Set the tone mode tel / fax panasonic KX-FT907CX
SOURCE: panasonic fax kx fp342 regarding
my fax do not send paper but it's reciver and copy it .
what solution ?
Posted on Apr 25, 2008
  • 87 Answers
SOURCE: KX-FT67 new settings
just errase all msgs or off it from settings .just off answering machine.by mian jee
Posted on Dec 16, 2008
SOURCE: PANASONIC KX-FM386CX DRIVER NEEDED
Kindly help me to down load install this machine
P K Kutty
Posted on Apr 01, 2009
  • 22 Answers
SOURCE: Panasonic KX-FL512 fax drum life error
You need to follow the instructions that came with the drum as you need to reset the internal counter.
Posted on Dec 07, 2009
SOURCE: panasonic fax model KX-FT981
the machine showing memory full . how clean memory
Posted on Feb 13, 2011
HOW TO USE TELEPHONE AND FAX PANASONIC KX FT72?
check cable & junction box connection thoroughly
Jan 22, 2015 | Panasonic Office Equipment & Supplies
How to continue using device as answering machine but route fax to new HP all in one
hook the answering machine after the fax and set the fax to answer after 4 rings and the machine after 5.
This option should be somewhere within the menu of the HP
Let me know if you can't find it
May 22, 2008 | Panasonic KX-FPG391 Plain Paper Thermal...
Selecting dialing mode
The directions for changing the dialing mode from tone to pulse can be found in the owner's manual for the main base unit.
Press the [MENU] button then choose "Set tel line". Then choose "Set dial mode", then choose Pulse or Tone and press [OK].
Additional details can be found in the below link.
http://service.us.panasonic.com/OPERMANPDF/KXTG1031.PDF#page=14
Jun 28, 2014 | Panasonic KX-TGA101S Cordless Handset
I have a panasonic KX-TGA101s somehow it is switched to pulse, I cant figure out how to switch it back to tone?
press menu
press down key arrow until "Set tel line"
press menu for OK
press menu again for "Dial mode"
Select "Tone"
Raja Thurairajah from Canada
Nov 27, 2010 | Panasonic Lands Phones
Cant change the nite mode to a day mode
On the phone press PROGRAM, press the original DAY button, dial the number 2, dial 781#, press AUTO DIAL STORE, pick up and drop the handpiece.
May 21, 2010 | Panasonic KX-T7730 Corded Phone
How can I turn off the auto answer feature of the pansonic kx fh332. I never want it to pick up and go to fax mode.
Set the fax machine to Telephone mode by pressing
{RECEIVE MODE} until TEL MODE is
displayed.
You might also want to dowload the Operating Instructions for you fax machine: KX-FHD332 Operating Instructions (English) (17208 kb)
Aug 03, 2009 | Panasonic KX-FHD332 Plain Paper Thermal...
Need to change phone back to tone dialing
Here's what the manual says: Changing the Dial Mode (Tone or Pulse Dialing) (HS1 only) Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most phone networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, follow the steps below to modify your phone?s settings: With the phone in standby, press and hold [cid/menu]. Press [vol/ / ] to move the pointer to select DIAL. Press [select/channel] to set the phone to pulse dialing. Press [end]. Return the handset to the base. The handset communicates the new setting to the base, and the base activates the setting on any other handsets. Hope this helps out. K
Jun 05, 2009 | Uniden 2.4 GHz Cordless Phone System
Panasonic KX-FP101 will not copy
theres a handset problem in your unit. try to lift up the handset and firmly set it back to its cradle.if after doing this the tel sign disappears, then you can proceed with the copy otherwise the hook switch of your fax machine has a problem.
Mar 09, 2009 | Panasonic KX-FP101 Plain Paper Thermal Fax
Change pulse into tone
Go to the menu and choose Tel line and the go to set dial mode and then choose the dial mode like dial or pulse mode
Nov 22, 2008 | Panasonic KX-TG2631 Cordless Phone
k24674
jasbo
jasbo
