Question about Compaq Presario 5000 PC Desktop
Meanwhat does three second of tone at power onmean
    Problem Solver:
  • 13 Answers
It could mean your ram is gone bad or not compatible,or video card is dead
Posted on Jan 11, 2009
I have a separate fax line for my Canon MX310. It goes into fax mode but noting happens. I also cannot receive faxes.
The only reason to call the phone company is if you're not getting a dial tone on that line. Otherwise, have you shut down the printer and tried to reset it to factory defaults. To do that, follow the instructions below:
  • 1 Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
  • 2 Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
  • 3 Release "Stop/Reset" while holding down the "Power" button.
  • 4 Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
  • 5 Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
  • 6 Push the "Power" button, then lift the MX310 cover open.
  • 7 Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
  • 8 Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
  • Good Luck Mark
Feb 20, 2015 | Canon PIXMA MX310 All-In-One Printer
My pioneer sx-316 multi channel receiver is off on protected mode what do I do to restart
I read the instructions perhaps slightly differently perhaps. I take the instructions to mean first hold down tone and then hold standby/on key for three seconds. Have you tried doing it as two steps?
1 Switch the receiver into standby.
2 While holding down the TONE button, press and hold the  STANDBY/ON button for about three seconds.
3 When you see 'RESET?' appear in the display, press the ENTER button. OK? shows in the display.
4 Press SETUP to confirm.
Feb 03, 2015 | Pioneer New Original SX316S Remote Control
How to unlock control panel LFFH21F7HWG?
Press and hold the Control Lock key for three seconds
to activate or deactivate the function. The Control Lock
feature prevents the user from changing the temperature
and freeze settings. At the first press of any key, the
key press click tone will be heard and the display will
show "LO", but no other change will take place. Holding
the Control Lock key for three seconds will activate or
deactivate the Control Lock feature. After three seconds,
the accept tone sounds and the Control Lock LED (if so
equipped) is activated. In lockout mode, when any key
is pressed, the invalid key tone will be heard and "LO"
will be displayed for 1 second. When the lockout is
deactivated, the Control Lock LED is turned off and the
display shows "UL"
if this does not work unplug the freezer for 30seconds then plug it in. if all of the above fails replace the control.
Jul 04, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
No dial tone on all of my three mobile phones
If the rechargeable batteries were all put in service around the same time, then logically they would fail around the same time.
Aug 13, 2017 | Panasonic Lands Phones
How do I disable circuit protection in yamaha 3064
Solution (according to Yamaha service):
Plug the power cord out. Plug it back in.
Press the following three buttons at the same time for 5 seconds: Straight + Info + Tone Control
While you keep these buttons pressed, press Power Button
The receiver will open.
Aug 30, 2012 | Yamaha Audio Players & Recorders
I can only get three ring tones on my Iphone, even though all of the ring tones show up under my device in Itunes. Please help. Turning off the phone and restarting or re-synching doesn't work.
Ringtones that exceed 0:30 (30 seconds) that are in your library will not sync with your device. If these ringtones that won't sync are over 30 seconds you will have to find new ones that are less then 30 seconds.
Mar 03, 2011 | BLACKOUT LABS Ringtone Designer Free
I have a quicksilver power mac G4 desktop that has a blinking green light when I turn it on. What should I do?
I assume the light you refer to is the power LED.
No Apple tech repair guide says anything about this LED being able to blink.
It's possible that this is an indication that it is trying to upgrade firmware, especially if it is accompanied by a loud audio tone of about three seconds. I can't say this for sure, because it has never been necessary to activate the firmware upgrade mode on a Quicksilver, since Apple never released any firmware upgrades to it. Firmware upgrade activation is achieved by holding in the power button at startup until the tone is heard. If you are hearing the tone and the power LED is blinking, it may simply indicate that your power button is sticking in.
Dec 27, 2009 | Apple eMac G4 Desktop
2005 pontiac grand am
Turn ignition to "ON", slowly press accelerator to the floor three times within five seconds, wait a few seconds and you will hear three tones, the "Change Oil" light will turn off. Turn the ignition to "OFF" and the light will be reset.
Good luck..
Sep 04, 2008 | 2004 Pontiac Grand Am
Cant get one of the phone to get dial tone says unavalibel
All you have to do is put the phone that does not get a dial tone on the MAIN CHARGING BASE for 20 seconds! it will then sync up!
Jul 17, 2008 | GE 25931 Trio Cordless Phone
Trying to replace lamp fan
First let make sure it's the Lamp fan. What many people think is the fan, And by the way there are three fans in this model, What sound like a fan is in fact a color wheel. So listen to the set as it starts up, these Samsungs make certain sounds when they start. First after you hit the power button you get the "Samsung Tones" from the speakers, second ALL the Fans start 1 to 2 seconds later the color wheel starts then stabilizes, third you may here the lamp fire. So if the sound takes two to three seconds after you turn the set on it's the color wheel BP96-00250A Now when it shuts down its like this First the shutdown "Samsung Tones" then watching from the back after a few seconds the lamp will shut off, then the color wheel stops but all the other fans remain on for about 2 minutes. I've worked on thousands of these and in only one or two was the problem a fan. but on the other hand I have enoghf bad color wheels I was able to make a pertty inpressive Christmas decoration
Feb 05, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Compaq Presario 5000 PC Desktop Logo
14 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
