Question about Home
Shower pump Deva pum40
When using the shower after a few minutes the pump makes a pulsation noise and can only be rectified by turning the pouwer off then on
2 Suggested Answers
SOURCE: Aqualisa Aquastream shower noise from pump/motor ?
aquastuream loud noise?motor/pump
Posted on Sep 04, 2009
Shower valve making banging noise pressure balanced even after changing cartrige
turn hose water off. open facet at lowest level to drain out lines. open a few faucets around the house to let air in. then close everything up. turn water back on. repressurize system by turning some faucets back on. see if it still happens. this is letting air back into any anti-water hammer devices that might be in system. sometimes they loose the air in them that makes them work. this should add air back in. good luck.
Mar 10, 2015 | Grohe Danfoss Tempress ll Tll Shower Valve...
N-069m pulsating when hot water is turned off.
Do you have a well our on city water? Check in coming water pressure make sure it is not over 60psi
Sep 14, 2014 | Noritz 6.9 Gallon Residential Tankless...
My karcher 250 pulsates when i turn it on, any idia how to fix it thanks
Several things can cause this problem. It is trying to build up pressure and something is preventing it.
1. check water pressure comming out of the the spicket.
2. Make sure the hose and connectors aren't leaking.
3. make sure there isn't any water leaking from the washer.
If all is ok I would guess the pressure pump has gone out that's the noise you hear pulsating trying to build up pressure.
Terry
Jan 15, 2011 | Garden
Hello, my aqualisa shower is working intermittently, water starts and then goes down to a dribble, but not all the time. It is an aqualisa quartz.
If you are not getting any water through your shower it is possible that there is a restriction.
Please note that the air lock test is only neccessary if you're shower is the Pumped Digital Quartz or Quartz Thermo Mixer Shower and that you are on a Gravity Fed Water System (cold tank in loft).
The hose will appear fine from the outside,but the hose has an internal rubber liner which can become blocked/twisted.
To remedy this,unscrew the shower head from the hose anti-clockwise.Place the open end of the hose to it's lowest point (bath or tray).
Turn the water on.The water SHOULD come out in a straight line,if however the water comes out in a V-Shape the liner is twisted and the hose will need replacing.
Air Lock
If there is air in your pipework this will cause low flow and pulsing.To remedy this fault do the same above but run the water on FULL COLD for two minutes and then FULL HOT for three minutes.
If the water pulsates it is the air escaping.If it does this leave it until it corrects itself.
Hope that this info helps you,if it doesn't it sounds like you have a mechanical fault with the processor box.
Aug 24, 2010 | Kitchen Ranges
Pulsating water and poor hot water pressure
Based on your description it sounds like the pressure balancing valve could be gunked up with particulate from your well or just worn out. If your water is not filtered to that shower I would lean more towards particulate. Try to remove the cartridge and take it to a plumbing parts store for a match-up since Delta makes several cartridges and you want to get it right the first time.
Feb 10, 2010 | Delta & Single Handle Shower Faucet
My macerator turns off and stops working for 10 - 15 minutes
the macerator is over heating.check the maintenance opening and clean it ,but you may need a more powerful macerator,some are made only for flushing systems (as in toilets) a pro-longed use may be making it overheat.. good luck
Jul 02, 2009 | Saniflo & Saniplus& Macerator Pump
Hot and cold oscillations on my deva envy shower
no man i installed plenty of shower valves if your in the shower looking at it the left is hot always just make sure ur holding it right side up most of them have a plug that goes in the bottom to block the tub spout and the top goes to the shower are maby u put it in upside down? good luck man if you run in to another prob, post again good luck
Apr 11, 2009 | Plumbing
Mar 30, 2009 | Home
05 equnox sharp turn noise
I forgot to ask if the noise was front or rear and stationary or moving so I will cover both.
If the noise is while the truck is stationary and the noise is from the front I would have to say the power steering pump. I have been changing several lately for similar concerns.
As far as the rear if the noise happens while making sharp turns and makes a whirring/growling noise while in motion its the rear differntial. What you can do yourself to be sure is find an open lot and drive in rather tight circles for about a minute, then noise should stop. This action flushes the clutch disks and stops the noise. If the noise goes away you will need to do a rear diff flush.
The fluid is very expensive so be sure this is your problem first.
In order to do the flush drive in tight circles for 5 minutes in each direction and then drain and fill the rear diff with the new Versatrak fluid.
Good Luck
Aug 01, 2008 | 2005 Chevrolet Equinox
Home Logo
29 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
