Question about Iomega 1TB Desktop USB 2.0 Hard Drive
My Iomega HDD1H4-2 drive no longer shows up on either my Imac or my Mac Mini? Cables seem to be OK. Is the Iomega toast?
5 Suggested Answers
PauldLucky
  • 268 Answers
SOURCE: external drive wont mount
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 2 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing.
Restart the system.
If it does not resolve the issue then you can try this :
Check this before you try to edit the registry values.
http://developer.apple.com/documentation/Darwin/Reference/ManPages/man1/profiles.1.html
Just remove the registry key it happen when this key is corrupted.
HLKM\System\CurrentControlSet\Enum\USBSTOR
And delete all references to the external hard drive.
And also HLKM\System\CurrentControlSet\Enum\USB
and found the keys associated with the USB to IDE value.
After restarting the system, the drive shold be detected & configured automatically by the computer.
Disclaimer : I will not be held responsible for anything that happens to your computer as a result of following my guide. Use this guide at your own discretion and risk.
You can use the Disk utility in MAC to run the diags on your drive.
Good Luck.
Live, Love, Laugh.
Posted on May 14, 2008
SOURCE: IOMEGA eGo portable hard drive won't copy files from mac
Format your hardrive for Mac OS:
Go to Disk Utilities under the go menu in your finder. Select the external drive and click on the erase tab. Clikc erase again and it formats the drive. You can now copy files onto the drive.
Posted on Feb 08, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Iomega drive clicks 2/second. Fails to connect
Hello there:
sorry to say this but it looks like the platters on the harddrive are scratched and unreadable or the little pointer arm in the drive that is used to get the information is faulty is unable to read any of the information so it is swinging back and forth across the platters looking for information, when it cant find any it records it as a no device found.
you may be able to have the drive repaired but it may cost you a bit to do it ok you may want to consider trying to get the information backed up off the drive if you can and than see if it can indeed be repaired. ok?
best of luck michael
Posted on Sep 02, 2009
  • 29 Answers
SOURCE: Iomega large external hard drive doesn't show up
Well this is a tough one. I am assumeing that you have done all the normal things.
Most external hard drives are just a standard internal hard drive with a case and a IDE/SATA to USB adapter built in. When you plug in the drive and it powers up listen to the drive if you hear a clunk. Not a the happy ticking of a normal drive but a bad clunk. This can mean that the controller on the hard drive itself is bad.
If everything sounds happy then I would try replacing your power adapter. I know that the blue light goes on but most of that runs off the 5 volt leg of the power supply (I have has some hardware manufacturers actually pull the power light voltage from the USB port Grrr) most of the Large sized external hard drives use a 12 volt adapter and it can have no problem with the step down to 5 volt it may have a problem with the 12v.The 12v is what it uses to spin the drive. Unless you have one of those little drives. They use a laptop hard drive that works of a lower voltage. Most of the time you can get an adapter from Radio Shack. Be sure to bring the old one so they can get the Volts, amps, poleartity and the type of connector. It is worth a try and keep the reciept. If it is just bad I am sorry but the only way to get the data off is to break into the unit and pull the hard drive out. Then use another USB to IDE/SATA adapter to pull the data off.
Hope this helps a little.
Posted on Sep 13, 2009
How do i make my iomega eGo writable on my Imac?
Been a ton of problems with these drives and Macs. A huge number of complaints about them not mounting. There is a supposed "mac" version that works better. Good luck.
Dec 07, 2014 | Iomega Computers & Internet
I have an iomega minimax device that I cannot seem to connect to my imac. when i plug the device in nothing happens on the desktop.
try getting a new power cord from iomega, If that doesn;t work, the drive is probably corrupted. They are under a year warranty. You ship yours to them and they will send you a new one. Try the free chat on Iomega
Jan 17, 2011 | Iomega MiniMax Desktop - Hard drive - 500...
I want to connect an LG 32LD550 television monitor to an Intel based 24" I mac computer---what cable is needed?
The LG 32LD550 television has HDMI and VGA.
Your iMac has a mini-DVI output port with support for DVI, VGA, S-video, and composite video connections via adapter.
So all you need is either:
1) mini-DVI to VGA adapter.
2) mini-DVI to HDMI adapter.
HDMI is better quality, and so I'd recommend something like this: http://www.amazon.com/PTC-Mini-DVI-Adapter-6ft-Macintosh/dp/B001H0REVK (You may want a longer cable though).
Dec 22, 2010 | Apple 24 iMac - Intel Core 2 Duo 2.8GHz,...
My iMac crashed when I hooked up a new Iomega hard drive. How can I fix that problem?
Macs are exceptionally good machines, if you are still under warranty you can get free support from apple. However at times the apple machines behave very strangely and it is very hard to diagnose the exact reasons for the problem.
There is a software called Onyx; it will search for the programs that are slowing down your mac and then it will suggest you fixes and repairs for the problem. Download it here : http://www.apple.com/downloads/macosx/system_disk_utilities/onyx.html
Also the problem can be a fragmented hard drive in that case you can utilize the below program to defrag your apple drives.
Download it here :http://www.ehow.com/how_2091895_defrag-mac-hard-drive.html
If you can still connect your external hard drive to your iMac then http://www.kenstone.net/fcp_homepage/partitioning_tiger.html follow this link to format your drive using your mac.
If you can't connect to your external drive from your mac; and if you have access to a pc then you can use the ubuntu live cd and use the gparted software in the Ubuntu distribution to format your external drive to hfs volume.
Hope this will help you solve your problem.
Best Regards
NextDoorNerd
Jul 28, 2010 | Iomega MiniMax Desktop - Hard drive - 500...
Iomega 1TB HD Works on iMac but not on Windows Laptop?
as the mac has a diffreent format to a pc you cannot connect up the drive to a pc because it simply wont recodnise it. the best way is to network the 2 computers together then alow file sharing on the mac and searcc with windows through the network to find the drive. then copy them across the network to your pc. this will then reformat the files to PC files at they hit your PC
May 17, 2010 | Iomega 1TB Desktop USB 2.0 Hard Drive
Imac external HD problem
You do not have permissions set up correctly.
Jan 09, 2010 | Apple iMac G4 20" Mac Desktop
IMac failing to recognize Iomega UltraMax Hard Drive
I have the same problem too, this iomega is terrible, I have it only less than two months and it is not working already. Evan it has one year warranty I will not suggest anyone to buy it in the future.
Jan 03, 2010 | Iomega 33089 250 GB Hard Drive
I formated my iomega with my iMac, and now it does
format it with msdos, instead of mac osx journaled.
Dec 28, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Iomega mini max external HD slowing things down
the hd external iomega 500 gb minimax have a litle noice and don't work dont conect whit my computer.
Mar 06, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
Oct 29, 2008 | Iomega (33090) 250 GB Hard Drive
Iomega 1TB Desktop USB 2.0 Hard Drive Logo
513 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
