Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Gadget installer Hello, I have a XP Pro SP3 Vista Look with sidebar unfortunately,i remove from my programs gadget installer and now every gadget with extension .gadget can't install and i can't find the right gadget installer.exe on the internet can u help me pls to solve Can u send me that small thing or a link with it... thx in advance
    Problem Solver:
  • 7 Answers
You probably have a problem with the skin you used. I have used several and had full luck with the standard .gadget applications. Try using a different skin or reinstall the one you have now.
Good Luck!
Ben
Posted on Jan 12, 2009
Why can i play hidden object adventure pack on my dell with Windows xp
Hi Jennifer,
When you say that you are unable to play , do you mean its not loading ? unable to install it? do you get a specific error message when you try to launch it ?
hidden object adventure pack:
  • System Requirements: Windows XP (Home & Pro) SP3, Windows Vista SP1, Windows 7 . , 800 MHz processor or greater. , 512MB RAM. , 237MB free hard drive space. , DirectX 7.0. Administrator privileges are required to properly install the program on Windows XP, Windows Vista , and Windows 7. Format: WIN XP,VISTA,WIN 7 Genre: ENTERTAINMENT Rating: E10+ Age: 8386390063
if your using windows XP , make sure that you have Windows XP (Home & Pro) SP3 and the rest of the specs mentioned above.
Thank you.
Dennis
Aug 03, 2014 | Video Game Consoles & Games
How do i remove the sidebar
vista
On the Windows desktop, mouse over the sidebar and right-click on the search gadget you want to remove.
Click on "Close Gadget." The search function is now gone from the sidebar; however, the search gadget is still installed on your computer for future use if you ever decide to re-add the item to your sidebar.
To completely remove the sidebar search gadget from your entire computer, follow the next steps.
Right-click on the Windows sidebar.
Click on "Add Gadgets" to open a window containing all sidebar gadgets installed on your PC, including the search gadget.
Right-click on the sidebar search gadget you want to remove, and click to select "Uninstall."
Click "Uninstall" again when a Windows notification pops up, asking you to confirm the uninstall process.
After you click, the program will automatically be removed from your PC and it will no longer appear on the listing of available sidebar gadgets for Vista
windows 7
Click "Start."
Click "Control Panel."
Double-click "Windows Sidebar."
Remove the check from the box next to "Start Sidebar when Windows Starts."
Click "Save." Now, the next time you load your computer Windows Sidebar will not start.
hope this helps
Aug 24, 2012 | Sylvania G-Netbook
Windows 7 gadgets working wrong
You dont need side bar anymore, rightclick anywhere on desktop and goto gadgets, Add the ones you want, put them where you want (side, top, anywhere) and thats your gadgets as they were in vista.
If you have installed Windows 7 beta then you must be aware of the bug that whenever UAC is switched off, Sidebar and Gadgets in Vista fails to display properly on Windows 7 Desktop. Though this is not for every machine but many users have reported this problem that their Sidebar and Gadgets are not working properly.
For older beta versions of Windows 7 there had been some temporary workarounds for the same problem. But if you are using Win7 Build 7000.0.081212 then this can be fixed using a simple registry hack which like in Vista will Elevate your Sidebar and Gadgets Process.
If you know how to play with you registry Editor then just open regedit.exe from Run command in Windows 7 and go to KEY
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows
\CurrentVersion\Sidebar\Settings From there edit the DWORD value of AllowElevatedProcess and set it to 1. You don’t need to restart your Windows 7 computer after this. If your sidebar and Gadgets were not working properly earlier then they will be fixed instantly.
Jun 19, 2010 | Microsoft Windows Vista Home Premium with...
Dimension 5100 and windows xp pro SP3 clean install
I was able to dig this up.
Reference: http://4sysops.com/archives/tip-how-to-install-and-uninstall-a-program-in-safe-mode/
Run Windows in safe mode.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\
Create a registry key REG_SZ key and call it MSIService and value data and call it Service, which is the windows installer. This will give you permission to uninstall windows service Pack 3 from add/remove programs while in safe mode.
May 09, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
When opening sidebar windows installer opens .
It is likely some sidebar gadget you've got installed that wants to use bluetooth.
Take a look at the installed gadgets, and see if that makes sense. To administer gadgets (I am assuming the sidebar is not opening properly), but do try to start it, then:
Start
Control Panel
Windows Sidebar Properties
View list of running Gadgets
Remove any gadgets that may cause the trouble.
Feb 09, 2009 | Microsoft Windows Vista Ultimate Edition
Problems adding new gadgets in Google sidebar on Vista
Try re-installing google sidebar, or make sure you're on the internet.
Dec 20, 2008 | Computers & Internet
Installation of Windows XP Pro on Hp Pavilion laptop
what is the error message that you're getting.. usually windows vista will not downgrade your operating system to windows xp. You may need to remove vista before you can load xp.
make sure to save a back up of all of your important files before you do that.
Nov 11, 2008 | Acer Aspire 5050 5430 Laptop
How to restore windows vista side bar
2 solution for this problem
1) start - all programmes - accessories - windows side bar or
open the Start menu and in the search line type this word: sidebar
and hit Enter key
Feb 27, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
363 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
