Philips 42PF7621D/10 power problems
POWER issues
4 Suggested Answers
roety
  • 585 Answers
SOURCE: Philips 42pf7621d/37 Will not turn on , red
Hi, most likely it neeeds a power supply, but without voltage checks I could not be sure.
the power supply part # is 310432836203
Posted on Aug 18, 2009
  • 73 Answers
SOURCE: philips 42pf7621d/10 dead
One of the circuit boards should be replaced inside, probably the power supply, the good thing is that screen is ok and it's a most expansive part, you can take it to the local repair shop for diagnostic and repair.
Posted on Oct 10, 2009
  • 68 Answers
SOURCE: TV CONTROL FOR A PHILIPS
try to check the remote responses to the buttons, get a camera and put it directly on the sensor of the remote if the light is blinking when you press the buttons the remote is ok if not try to replace it with another sensor from a defective remote
Posted on Jul 20, 2011
Philips LCD TV power cycles on and off during power on sequence. TV will not power on.
This typically indicates a power supply issue. In order for the TV to protect itself, instead of staying on and causing over heat and potential fire, it shuts off. Contact Philips for possible warranty info.
Jun 06, 2016 | Philips Televison & Video
Philips 42pf7621d 10
What is the problem you faces with this TV? Provide more details please.
Sep 12, 2013 | Televison & Video
TV CONTROL FOR A PHILIPS 42PF7621D/10 WILL NOT WORK . BATTERIES HAVE BEEN CHANGED
Jul 20, 2011 | Televison & Video
Philips Cineos flat screen TV vith Ambilight 37PF9631D/10, went in standby and blinking red power led diode once-two times in cicles.
Sounds like an issue with the power supply board. We will have to go component by component and you will need to knowledge of using a multimeter. If you are skilled enough to do this then let me know and I will help you troubleshoot it.
Mar 19, 2010 | Philips 37PF9631D 37 in. LCD HDTV
Philips FW 780 v Set Wiring Diagrame
Please will you indicate the problem so that we can go by the present issue. Within the electronics side specify whether it is power side, the drives,or the optical.
Feb 27, 2010 | Audio Players & Recorders
Philips 42pf7621d/10 dead
Oct 10, 2009 | Philips Televison & Video
Philips LCD TV 37PF5520D/10. TV will not switch on.
philips has a problem with bad caps(swollen)in power supply-try shopjimmys.com enter model number-scroll down til you find power supply-order it simple to put in.if they do not have it write down part number then google it to find one--you also can change the bad caps yuorself if you are handy with a soldering iron
Sep 11, 2009 | Televison & Video
Philips 42pf7621d/37 Will not turn on , red light blinks 4x.......I NEED HELP!!!!!!
have its power supply checked and diagnose by a qualified technician
Aug 18, 2009 | Televison & Video
My phillips 42" flat screen model number 42pf7621d/10 keeps blowing the fuse in the plug usually after we have turned the tv off and its in standby mode or overnite when we sleep ive just change...
What is rating of fuse in your TV like amperes and volts.
There is Thermistor in TV for degaussing the picture tube while in start up. This part requires heavy current to work for a second or two.
You can increase little bit current rating of fuse to avoid blow off.
Oct 01, 2008 | Philips Televison & Video
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
