New denon m37 won't play cd's
Denon rcd-37,won't play cd's,"00tr00:00" appears on screen.
5 Suggested Answers
lock123
  • 6831 Answers
SOURCE: Will not read CD or
Hello
OK, this is a very common problem regarding any CD/DVD players. The problem is that the laser lens of the unit is either "Dirty" or burnt out.
You can try to cleaning the laser lens using a ear-bud and some surgical spirits. Do this by dipping the ear-bud into the surgical spirits and gently wiping over the lens. If this sounds a bit to complicated, you will be able to buy a laser lens cleaner cd at your nearest computer store for under $5.
Please feel free to let me know of you have any questions.
Kind regards
Andrea
Posted on Dec 08, 2010
dunnbiker
  • 8546 Answers
SOURCE: My Denon M37 just cut out whilst playing a CD -
ONLY while playing a CD, or is excess volume at play, too? What about FM?
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Feb 06, 2011
dunnbiker
  • 8546 Answers
SOURCE: what type of sub-woofer can
Free or you can tempt us with $$. Your choice.
Register and download the manual for free at audio.manualsonline.com
http://audio.manualsonline.com/manuals/mfg/denon/rcdm37.html
Self-powered would work but it would have to run on full-range amplifier (from the speaker posts) or Line Level signal (from the OUT RCA jacks) because this unit has no Sub-specific output. It's no bigge as the sub would naturally discard the higher frequencies via its own amp's and speaker
Posted on Feb 22, 2011
dunnbiker
  • 8546 Answers
SOURCE: Denon RCD-M37 turns on when
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it '*****'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Aug 04, 2011
My denon rcd-m35dab, there is disc in and plays ok but cannot open the drawer it just shuts down/turns itself off
Check the belt or drive that is responsible for opening up the disk tray. If it is slipping the disk will not come out.
Mar 07, 2015 | Denon Audio Players & Recorders
Tip
Denon VPROT Problem.
I posted a question regarding a Denon RCD-M37 DAB, which after a repair to the sub power supply transformer, came up with VPROT after a few mins use. After very careful measurements I found that the -12Volt line coming from the power regulator board situated behind the mains transformer was measured at 10.5Volts. It is necessary to replace the LM7912 regulator. Whilst with this board out check soldering and all other components. Normal operation has now been restored. I hope this will help regards Paul R.
on May 08, 2015 | Denon Audio Players & Recorders
Hi can you tell me that impedence on JBL TLx4 speakers- i need to know if they are compatible with my denon RCD M37 dab player thanks
hi,
Is it JBL TLX 420 then its impedance is 4OHMS. You cant connect these speakers to denon rcd m 37, because its output impedence is 6 to 16 ohms.
ok
Jul 04, 2011 | JBL PSW-D110 Speaker
What type of sub-woofer can i add to my denon rcd-m37 system? (passive or powered). Is this information free or not.
Feb 22, 2011 | Audio Players & Recorders
My Denon M37 just cut out whilst playing a CD - what is wrong? When I switch the power off, then on again, it says Please wait........ then phases out again.
Feb 06, 2011 | Denon Audio Players & Recorders
In just brought a denon m37 dab. but it will not play a new cd i brought to play in it. the cd is Believe by Katherine jenkins
Hi, I have had exactly the same problem, I have tried three different M37DABs and three Believe CDs by Katherine Jenkins. Unfortunately I dont have a solution, but thought Id let you know its not just your CD player. I hope this can be resolved. Let me know if you ever resolve this problem. Thanks
Nov 22, 2009 | Audio Players & Recorders
Sony RCD-W500-c CDR Recorder
my cd recorder laser head is bad trying to find a place to send it for repairs.
Jul 13, 2008 | Sony RCD-W500C 5-Disc CD Recorder
I have a Denon RCD M33. It will turn on no problem but as soon as I press the eject button so that I can insert a CD it turns itself off.
I had to press all the eject, play and stop buttons simultaneously whilst at the same time pressing the on button.
Apr 11, 2008 | Denon Audio Players & Recorders
130 people viewed this question
 Grubhead
Grubhead
