part with two wires on it near the blower wheel. If you have an ohm meter, you can test it now. Or remove it (one 1/4 in *****) and take it to the parts store for testing.
If your lint screen is in the top of the machine, follow these directions:
Disconnect power. Remove the lint screen. Remove the two Phillips screws under the lint screen handle.
Pull the dryer away from the wall about 2 feet or more. Disconnect the vent pipe from the bottom of the dryer. Remove the nine 1/4 in screws holding the back panel on, along with the small metal cover. Lift and remove the back panel.
You can now reach the thermal fuse. It's the white plastic part with two wires, close to the blower wheel. If you have an ohm meter, you can test it now. Or remove it (one 1/4 in *****) and take it to the parts store for testing.
While you're back there, be sure to clean out the long metal box that the lint screen goes into (four more 1/4 inch screws.)
Mar 12, 2008 | Kenmore 63942 Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
