Question about Miele Washing Machines
Miele honeycombe w1716 waterproof fault
Shows "waterproof fault" in display
ginko
  • 19396 Answers
SOURCE: MIele waterproof system reacted
That means that there is a leak that passed throught the waterproof system, and the water protection system had reacted putting the machine on error mode, as the water can damage electric parts, and cause serious hazard.
Sometimes you can reset the error by unplugging power cord, however you should call immediately a technician, as using the appliance when there is a problem with the waterproof system, you can be seriously injured by electric shock.
Operating instructions for Washing machine W 3923 WPS
Posted on Nov 16, 2008
  • 177 Answers
SOURCE: my miele touchtronic w 3039
Sounds like you may have flooded the base of the unit and activated the float switch. Tip the unit forward slightly with a towel at the base and all the water will pour out. You should be right to run the unit after that and any other water inside will dry up. it won't rust as it is stainless steel inside.
You may just have over sudded the unit by using the wrong detergent or too much. After you have the unit running again test the unit with no detergent and see if you activate the waterproof system again. if you do then you will probably have a split hose inside the unit.
Posted on Mar 02, 2010
  • 91 Answers
SOURCE: why dose the water leak out from the Miele
Hi dear.Please check the door gasket for any wear & tear.(Also open the door,ajar inside the door gasket, check inside of it for any fine tear or cut.)Please check for pump filter.Is it attached correctly.I hope that helps.Thanks.
Posted on Sep 02, 2010
jyackle5
  • 8197 Answers
SOURCE: need manual for Miele Honeycomb
You can get the manual on the link below.
http://www.miele.com.au/au/domestic/service/aftersales_operatinginstructions.aspx?product_type=W%203831%20WPS
Good Luck please rate 4 thumbs up and please leave a testimonial
Posted on Oct 24, 2010
SOURCE: Miele W 1712 is giving
I just received this error message on my Miele W 1712 (Waterproof Fault). Prior to this I had an error message regarding the Drain outlet, so I opened the drain outlet and cleaned it. I think I might have opened it too quickly and therefore creating the (Waterproof Fault). The problem is that when you open the drain outlet too quickly the water runs into the bottom of the washing machine where some sensor lies and you get the (Waterproof Fault) error message on the display and not even turning off the machine will do anything to get rid of this annoying message.
1. Turn off the machine
2. Unplug it
3. Open the drain outlet and take out the plug.
4. Dry all the visible water with a cotton cloth.
5. Tilt the machine FORWARD and hold it until you see water gushing from underneath the machine.
6. Repeat this until you see no more water.
7. Plug the machine back inn.
8 VOILA no error message! I hope in your case :)
Posted on Feb 15, 2011
Miele w1712 did not work...the machine was buzzer and when i saw it, it said waterproof fault
Hi dear,
There is a internal leak on your machine. You need to contact Miele to assist you. Thanks.
Jan 05, 2016 | Miele Washing Machines
Display shows 'fault waterproof'. what is wrong?
I have been trouble shooting my own Miele issue and may have found your answer, which seems to be easily fixed. Apparently one can reset the water fault sensor by tipping the machine forward at 45 degrees. If water comes out the bottom pan, then you will have reset the sensor. You should check for leaks especially in the door gasket. However if it comes on again, you probably have a leak that you need to address.
Aug 31, 2015 | Miele W5877 Edition 111 Washing Machine,...
It is displaying the message and beeping at me waterproof fault
Put a towel down in front of machine. Tilt machine forward. Water should run off the sensor plate and fix this problem.
Jun 20, 2015 | Miele Novotronic Premier 500 Front Load...
Miele honeycomb care w 1712 drain fault comes on every wash
see this possibles causes:
God bless you
attached diagrams
t spins, but doesn't pump
see line clogged and fix it.
It doesn't spin or pump
frozen pulley
It pumps, but the water returns
improve the drain laundry, if drain hose reaches more 4 inch cut off the excess
May 16, 2012 | Miele Washing Machines
Miele W 1712 is giving a waterproof fault. I tried to switch the machine of and on but the alarm is still going - I am also not able to open the door. Regards Peter
2. Unplug it
Jan 04, 2011 | Washing Machines
Miele w3725 front loader. message on screen "waterproof fault"
For our model Alemnesh's suggestions were spot-on. It's hard to believe that a machine with such a good reputation would (a) allow this fault to occur so easily and (b) not have its own manual provide explicit guidance as to how to fix it.
Oct 03, 2010 | Miele Washing Machines
My miele touchtronic w 3039 will not start. the waterproof system activated keeps blinking in the display window with the start button blinking as well and beeping
Feb 16, 2010 | Miele W2203 Front Load Washer
My Miele Touchtronic W1119 shows the error message Drain/Intake Fault. The intake and filters are fine. What's going on?There is no water standing in the drum. How can I reset this?
Hello Buvamo,
You may want to check the water valve and make sure it is all the way up where the intake line is.
The other area to check for water not draining is the lint trap. While the intake/drain fault is on the door will not open for the lint trap.
There is a release lever at the bottom of the machine (Orange in color) that is below and behind the trap door. Just pull down on the lever and that will open the trap door. You may want to put a towel under there as it will leak once the door is opened. inspect and clean the trap and try running cycle again
Sep 13, 2009 | Miele Touchtronic W1119 Large Capacity...
Waterproof fault
I just received this error message on my Miele WPS 4146 (Waterproof Fault) Prior to this I had an error message regarding the Drain outlet, so I opened the drain outlet and cleaned it. I think I might have opened it too quickly and therefore creating the (Waterproof Fault). The problem is that when you open the drain outlet too quickly the water runs into the bottom of the washing machine where some sensor lies and you get the (Waterproof Fault) error message on the display and not even turning off the machine will do anything to get rid of this annoying message.
So here is the fix that worked for me.
2. Unplug it
Jun 19, 2008 | Miele Washing Machines
Washing Machines Logo
83 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
