Question about Mitsubishi M-VR600 Receiver
Receiver not putting out audio
I have a Mitsubishi M-VR600 Receiver connected to a Television and a DVD Player. The other day I noticed there was no audio. So I checked all the connections on the TV, DVD Player, and the Receiver. I also checked the set up of the Receiver to make sure it was on the right output. I tried cleanng the lens of the DVD Player and tried using a new DVD. None of these steps seemed to work. Does anyone know anything else I can do? Or if this system is simply dead? Thanks for your help.
    Genius:
  • Mitsubishi Master
  • 1,550 Answers
Probablemente tu aparato tenga dañados los amplificadores de audio.Llevalo a un taller para su reparacion.
Posted on Apr 01, 2008
Does anyone have the Set-up code for the Mitsubishi M-vr600 a/v receiver? The owners manual doesn't list one.
Download mitsubishi m-vr600 manual - Google Docs
https://docs.google.com/document/d/.../edit Google Docs, Sheets, and SlidesLooking for mitsubishi m-vr600 manual? Download mitsubishi m-vr600 manual.mitsubishi m-vr600 manual. User Manuals, Instructions and Guides.We have ..
Aug 17, 2015 | Mitsubishi M-vr600 Audio Receiver
My dvd player is hooked up to the samsung receiver. I am using two remotes, one is the cable box remote where I hit tv and power and then cable and power and then the red power button on the samsung remote...
What you have to do is select the proper item on the receiver since that is what you have the dvd player connected to. Pressing bd/dvd on the receiver is not necessarily the right thing to do. All receivers have an input or source or function button that will enable you to choose the correct area where your device is connected. The way you have this hooked up may not be right but first things first. You will need to have a movie playing in the DVD player so that you see the numbers advancing. Go to each input/source/function on the receiver until you hear the DVD. Ok great! Now getting the picture is a little more tricky so please follow along carefully.
The cables going from the DVD player to the receiver: The cables should be connected to where it says OUT on the DVD player or hdmi out from the DVD player to one of the receivers INputs. Once that proper connection has been confirmed make sure the receiver is connected to the television for both video and audio. You must have a video cable as well as audio cables between the television and the receiver or an hdmi cable. If it is not connected to the television in this way that is the problem right there. In fact you probably have a cable going from the television's audio OUT going INto the receiver. In order to see your DVD player you will also need to connect the receiver's video OUT to the television's video IN.
You will need the television's remote to be able to change the source/input/video/aux on the television. You might be able to change it with the cable box remote by pressing tv and then input/source/video.
ALTERNATELY: You can connect the DVD player's Video OUT directly into the television's INput. The DVD player's Audio OUT cables would be connected directly to the receiver's IN.
Either way you will have to choose the correct input on the receiver as well as on the television itself.
May 16, 2011 | Samsung HW-C700
Have mitsubishi m-vr600 and remote...need remote code!
TEGO UN CONTROL REMOTO M-VR600 QUE ME VINO CON UN TV CS40509 Y NO LO NECESITO...QUIEN LO NECESITE ESCRIBIRME AL CORREO tabaresarboleda@hotmail.com y podemos hacer algo... de colombia- medellin
Aug 16, 2010 | Mitsubishi M-VR600 Receiver
CANT GET MY TV TO WORK WITH DVD PLAYER
Connecting a DVD player to your stereo receiver (or television, if you don't have a receiver) involves making two basic connections: audio and video.
Audio
The first connection to make is for the audio portion of the signal. There will be several options depending on the receiver you have.
  • The best choice (if available) is either to use an optical (also called Tos-link) or coaxial (RCA) digital connection. These two choices are equal in quality. In order to use either of these, you will need to have both an output on the DVD player, and an input on the receiver. Only receivers with built-in Dolby Digital decoders will have this type of input.
    The audio outputs on a DVD player
  • If your receiver does not have a built-in Dolby Digital or DTS decoder, but is "Dolby Digital ready," look for the 5.1-channel Dolby or 5.1-channel DTS. This connection involves six cables, corresponding to different speaker channels: left front, center front, right front, left rear, right rear and subwoofer.
  • The last option to connect the two components is with analog RCA outputs. This is a two-cable connection, with one cable delivering the left speaker sound, and the other cable delivering the right. This connection will deliver only stereo sound, but it may be your only option if you are hooking up directly to a television, or if you have an old receiver with only two channels.
Now let's take a look at the video connection.
  • The best quality choice is to use component connection. This connection consists of three cables: color-labeled red, blue and green. The quality is superb. However, these connections only exist on extremely high-end receivers and television sets.
    The video outputs on a DVD player
  • The next option is s-video. One cable connects the DVD player to the receiver in this setup.
  • The last option, similar to the audio setup, is to use the analog RCA video output, usually color-labeled yellow on both ends. This will deliver the lowest quality, but will suffice for most older, analog televisions.
Jul 03, 2010 | Symphonic Televison & Video
I am looking for an owners manual for mitsubishi m-vr600 can it be sent to my email lawton3@juno.com thanks!
If google and manufacturer website are of no help then ask a search agency like http://manualfox.com - They do a great job.
The service is not for free, but often worthy (you only pay if they find what you are asking for).
Oct 21, 2009 | Mitsubishi M-VR600 Receiver
Unable to get surround in dvd mode but can hear thru tv speakers?
Is your DVD player hooked up to a surround sound receiver, or directly to your television?
Mar 18, 2009 | Mitsubishi M-VR600 Receiver
Owner's Manual & Remote Control
Checa en este sitio http://sumanual.com
Mar 29, 2008 | Mitsubishi M-VR600 Receiver
241 people viewed this question
Top Mitsubishi Audio Players & Recorders Experts
Marvin
Marvin
ray gallant
Are you a Mitsubishi Audio Player and Recorder Expert? Answer questions, earn points and help others
