Question about Lowrance GPS
Hi i have problem putting way points into my lms l337c df gps unit,when i put cordnates into the unit and they only have 6 numbers the unit want let me save the way point,iv been putting an extra 0 at the end of the numbers so i can save the way point,was just wondering if this is the right thing to do,or should i put an o at the start of the codinate numbers,thanks if you can help me out
  • kia_roa Jan 11, 2009
    i just payed to get this problem worked out,i need a positive answer thanks
    hi there isnt an answer to my question in the lowrance web site
    thanks david
  • 837 Answers
Since waypoint entries are based on Latitude/Longitude, degrees, minutes and seconds .. by putting the waypoint entry in with the 'zero' at the end you are not correctly "plotting" .. if you entry is less than 6 digits .. precede the entry with zero(s)
Posted on Jan 11, 2009
    Genius:
  • 1,239 Answers
Hi
no dont use zero at start,,because some program will read the o as negligible....so start coordinate numbers
  • 4,806 Answers
Hi there
Go to the Lowrance website for the PDF manual and firmware update this should help you sort the problem out
http://www.lowrance.com/en/Products/Legacy-Products/34014/
Good luck
    Brigadier General:
  • 5,158 Answers
I would think the zero should be at the start
LMS 337c DF. The LCD backlight seems to jump from bright to off and back continually after the unit has been on for 10-15 mins. holding finger on the power/light button stabilizes the problem until the...
the lcd is going out and will cost more to fix it then the cost of the gps....my advice is to get a new one from bestbuy and get the 4 yr performance service replacement plan so next time you have a problem like this they will replace it for free.
Mar 06, 2008 | Lowrance LMS-337CDF GPS Receiver
Lowrance completely dead
my lowrance lms 337c df will not power up. I checked all the cables and poer and they are good . can you assist me
Aug 14, 2011 | Lowrance LMS-337CDF GPS Receiver
Is there an external antennae for the lms 527 combo available
  • No it does not. Lawrance often makes either external or internal GPS units. This is an internal antenna unit only model. Hope this helps.
Regards, Tony
Jun 05, 2011 | Lowrance LMS-527C DF iGPS GPS Receiver
My LMS-522C keeps losing it's position on the GPS.
I'd suggest calling Lowrance.. Those guys are very helpful with step by step support... I just purchased a used boat with a 525c df on it and been troubleshooting some problems with it. Central time zone and best to call right when they open or turn on the phones at 8:15.
Mar 07, 2010 | Lowrance Lms 522c 5" Screen Color Internal...
HAVING A PROBLEM WITH MY LOWRANCE 525C WITH EXTERNAL ANTENNA. IT KEEPS TELLING ME GPS MODULE NOT RESPONDING. I HAVE CHECKED ALL CONECTIONS AND CANNOT FIND A PROBLEM. WHAT NEXT
Make sure that you have powered the NMEA 2000 network. The display unit's power cable has a set of red, black, and sheild wires that need to be hooked up to a 12VDC power source. There is a power diagram somewhere in the manual that should show this.
Make sure that you have the NMEA 2000 network connected properly. If it is a newer version LMS-525, it should just be a single 15ft cable that has two female ends, the module plugs into one end, and the other end plugs into the back of the display.
If it came with some T connecters and 120Ohm Terminator caps, then make sure you have that hooked up correctly. There should be a diagram in the manual for that as well but you just connect the two T's together like TT, put the 120Ohm terminators at each end, and run the extensions to the display and GPS module.
There is a decent troubleshooting guide for checking to make sure power is getting to the module at http://primus.lowrance.com/support/resultDisplay.do?gotoLink=92&docType=1000&contextId=426%3A92.273%2C600.639%2C92.113&clusterName=ClusterPublic&lang=english&docset=%2FDocuments%2FTroubleShooting%2FNew+Utility&contentId=42296cce-4f9b-40c8-9dcf-33d5df754009&responseId=135ccbe2cfd4f608%3A1fe88d%3A1225c5cc17c%3A-bac&groupId=4&answerGroup=1&score=986&page=http%3A%2F%2Fprimus.lowrance.com%2Ficr%2FTroubleShooting%2FNew+Utility%2FNU_GPS_ModNR.htm&result=0&excerpt=Module+Not+Responding+The+GPS+module+not+responding+(early+GPS+products+may+also+indicate+coupler+not+responding)+indicates+that+the+unit+and+module+are+no+longer+communicating.&question=gps+module+not+responding&resultType=5000#Goto92
If this doesn't tell you anything, most likely the GPS module is bad.You will need to contact Lowrance support to get it repaired/replaced. You can call them at 800-324-1356 or email them at http://www.lowrance.com/en/Support/Product-Support/Contact/
Jun 29, 2009 | Lowrance Lms 525c Df 5" Df Sonar...
My Lowrance LMS-337c df keeps going crazy.
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}This could be caused by glitch in the operating systemsoftware or by low voltage due to a short in the unit or somewhere in the boatswiring. To troubleshoot the problem Iwould recommend the following steps.
  1. Try a soft reset
  2. If the problem resurfaces, try a hard reset
  3. Update the the operating system software
Soft Reset (Does not delete GPSData)
1. Turn unit OFF 2. Press and holdthe PAGES key
3. Press and hold the PWR key
4. Release both buttons when the USA map
Appears
Hard Reset (Deletes stored GPS Data
such as Waypoints and trails)
1. Back up any waypoints, routes,and trails that you want to save on a blank MMC card
2. Turn unit OFF
3. Press and hold the ZIN&ZOUTKeys at
the same time
4. Pressand hold the PWR key
5. Release both buttons when the USAmap
appears
To update the operating system software, check out this link:
Lowrance337c df update
If you don't have a card reader I can program an update card for you.
Dec 15, 2008 | Lowrance LMS-337CDF GPS Receiver
Gps
I have a manual for this unit but i'm still using mine so not willing to sell it to you. I'm in Melbourne and you're welcome to borrow it for a week or so or i could probably photocopy/scan certain sections for you and email them if it helps. Let me know if you still need it by emailing me at joshklat@hotmail.com
Cheers,
Josh
May 21, 2008 | Lowrance LMS-337CDF GPS Receiver
GPS Logo
22 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
