Question about Aube Technologies Hardware & Accessories
Aub digital themostat th 232-af instruction manual
2 Suggested Answers
SOURCE: Is there an easy to understand user manual for the
http://www.uheat.co.uk/aube_th132_underfloor_heating_thermostat.htm
TH132 is a thermostat for under-floor heating
Go to the website above and download on-line copy of your manual
On-line manual let you read bigger print & lets you break down the steps easier
I am sure by the time this answer reaches you, the problem will be solved
This is true because manuals are frustrating, until you tell somebody it can't be figured out >> which gives you time to rest >> after which the manual makes sense.
BUT I am frequently wrong, and you may be at a standstill
A quick look at the manual.
You can also select which part of the manual is giving you a problem and then I will help you through that specific difficulty
Wiring: I guess the instructions at bottom of manual apply to your model
Your 240Volt hot wires from breaker box connect to terminals 1 & 5
Your two wires supplying power to heat connect to 2 & 4
Pilot wire to terminal 3
Floor sensor to 6 or 7 >> wire from sensor can connect to either pole
The TH132 has two sensors, 1 located inside the TH132, the other sensor located in floor
Set up:
The first part describes 10 buttons (right away you know this is complicated)
There is a brief description of both sensors
Step 1 shows how to configure the start and temp-display switches
Step 2 covers installation of module on base
I guess you hook up power at this point because the display is supposed to light up
This implies that the bottom part of manual should be located more towards the top, and the power-up directive seems to be missing. Bad manual.
Step 2 shows what the display looks like with first power-up
Step 3 tells how to set current time and day.
Step 4 adjust temp setpoints >> floor temp is pre-programmed to 82 degrees
Step 4 shows that you press-and-hold the sunshine or moon button to have it display
The sunshine button is the upper temp setting, the moon is the lower temp setting
Step 5 is operating mode > choose automatic for programming to operate
Step 6 is programming, which carries on with about 24 steps
If this is your problem area, let me know
Now the manual suggests you make a chart of your programs
Other programmable devices don't work when there is a conflict in programming
Wow I see the TH132 is 'equipped with a proportional adaptive controller..' that carries a two year warranty. I'm sure you'll rest easy knowing that.
Reply back with the specific trouble area, and we'll get it going for you.
Posted on Oct 22, 2010
Aube th132 problems
You can reset the programming of the comfort setting and make sure that it did not get set at 14C. Here is the manual that shows how to do that.
http://www.aubetech.com/manuel/2/TH132-A-F-AF-230.pdf
Sep 19, 2013 | Hardware & Accessories
How do I find the instruction manual for the Aube by Honeywell TI033/U 7-Day Programmable Timer Switch
Open following links to identify Honeywell Aube timer and download manual for T1033:
http://waterheatertimer.org/pdf/Aube-TI033.pdf
http://waterheatertimer.org/Aube-timers-and-manuals.html
Add a comment if T1033U is different from T1033, and describe differences for possible help.
Take a moment and rate answer for accuracy:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Oct 01, 2011 | Hardware & Accessories
I need the instruction manual for Aube by Honeywell TI033/U 7-Day Programmable Timer Switch
Where can I buy the Aube 7-Day Programmable 40-500w timer
You might be looking for T-1032 or T-1034 500watt timer
Identify model number on following link, and then google-search that specific model.
Link to instruction manual appears for each timer.
Honeywell Aube in-wall timers can be used for single-pole or 3-way applications.
Look at instruction manual carefully for 3-way wiring.
Timer can be used for incandescent, halogen and CFL with minimum wattage requirement.
Since Aube timers have internal battery, they cannot be exposed to freezing temperatures or high temperatures.
Sep 28, 2011 | Aube Technologies Aube 7-Day Programmable...
Where can we purchase Aube 7-Day Programmable 40-500w Light Timer Switch
I need instructions for programming Aube TI032-3W/U 7-Day Programmable Timer Switch, White
Open following links to identify timer and download manual:
http://waterheatertimer.org/Aube-T1032-timer.pdf
Honeywell Aube T1032 is made for single-pole or 3-way applications, and works for all types of lighting up to 500Watts.
Timer has internal battery and cannot be exposed to freezing temperatures or extreme hot temperatures.
Sep 28, 2011 | Intermatic HB88RC - 7-Day Programmable...
Lost programming instructions and need to program timer. Can you email the instructions to me? Aube T1032-3W. Timer is installed, just need programming instructions.
Open following link to identify timer and download manual
http://waterheatertimer.org/Aube-timers.html
Add a comment for more help
Upvote the help.
Jun 06, 2011 | Aube Technologies Aube 7-Day Programmable...
Can i have programming instructions?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://www.aubetech.com/products/list.php?noLangue=2&noFamille=5&app=13
Links above shows 10 different Aube models
Select your model, click link next to your model, next page has instruction manuals at bottom of page
Each model has different instructions
4 models are 7-day timers
4 models are sunrise-sunset timers
2 models are combo sunrise-sunset
There are 2 exterior box-type timers with choice of sunrise-sunset or 7 day, depending on model
The instructions vary by model
Let us know if you have problems with specific instructions
Oct 19, 2010 | Aube Technologies Aube 7-Day Programmable...
Need Aube by Honeywell TI032-3W-5/U instructions
http://waterheatertimer.org/pdf/Aube-TI032.pdf
Manual for Aube T1032
Internal rechargeable battery
7 day programmable timer for halogen, incandescent, florescent
Aube T1032 has 40 Watt mim & 500 Watt maximum (5- 100 watt incandescent bulbs etc)
Buy Aube-1033 for heavy 20Amp 2400 Watt maximum
Replaces single-pole switch or 3-way switch (slight modification needed in 2nd 3-way switch)
Buttons
Oct 12, 2010 | Honeywell Aube by TI0323W5U 7Day...
I lost the instructions for my Aube origrammable
Open following link to identify timer and download manual:
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
Mar 15, 2010 | Aube Technologies Aube 7-Day Programmable...
Hardware & Accessories Logo
154 people viewed this question
Top Aube Technologies Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you an Aube Technologies Hardware and Accessory Expert? Answer questions, earn points and help others
