Question about HEWLETT-PACKARD M1212nf All-In-One Laser Printer
Load cartridge for HP Laserjet M1212nf
How do you change toner?
  • HEWLETT-PACKARD Master
  • 3,606 Answers
HELLO DOWNLOAD A USER MANUAL HERE:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&dlc=en&tmp_geoLoc=true&document=&product=3965849
THE FILE IS IN THE PDF FORMAT SO YOU NEED ADOBE READER TO READ THE CONTENT.
GOOD LUCK
Posted on Dec 02, 2012
2 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: HOW TO FIX SCANNER ERROR 52 HP LASERJET M1212NF
Possible that a reset might help. It is worth trying to re-install.Shut down PC system and restart with the printer removed , then install the driver software and on completion connect the printer-hardware- to be installed.Test and see if it works or else you might need help from HP support.Check this link : http://www8.hp.com/uk/en/support-drivers.html
Posted on Dec 14, 2011
What should i do to Stop initialization error
Check the paper paths are clear and reseat the toner cartridge. I assume this is not the result of a firmware update?
Try a reset, I found instructions for a hardware reset on another forum:
1. Power down
2. Press <right> and <cancel> buttons together
3. Power up during pressing these Buttons
this should clear the error, if the problem is due to a firmware update here's a link to an hp forum
M1212nf fails to initialize after firmware update HP Support Forum...
May 08, 2014 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
1020 drum laserjet
The OPC drum is contained inside the toner cartridge.. just buy a new toner cartridge! OPC stands for (Organic Photo Conductor) and its part of the toner cartridge.. Buy a new cartridge HP order number is Q2612X or aftermarket
Feb 04, 2014 | HP LaserJet 1020 Printer
How to replace hp laserjet p2015d drum
The drum is part of the toner-cartridge, so when replacing the toner-cartridge, you are also replacing the drum.
Solution - Change cartridge :)
May 01, 2012 | HP LaserJet P2015d Printer
Laserjet m1212nf mfp, getting "suppy
Supply memory error is referring to a defective toner cartridge. Actually it's the electronics chip that is attached to the cartridge. The printer gets toner information by reading the chip. Replace the cartridge.
Aug 12, 2011 | HP Hewlett Packard LaserJet 3000dn Printer
Unable to resolve "scanner error
how can i resolve the error code 22 on my hp laserjet m1212nf MFP?
Jul 23, 2011 | HP LaserJet M1120 MFP All-In-One Printer
Right hand printer cartridge light is flashing - have taken it out and reinserted it, no luck, so put a new one in, still no luck. Only way I can get it to work is to take the right hand cartridge out and...
A Non-HP Toner Cartridge installed error message occurs in the following situations:
  • Non-HP cartridge is installed
  • HP cartridge is not installed correctly
  • False error
  • Sensor issue (hardware)
SOLUTION: The Non-HP Toner Cartridge installed error message could be cleared completing the following steps: All HP toner cartridges carry the Hewlett-Packard logo, and meet HP's high quality standards. 1. Verify that you are using a legitimate HP toner cartridge by going to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage. Click here to go to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl01270) . 2. Remove the toner cartridges, clean the metallic contacts by a dry linen cloth, and then reseat the toner cartridge, and check if the error occurs. To reseat the toner cartridge, see the instructions at the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage. Click here to view the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314345) . 3. If the issue persists, perform a firmware upgrade from the Download drivers and software page at www.hp.com. 4. Restore the factory defaults in order to restore the default settings: a. Use the left arrow or the right arrow button to select Service , and then press SELECT . b. Use the left arrow or the right arrow button to select Restore defaults , and then press SELECT . If the issue still persists, even after completing the troubleshooting steps provided, then use one of the following support options so that HP can work with you to resolve the issue, because it may be related to printer hardware where it needs a live interaction
Oct 26, 2010 | HP Deskjet 460c InkJet Printer
How to refill HP Laserjet C4127x Cartridge
http://base0.net/archives/207-Refilling-Laser-Printer-Cartridges.html
http://www.wisegeek.com/how-do-i-refill-toner-cartridges.htm
Jan 09, 2008 | HP LaserJet 4050n Printer
HEWLETT-PACKARD M1212nf All-In-One Laser Printer Logo
139 people viewed this question
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Victorman
Victorman
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
