Question about HP LaserJet Pro CM1415fnw
Switched to Comcast and my HP LaserJet CM1415fnw will not connect
Using the Wireless Wizard I can see my new Comcast Router (switched from Verizon router). I chose the correct network name and enter the password listed on the router. My laptop is connected to the same wireless network and it works fine. My printer tries to connect but comes back saying my password is incorrect.
khanmohammad
  • 188 Answers
SOURCE: Printer is not working after changing the router
Hi Nagureddi,
Please click on the web link given below and perfrom the steps as given in the web page.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00805046&cc=us&lc=en&dlc=en&product=391194
Have a great day!
Posted on Mar 24, 2008
SOURCE: cannot receive/send faxes nor can
Bad phone line. Check it with a regular phone.
Posted on Aug 31, 2008
leroyal
  • 2120 Answers
SOURCE: How can I install my fax HP640
All fax machines are ANALOG devices. They are designed to work on POTS (Plain Old Telephone System). Any other condition is a **** shoot.
Posted on Sep 05, 2008
PABLOCSA
  • 1124 Answers
SOURCE: connecting to printer on wireless network with built in wireless adapter
You have to share the printer to the network
To do that go to Start >> Control Panel >> Printer
Select your printer and right click go to Sharing
Mark "share this printer" an hit ok
A small hand will appears below your icon printer
Now you have the printer available on your network
Posted on Oct 03, 2008
  • 53 Answers
SOURCE: Jetdirect 170x External Print Server Not Visible over network
it is possiable that a firewall is in the way, but more likely is that you are on a different logical network or subnet.
the HP software relies upon doing a broadcast to find HP printers, broadcast traffice is not normally permitted between subnets, this is why the HP software does not find your printer.
basically you need to creat a new port on the computer in question and then associate a printer to that port.
do so by doing the following on XP pro.
get to the printers folder then click from the menu "File"
click "server properties"
click add port and then double click on the (Standard TCP/IP Port) a new wizard opens click next
in the top box enter the ip address of your printer. and click next. leave the device type as "Standard and as generic network card) click next then finish. then close.
now you have to link your printer to your new port.
install a new printer
making sure that you select local printer... but removing the tick "Automatically detect......" then click next and select LPT port 1.
click next choose HP on the left colum and HP lasterJet III from the right colum. click next give the printer a name of your choosing. and if nesseary choose if you want it to be a default printer or not.
click next and leave do not share selected.
click next
on the "do you want to print a test page " select "No"
then finish.
once done
right click you new printer select properties
then select the "Ports" tab
scroll down the list until you see new Standard TCP/IP port listed, select your port. then click apply
lastly click the advanced tab
using the driver part of this screen you are able to select the correct driver from the dropdown list if it is not avaliable click the new driver button and follow the prompts.
click OK when done.
hope this helps.
selecting the HP Laser Jet III making sure that the
Posted on Nov 08, 2008
Adding to discription.I'm trying to connect two computers that access the net wirelessly but are not networked. I'm installing the HP using the HP installation disk,it does the configuration tells me to...
I am assuming your router or modem has wireless capabilities, or you have a wireless hub. If your provider is comcast you have to have comcast wireless equipment.
Make sure wireless is turned ON at modem/router switch and or IP page(192.168.0.1 in URL. most equipment uses that address by default if not you will have to get the address from the manufacturer of your equipment.). Again if your provider is comcast call comcast to set up your equipment (you have already paid for it!).Once you have established you are broadcasting a signal you should have no problem connecting. I hope that I helped GOOD LUCK
Sep 22, 2013 | D-Link Computers & Internet
We recently switched to Comcast and now our printer is not working. It says that it is on, and ready, but nothing happens when we try to print. We have an HP Color LaserJet 2840, and we use it for faxes,...
It seems that the connectivity b/w the printer and the computer is not through. Is it a wired or wireless printer? When you switched to comcast, did you made any changes to the wired connection with printer?
Mar 02, 2011 | HP LaserJet 2840 Printer
How do I hook up a Berklin wireless router to my comcast internet
Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
Start Internet Explorer on your computer.
Connect to the web-interface inside the router.
Run the "network setup wizard".
Run the "wireless setup wizard".
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Need help getting wireless laptop connected to internet
1. Go to Start, Control Panel, syetm.hardware, device manager. Under network adapters make sure your wireless is there. Note: there is a recall for HP laptops including the DV9000 because they eractically lose their wireless settings. If this is the case call HP tech support.
2. Assuming your wireless card is listed (not the 1394) and there are no red or yellow check marks we can now go back to control panel, network connections.
3. If wireless connection is not listed then click the task Create a new connection. This brings up Welcome to new connection wizard. At this point you should see a line that says to connect to a wireless network in range . . . If this line is there click this then select your SSID (network name). If this line is not there and you're sure the network switch is on and turned blue then you'll need to call HP.
Mar 23, 2009 | HP Pavilion dv9000z Notebook
Wireless connectivity with Vista
since you have verizon modem wireles router..
i have the same issue with the same model...I call verizon and tell the issue...verizon accepted that modem router have problem in wireless...i know that all my computers have no issues because i maintain and built those computer by me..
then Verizon send a new and different modem router...this time it works fine...since i received it last week. call Verizon regarding the wireless issues ..tell them too that you have some dead spot on your wireless..like if you move away more than 15 feet..your wireless connection get lost..
i hope this might help
Mar 16, 2009 | HP Computers & Internet
Connection
Hi Susie
With related to your particular issue it seems like that your broadband modem is not configured for the router. There are basically 2 types of connection. DSL and Cable modem. Verizon, ATT are DSL and comcast other providers give you a normal cable broadband connection. If its comcast make sure the cable from the comcast modem is going to the internet port in the linksys router and also make sure that there is a system connection the linksys router and the cable from the system goes to any of LAN 1, 2, 3 and 4 ports. Then reset your cable modem by using a pin and inserting to the reset hole in the modem. You could use the same step to reset your linksys router as well .If its a verizon or dsl connection you need to put normally your username and password in the router page. here is the link to how to configure linksys for your internet modem.
Here is a video as well on it?
http://in.youtube.com/watch?v=vSAXMO7aNzg
http://tinyurl.com/5tqqhl
Also post the linksys router model. your ISP modem model number and also information on how many systems are wired to the router and wireless and let me know if you need more help.
Thank you
Rakesh
Dell Laptop Expert
Jan 09, 2009 | Linksys Wireless-G Broadband Router
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
SETTING UP EASY INSTALL WIZARD - Belkin F5D7230-4
just type 192.168.2.1 into your browser and it will get you into the settings, just as a cd would but you still have to manually enter your settings with either way of setup.
Sep 06, 2008 | Belkin (F5D7230-4) Router (587009)
UNABLE TO CONNECT TO THE INTERNET THROUGH COMCAST
To setup your router
first check..
Connect Cable modem to the computer using an Ethernet cable without the router installed and make sure that the Internet connection is active. If it is not, contact your Internet Service Provider. If it can go online,
to setup connectionwith router ..
Step 1:
Connect the Cable modem to the router’s WAN or Internet port.
Step 2:
Connect the computer to any available numbered port (1, 2, 3 or 4).
NOTE: In this example, we’ll connect the computer to port number 3.
Step 3:
Make sure the power adapter is plugged to an available power outlet.
Step 4:
check if you are able to go online wired..
if not your router has to be configured first,
you can also try power cycling your network set up,
Press and hold the reset button in your router for 30 sec with a pen or a paper clip with the power cable connected, then disconnect power for your router wait for 30 sec and then reconnect in back, restart your pc waith for all the lights to become stable in your router, then check if you r able to go online..
All the best...
Jul 07, 2008 | NetGear MR814 Wireless Router
Current dlink basic want to use dling DI 514
If you want to use your former router, you just have to connect the previous router in between your modem and computer. Try turning off all the devices (modem, router and computer) for 2 minutes. Then turn on the modem first, wait for the lights to be stable then turn on the router. When the router lights are okay that is the time that you can turn on the computer and check the internet connection.
If the Internet connection still has not come back, you will have to reconfigure it for Comcast connection. You can try using the setup CD or access the setup wizard using 192.168.0.1. User name is admin and leave the password empty then run the wizard.
May 05, 2008 | D-Link DI 514 Wireless Router (DI-514)
HP LaserJet Pro CM1415fnw Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
