Update for vizio VBR120A blu ray player - Televison & Video
5 Suggested Answers
  • 45 Answers
SOURCE: firmware update
Here's the link to the newest firmware.
http://tinyurl.com/54a9wo
Posted on Jun 15, 2008
SOURCE: Blu-Ray player not reading Blu-Ray movie
I had the same problem - Fix - Go to the sharp web site and download the file HP21U_HP50U_PN902270. You will need to make sure your thumb drive is no bigger than 4gb and you do not have any other files on it. Once you download the file on the thumb drive, you will need to unzip the file on the same thumb drive. The zip file is one of the new ones, so you might need to go to the web and get a shareware program that will open it. After this - turn your player on and go to setting, next scroll down to update firmware, insert the drive and tell it OK, it will ask you if this is OK, tell it OK and it will upgrade the firmware in about 2 min. I have already done this with 3 other players with no problem. Good luck. The sharp web site is sometimes a little hard to find and to me was not the most user friendly. good luck Pruitt43@yahoo.com
Posted on Mar 31, 2009
  • 3 Answers
SOURCE: My Sharp Aquos Blu Ray player cannot play my blue ray disc.
goto sharpusa.com and put in your model number. download the update to flashdrive and the update your blu ray..and it will then play
Posted on Apr 24, 2010
dss902
  • 16 Answers
SOURCE: I have a Vizio VBR120
The default IP mode is set to Dynamic, which means your player will automatically detect and use
your network settings after you connect your Ethernet cable, but you can manually change these
settings if you are an advanced user and are comfortable with networks.
1. Turn on your player and your TV. If a DVD is not in the disc tray, the Home menu will be
displayed. If a DVD is in the disc tray, press SETUP to display the Home menu.
2. Connect one end of an Ethernet cable (not included) to the Ethernet port on your player
3. Connect the other end of the Ethernet cable to your home network (usually your router
home network must have broadband Internet access such as cable or DSL.
4. Press to select Settings, and then press SELECT.
5. Press to select Network, and then press SELECT.
6. Press ^ or down to select Wired and then press SELECT.
7. Press to change IP Mode to Manual and then press SELECT.
8. Manually change your network settings such as IP Address, Subnet Mask, Default
Gateway, the Primary DNS, and Secondary DNS.
9. Press ^ or down to select Apply and then press SELECT.
Note: If you need additional help setting up your network, please refer to the user manual for your
router or contact the manufacturer of either your router or your Internet service provider if they
provided the router for you.
Your ip settings will look something like this 192.168.2.1
You might be able to find you setting by going to Network Connections -> 2x click on Local Area Connection -> then click on the support tab.
Posted on Mar 05, 2011
My vizio blu ray player will play discs that i burn but no store bought discs dvd or blu ray
Sounds like it may need a software update. Quite common for dvd players. ring or contact where you bought it from or manufacturer and ask for instructions and obtaining files to update your player
Feb 22, 2014 | Vizio VBR220 Blu-Ray Player
Adding amazon app to blu-ray player
Unfortunately, no. All the apps that are on any Blu-Ray are added or removed by the manufacturer. In your case, Netflix pays Vizio to put their app on there. I've seen apps removed and added from players during updates. So unless Amazon and Vizio make some sort of an agreement, that player will never be able to access anymore than what was loaded on it when you bought it.
Jan 20, 2014 | Vizio VBR220 Blu-Ray Player
Vizio blu ray player vbr334 unable to update
you can unplug your wireless adapter for about 5 minutes if that doesnt work you should be able to reset the whole system
Jan 04, 2014 | Vizio Vbr334 3d Blu-ray Player With Wifi,...
Vbr120 firmware updates
The best advice I have to offer for the Vizio VBR120 is to replace it with a better player from LG, Sony or Samsung. I replaced mine with a LG BR540 and haven't looked back. With Vizio you get what you pay for, junk. There is no update for a Vizio VBR120.
Feb 09, 2013 | Vizio VBR120 Player
Firmware update for vizio vbr333
Found out there isn't any update available and there never will be. My suggestion is get rid of the player and NEVER buy Vizio again. While you're at it tell all your friends and family not to buy Vizio either. I know I'll never buy another Vizio device and never recommend them to fri
Sep 30, 2012 | Vizio 3D Blu-ray player VBR333
My blu-ray player is only playing dvd instead of blu-rays i have updated my player but still not playing blu-rays disc at all
First confirm that the firmware update that you used is in fact for that very model.
Then check the region code for the discs in question.
Try the update again.
Sep 04, 2011 | Vizio VBR210 Blu-Ray Player
I have a vizio blu-ray player vbr120a. I can't seem to see or setup the wireless capability with the player. does it exist? no instructions in the box, but downloaded the manual. thank you
The VBR120 has no native wireless capacity; it only has wired ethernet built in.
I do not see the VBR120A anywhere on the Vizio Site.
I wish that I had better news for you.
Aug 08, 2011 | Televison & Video
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
