Question about Kitchen Ranges
How do I replace the light on a Samet Extractor
Need to replace the globe on a Samet stove extractor
SOURCE: Bosch Extractor Fan model DKE945DGB
One way to check is to track down a schematic of the parts. That will often give you a good idea of there the part attaches and how.
Posted on Feb 21, 2008
SOURCE: Neff extractor fan not working
I have a similar problem with a Whirlpool oven hood. In my case the kitchen fiitters used a (UK) standard 3-pin plug to power the hood. The plug is fitted into a socket that is placed on top of the cupboards that house the hood.
I have replaced the 3 amp fuse in the plug and now the fan is working.
HOwever, the light isn't working and so I'm assuming that the bulb has blown and that this has caused the fuse to blow as well.
Now my problem is accessing the bulb so that I can replace it.
Posted on Jan 29, 2009
  • 72 Answers
SOURCE: how to install a kitchen hood extractor
Use the template that came with the hood, mark holes on wall and then drill and insert wall plugs. Offer unit up and screw from the inside.
Posted on Dec 28, 2009
  • 72 Answers
SOURCE: minimum distance between diplomat chimney extractor and gas hob
Minimum above a gas burner should be 750mm and for electric hob should be 650mm.
  • 72 Answers
SOURCE: bosch dke 935 90cm hood. light and extractor not working
The fuse will be located in the switch or socket that the hood is connected to. This is sometimes inside the flue on the back wall. There should be two small screws either side of the chimney located at the top, unscrew and slide one part of the chimney down, please be careful as stainless steel has very sharp edges.
Posted on Jan 04, 2010
I need a extractor and a extractor detent ball for a Mossberg 100 ATR .270 Win. bolt.
Fixya does not sell replacement extractors and extractor detent balls.
Jul 11, 2016 | Mossberg Optics
Smith and wesson sd9 feed problems 16+1
Clean, clean, clean! Probably a little sludge in the extractor or extractor spring. Pull it apart, clean it as if your life may one day depend on it, light oil, re-assemble, test fire, and a final quick clean.
Apr 13, 2014 | Watches
How do you remove and replace harmonic balaqncer on nissqan sentra 2002 1.8
you need a pulley extractor. undo the bolt and put the pulley extractor. watch out when it come off as the is a half moon shim that will fall out and you need it to put new one on. b56699df-775f-4628-95fc-e1835e836bcb.jpgthis is just one type of pulley extractor there are loads of other types.
Dec 24, 2013 | 2002 Nissan Sentra
I Have a GE Micro JVM2070. When I boil water on the stove the water vapor shorts out the Micro. It then turns it self on or doesn't work at all. If I unplug it it might work in a few days.
One would think that you would have the sense to use the extractor that is above your stove and under your microwave, would you use a laptop in a sauna!!! no wonder the thing is shorting out. Contact the person who fitted the microwave. always use the extractor when you boil things on the hob.
I live in England it is illegal to have a microwave above a hob for this exact reason. America will catch up eventually with building regulations!!
Nov 05, 2009 | GE JVM2070 Microwave Oven
I have a Samet built-in oven (linea italiana #DG941ET) and I want to know what its temperature gauges mean. They range from 1 to 7. Thank you.
Samet Double oven - Small oven on top. Glass door just shattered whle cooking. Can i Buy a new door or have the glass replaced in South Africa.
Jun 16, 2009 | Ovens
Wireing a bathroom extractor fan to a three switch (fan=landing light=offswitch0
yes, if the three switches are all made together, then there is only one feed. sounds like a bad switch, or possibly bad exhaust fan. check voltage at fan with switch on, if not qualified, be careful, or call an electrician
Aug 10, 2008 | Dryers
Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
