Question about Neff Ovens
Can the 1031-1 circotherm oven be connected to a 30 amp ring main or does it require a 30amp cooker circuit
The existing oven has been connected to the 30amp ring main without any control switch
kibonghe
  • 25 Answers
SOURCE: Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
Posted on Feb 04, 2009
barkencoa
  • 3463 Answers
SOURCE: hi.i have a hotpoint creda c362e cooker the rings
Hi.
Frpm the sympton's you list, I would say that the main oven element has failed, espsecially if the fan is working o/k.
The element is located at the rear of the oven compartment behind a removeable cover.
In addition to the grill elements in the top oven compartment, there is an additional base element which you can't see.
If you turn the top oven on, the base of the compartment should get hot, if it does not, then the base element has probably failed.
Hope this helps.
Posted on Jan 09, 2010
apart4u
  • 213 Answers
SOURCE: neff circotherm doudle oven main oven fan working
For all Free appliance repair videos visit our VIDEOTUTORIALS1, If the fan motor in the back of the oven is going round and thetemperature light is on (normally little red light), but there is no heat thenyou will probably need a new oven element, these are generally very easy to fitand readily available from our website these can be tested with a electricmeter.
To gain access to the NEFF element you willhave to remove the back plate from inside the oven. Once removed you will seethe fan and element, if youlook closely at the element you willprobably see a small hole burnt in it where it has blown. Sometimes howeverthere is no evidence of a fault but the element is open circuit ie:broken inside the element casing, either way it will need replacing. Some elementswill are fixed from inside the oven and some are held in place by nuts from therear of the machine.
2, If your NEFF fanoven is getting warm but takes a very long time to cook or is burning the foodmore on one side than the other, then you need to check if your oven fan motor is working you willsee the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then youneed To replace the oven fan motor is a little moreexpensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heatingand burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: noheat and no fan then the chances are that someone has put the oven timer into AUTO mode,simply put oven back to MANUAL mode and all should be working again.
Posted on Jan 12, 2010
SOURCE: Oven not heating
blue waffle is nice and i like to pop fish up my **** go to google and type in lol fish and then click im feeling lucky and do the same with blue waffle xx good look it could help your oven.
Posted on Mar 31, 2010
mreid542
  • 166 Answers
SOURCE: 1984 stove, fuses located on the top of stove/ 30amp keeps blowin
It sounds like the element has a short in it. unplug the range, and take the element out and inspect if for burn marks. check the wires going to the element to make sure they have not shorted.
Posted on Jul 01, 2010
What size circuit breaker for rbs305pr oven?
If you're connected to a 240V source, a two-pole 40 amp circuit is required. If connected to a 208V source, a two pole 30 amp circuit is required.
But the limiting factor here will be the wire size. If installed with #10 copper wire, 30 amp will be maximum. If a #8 copper (or #6 aluminum) 40 amp is maximum. See the link below for details.
http://www.whirlpool.com/digitalassets/GBS307PRB/Dimension%20Guide_EN.pdf
Sep 24, 2015 | Ovens
Neff 1031 2
The heating element(s) may have shorted.
Apr 13, 2017 | Ovens
Electrical output requirement for a buit-in oven and cooktop
Providing the existing switch outlet iscontrolled by a 30amp circuit fuse or trip, then there is no problem connecting the 2 appliances to the same switch.
If on the other hand, it is controlled by a 13 amp breaker, then you cannot connect both appliances to this, you would have to use 2 seperate sockets.
Hope this clarifys your question.
Mar 07, 2010 | Whirlpool RBS275PD Electric Single Oven
Does a moffat oven need a 30amp cooker socket or is it ok on a 13amp plug
Unless your talking about one of those tiny, table top ovens, dont use a 13 amp socket / connection.
An electric oven must be connected via a 30 amp SUPPLY - the socket is just the connector at the end of the cable that runs from the fuse / breaker board. A 30 amp supply will use a much thicker cable capable of handing the higher currents.
Whilst a very basic oven may draw less than 13 amps current when operating in some modes, most will draw well in excess of this depending on what facilities they have, e.g. bake and grill at the same time, or maybe a combi-oven - one that can bake and microwave at the same time.
Oct 03, 2009 | Ovens
Apart from the main supply to the cooker terminals
So long as the earth is connected to the earth terminal, then there is no prob for you to worry about.
The normal twin and earth cable is adequate.
Please rate my comments.
Thankyou..
Mar 05, 2009 | Neff U1661 Double circotherm super...
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
Installing a B1641 oven
Providing it is just a single fan oven on it's own. then it will work fine from a normal 13 amp socket.
If it is a double oven, then it will have to be hard wired into a cooker control switch box, protected with a 30amp circuit trip or fuse.
Please rate my solution to your query.
Thanks.
Feb 19, 2009 | Neff B1641 Single circotherm super...
Zanussi Electric Cooker and Hob don't work properly
it will have nothing to do with the supply, although it does sound as though he could have done a better job. if the appliances are brand new get Zanussi out to it. shame on the guy for not checking that they worked as they should. hope this helps.
Feb 17, 2009 | Zanussi ZHQ575 Electric Double Oven
What connection do you require for eye level electric double oven
You need a 45amp circuit for this double oven, under no circumstances , try to run it off a 13 amp circuit.
Plz rate my solution.
Thankyou.
Jan 25, 2009 | Neff U1421 Double circotherm Electric Oven
After effects of blown fan oven element on U1721
I think there is an inline fuse for each oven/element.
May 04, 2017 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
Top Neff Ovens Experts
ashburton
Samyfam
Samyfam
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
