Question about Candy CPCA240FFK Bottom Freezer Refrigerator
My refridgerator is freezing my food
The setting is on the lowest setting, but all food is freezing can you help, hope so thakyou.
    Problem Solver:
  • 5 Answers
Are all your lights working ie interior light and warning lights on front, i had the same problem with fozen food and it turned out to b the control board cost me 75 supply and fit
Posted on Jan 11, 2009
I have a Westinghouse Moist Cold Cylic Defrost refridgerator the freezer is great but my fridge area is on the lowest setting but is freezing my food, ,Why is this ?
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
May 02, 2011 | Refrigerators
My refridgerator freezes everything even on the lowest setting
heatman101
Apr 20, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Refrig in camper keeps freezing food even when on lowest temp
It's either the thermostat or the door seals leaking Since its freezing the refridgeration unit is fine
Oct 22, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
Refridgerator problem
Not sure about your model, but most of these style side by side refridgerators use the cold air from the freezer to cool the refridgerator. Sounds like your "flapper" valve is broken. At the top left in the refridgerator there should be plastic shroud. Remove it and your flapper valve should be under it. You will most likely find the flap broken off of it. You may have success using epoxy to glue it or you may have to replace the valve assembly.
Good luck.
Apr 20, 2009 | Frigidaire FRS26H5AS Side by Side...
Refridgerator side of my refridgerator keeps freezing my food
The problem may be low gas or it may be the thermostat is set too low.  First, look at the possibility that you may have the food partly blocking an air channel which is where the very cold air is coming from..  Fridge side should read about 40 F after the door is closed for about an hour.  If colder, adjust.
Nov 15, 2008 | Refrigerators
Refridgerator freezing food
dm, I'm not sure if the thermostat is mechanical or electronic. Assuming mechanical...and I do...turn it to the lowest number...does it turn off? If this works properly, the problem is likely not the control. Does the compressor turn off at any time? If not after an hour or so of operation, the stat could be defective. That's my first guess. Oh, have you made sure that you don't have the ducts in the freezer blocked? The would deflect too much cold air to the fridge section.
Next, defrost the unit and clean the condenser coils. This will help the unit work properly. Then, wait awhile with the unit off. Meanwhile, access the compressor in the rear of the unit. Find the largest pipe coming out of the compressor. Turn the unit on. The largest pipe should frost and then, in about 5 minutes or so...either cause condensation or dry out. If neither happens and the line is either not COLD to the touch or frosty, you're low on gas. If the unit is less than 5 years old, you may get warranty coverage on the sealed unit from the mfgr. Believe it or not, too little gas will cause freezing in some cases!
Nov 28, 2007 | Kenmore 53212 / 53214 / 53219 Side by Side...
Candy CPCA240FFK Bottom Freezer Refrigerator Logo
154 people viewed this question
Top Candy Refrigerators Experts
Charles T Nevin
Charles T Nevin
Cesar Quant
Cesar Quant
Are you a Candy Refrigerator Expert? Answer questions, earn points and help others
