Computer boot but nothing show up on monitor
The computer boot up fine no beep sound but noting show up on the monitor,the keyboard has no power,no sound coming out from the speaker
  • 4 more comments
  • empty_kenbai Jan 11, 2009
    My computer finally started but i'm getting cmos error and my ddr speed gets lower from 333 to 266
    nothing, the computer just restart itself then at first nothing show up and no beep the keyboard has no power sound but i can open close the cd rom,now it boot up but with cmos error and the ddr speed get lwer from 333 to 266 and it boot just up to the boot from cd press any key part and then it hangs it did'nt boot the window xp
  • Asylum_Donna May 25, 2009
    I booted my computer up, checked all the cables when I saw the monitor was dark and wouldn't respond to the mouse or keyboard. The mouse and keyboard are not lit up, so the computer is not recognizing them but everything is plugged in properly. I did a hard reboot and hit F10 which didn't do me any good since I still have a black screen. Any ideas?
  • Roberta Smith
    Roberta Smith May 11, 2010
    have you done anything to the computer recently.. added anything ?
  • Roberta Smith
    if you don't hear at least one beep... it's not booting up fine
  • Anonymous Mar 26, 2014
    power comes on & starts to boot then 2 beeps. 1 long and 1 short. Boot does not go past this point
    Sergeant:
  • 270 Answers
Nothing, the computer just restart itself then at first nothing show up and no beep the keyboard has no power sound but i can open close the cd rom,now it boot up but with cmos error and the ddr speed get lwer from 333 to 266 and it boot just up to the boot from cd press any key part and then it hangs it did'nt boot the window xp
Posted on Jan 12, 2009
Computer powers on but monitor, keyboard and mouse are not working
Once the monitor shows "no input", indeed the mouse and keyboard are pretty useless, even if the are working, as you cannot see they are working. If the monitor power light is on or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
Feb 17, 2013 | Compaq Computers & Internet
Dell inspiron 530 desktop won't boot, fan is running, no signal on monitor
It sounds like either your monitor or video card inside the computer is bad.
If the monitor is showing the "No Input Signal" message then the video card inside the computer is bad. The monitor is ok otherwise it would not be able to display the No Input Signal message.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 06, 2012 | Dell Inspiron 530 Desktop Computer
Acer computer won't boot has long buzzing noise
The long buzzing sound indicate the nature of the problem. Depending on the manufacture of your bios will determine the problem. With only one long beep you may have memory problem. The computer cannot initiate the boot sequence. Did you add any devices to the computer prior to your problem. if you did undo what you did. Make sure the computer is on, if nothing happens ( no lights, no sound, no fans etc.) the computer has a power failure. Make sure you listen to the beep if it is a numerous beep sequence note it down and check the web for computer beep during boot up.
Mar 25, 2012 | Computers & Internet
Desktop: Gateway LX6810-01 PC will not power on. When I hit the Power button on the tower, a long continuous BEEP comes on and nothing appears on the monitor. After the BEEP, the On light (on tower)...
Thank you for using FixYa
I would try shutting down the computer in the normal way, and turning off the monitor.
Boot up and turn the monitor back on.
If it still doesn't work, then I would check the cables and power plugs and wall plugs.
Check the mouse and keyboard cable and any other cables plugged into the computer.
The next step requires a seperate monitor or laptop.
Try unplugging the monitor and pluging in another monitor. Most laptops have a common
VGA adaptor jack or even an Svideo jack.
If the other monitor does not work, Then take to a qualified technician for repair.
It could be your power supply in the computer or video controller.
I hope this was useful and please comment if this was helpful to you.
Mar 24, 2011 | Computers & Internet
Keyboard and VGA port does not work,i think it's a motherboard
i think your board is dead you must wait 15 seconds to reboot your pc or you will over surge it with power my buddy did it to mine and blew up my graphics card your board might be dead but does it make a clicking sound when you try to start it or any beeps if not your board is dead you could try to clear the cmos just take out the round watch battry on the board for about 5 min and then put it back in and start it up but theree should be a jumper you can use to clear the cmos cmos is your pc's boot options you know when you hold the delete button and shows your boot options it will reset itself try that if nothing works your board is dead
Feb 11, 2010 | EliteGroup Goal 3 Plus/Sempron 3000+...
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
Dell Monitor Power save mode activate using pc
yes right click on desktop select properties then click on screen saver then increase wait time problem will solved
Oct 29, 2008 | ViewSonic VE155b 15" LCD Monitor
No booting
did u chk the power cable to monitor ?
replace the power cable wd tht of the tower or cpu if cpu glows then ur monitor neds to be repired
May 22, 2008 | Intel Motherboard
Computers & Internet Logo
481 people viewed this question
David Payne
David Payne
