Question about SMC Planet Dual WAN Router w/4 port 10/100 Fast Ethernet Switch (XRT402D)
NAT settings for Planet router WRT-414
How can I set up NAT settings for my Planet router! Can you please help me?
  • ramizi_tr Feb 16, 2009
    i give wrong password and i can conect to menu
I cant log into my planet wireless router wrt-416 (192.168.1.1) i reset my router because i cant remember the username and password it was configured. please can you assist me how to resolve this problem
Hello !
Usually on routers, on the back of the device you should have a "default login". If you do not, USUALLY, the user is either "root" or "admin" and pass "". (blank pass).
Update : I checked out your model and it says the default credentials are:
User : admin
Pass : admin
Hope that helps !
All the best.
Aug 03, 2011 | Computers & Internet
I cant configure my wireless router planet planet wrt-416 afer i reset and configure it and if turn it off,it just go back to its old setting
If you are doing a hard reset(usually by pressing the small button on the back) then this will erase the settings.
Configure the router, and if you ever need to restart it, just unplug it for 10 seconds via the power cord then plug it back in.
If when you turn it on/off the settings always reset to factory default, the router may be bad and you need to have it replaced.
Thumbs up is always appreciated!
May 04, 2011 | Computers & Internet
Port forwarding not working on router cisco 861w. ROUTER nat DHCP IS WORKING. I have used this command to add portforwarding: ip nat inside source static tcp 192.168.0.222 80 interface FastEthernet4...
make sure you enable both tcp and udp port fowarding . worst case comes to worse reset it back to factory settings. or upgrade the firmware (i couldnt port foward until i upgraded my firmware on my wrt model)
Mar 17, 2011 | Cisco 861 Router
Hello, I have a Linksys Router model No. WRT 160N and have problems with the wireless signal. Doesn't appear the wireless symbol ON and I have connected already the modem cable. The modem is OK cuz I can...
* NOTE: If you tried to set-up the WRT-160N Router previously, but failed, with the Router ON, press the "Reset" button on the back panel and hold it down for 10 seconds, then release. This will reset the Router to factory settings and erase all previous data.
Then do this
1. Hook up the Linksys WRT-160N Router to the modem(cable, DSL or satelitte)
2. Hook up the Linksys WRT-160N Router to your computer via a LAN cable with the LAN cable in Port #1 on the Linksys WRT-160N Router.
3. Type http://192.168.1.1 in the address bar of your web browser.
4. Log-on to the Linksys WRT-160N Router with these log-on credentials:
Username: linksys (lower-case)
Password: admin (lower-case)
5. Click on the "Clone PC MAC Address" tab.
6. Click the "Clone PC MAC Address" button.
7. Click "Save", click "Continue".
8. Click the "Wireless Security" tab.
9. Choose "WPA2 Personal - TKIP/AES" for encrypted security.
10. Enter encryption password (passphrase).
11. Click "Save", click "Continue".
12. Exit the web browser.
13. Disconnect the LAN cable from the computer and Port #1 on the Linksys WRT-160N Router.
In about 5 seconds, your wireless connection should be up and running.
Sep 15, 2010 | Linksys WRT160N Wireless Router
Restricted nat for xbox / linksys 160n router need to open
You are trying to open the NAT on the router for X-box.
For this you will need to reduce the MTU settings on the router to 1365.
You will also need to trigger some ports on the router.
For this you will need to open the router set up page.
Router set up page is the page where you can change the settings of the router
Click Here
to know more about router and network
Apr 20, 2010 | Linksys WRT160N Wireless Router
Change NAT to open
Click Here to know more about router and network
Mar 14, 2010 | Arris SURFboard SBG900 Wireless Router...
My NAT type is on moderate so I cant play Xbox Live
I tried everything and eventually figured this out.  Do this!
Enable DHCP set the start ip to 192.168.1.100, and remove any static IP address on your xbox 360 (have it automatically detect connections)
Set the MTU to 1364.
enable UPnP.
if you are using wrt-dd (if you aren't, you should be)  setup QoS so xboxlive has premium priority.
And you have hit the ground running.  Even microshats own website wont' help you fix this stupid problem.
I promiss this will work ;)
May 16, 2008 | Computers & Internet
Set nat to open
These routers have a setting underneath the advanced tab (within advanced setup) called UPNP.....all three of the active tick boxes need a tick in (by default they don't) and this will sort the NAT stuff out.
Jan 19, 2008 | Zyxel Prestige 660HW Wireless Router...
Computers & Internet Logo
487 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
