Question about GE WJSR2070B Top Load Washer
Washer fills and drains repeatedly
When I start my washer it fills about half way and then drains and then immediately refills so that it is constantly running water but never getting full enough to start washing clothes. Anyone know how to fix this?
  • 247 Answers
Have a look at the routing of your drain hose. It sounds a bit as if: a. The highest point of the hose isn't high enough (you normally want to aim for about 3 feet off the ground) - so that water starts draining from the machine before it is finished filling. and b. There isn't an effective air break or anti-siphon valve where the drain hose goes into the domestic drainage system - so that once the machine starts to drain by itself, it continues until empty. A.
Posted on Jun 07, 2007
  • Alastair Macleod
    Alastair Macleod Jun 07, 2007
    After a moment's further thought, before attempting the above have a listen to the machine while it's misbehaving.
    My earlier recommendation only really applies if you can't hear the drain pump switching on and off in time to the filling and emptying.
    A.
SOURCE:
Washer fills then drains immediately
Motor plug faulty. Remove and check for burnt wires.
Dec 08, 2013 | Zanussi ZWF1430W Front Load Washer
My machine start to fill with water and about half way full the water starts running out juswt as fast as it is going in
Check the drain and see if the drain valve or pump is open due to clogging of dirt. If so back flush the drain and reset the unit , drain pump.
Jun 11, 2012 | GE Clothes Washer Model Select Connector -...
Will not hold water ,when filling it just drains out
I just had this problem also. The reason I was having this problem was that I was letting the draining hose run into my bath tub to drain. Because of this the water was immediately draining out of the washer. So I had to hook the draining hose onto my bathroom sink to drain. By raising the hose higher,the washer filled up with water and worked just fine. Hope this helps.
Jan 24, 2010 | Haier HLP21E Top Load Washer
Washer fills up with water than immediately the water drains to half full. Any idea what causes this?
HI. The drain hose might be too low, thus, creating a siphoning effect. Make sure the drain hose is at least three feet above the floor.This should correct the issue.
Nov 30, 2009 | GE Washing Machines
Washing machine releasing water at wrong time
your drain hose is to low ,,make drain hose go up the height of machine berfoe it can come down,,,sphion effect...onthejob
Jan 14, 2009 | Maytag PAV2300 Top Load Washer
Maytag performa pav2300
Just rehook the clear tube back onto the air dome (back right side of drum), drain any water from the drum, the refill, pressure switch will reset itself. Start to fill on small load size first, then move up when washer starts to be sure it reset all the sizes.
Aug 06, 2008 | Maytag Performa PAV2200
LAV3600AAW Maytag Top Loading Washer
check your house drain make sure it is above water line in tub
Nov 30, 2007 | Maytag SAV5710 Top Load Washer
Running water
Sounds like your stand-pipe has fell over,located behind machine that the drain hose goes into.This pipe must be vertical,and secure.The top of the washers drain hose loop that goes into the stand-pipe, should be as high as your soap dispenser.If this is not the problem then your water pump must be pumping the water out all the time.Can you hear the pump? If so, some faults can force the washing machine into a constant cycle of filling with cold water and pumping the water away if it thinks the washing machine is overheating (possible faulty thermistor).Hopefully its only your stand-pipe causing the loss of water.Lets know how you get on.Good luck.
Sep 05, 2007 | LG WFT1071TP Top Load Washer
Tub will not fill with water
That's Great Man. Thank you for letting us know!
Apr 29, 2006 | Kenmore 23822 Top Load Washer
GE WJSR2070B Top Load Washer Logo
288 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
