Question about Compaq Presario 5000 PC Desktop
Have compaq s5000nx that needs a cooling fan. fan was missing and I don't know where to plug in small lead to board.
    Problem Solver:
  • 9 Answers
On mine it is at the very bottom of the motherboard under my PCI ports
[IMG]http://i270.photobucket.com/albums/jj105/Ugly-Wan/helppic1.jpg[/IMG]
[IMG]http://i270.photobucket.com/albums/jj105/Ugly-Wan/helppic2.jpg[/IMG]
P.S
If you bought a computer without a fan take it back
Posted on Jan 11, 2009
    Problem Solver:
  • 13 Answers
Well theres always at least 2 plugins for a fan ussualy its located near the cpu and the other one near where the power supply plugs in theyre both white with 3 prongs and the the lead when inserted clicks in and it only fits in those 2 spots .prosses of elimination.and if u look with a magnafying glass and a flsh light it should be written on the board beside it fan or cpu fan both are good to go. good luck.
Won't start but CPU fan vibrates but will not go full blast. Intermittant
It appears you have a faulty CPU fan and it is causing the CPU to overheat and shut down.
I suggest you replace the CPU fan. remove any dust from the heatsink and put new heatsink compound on the CPU/heatsink.
May 06, 2012 | Compaq Presario S5000NX PC Desktop
I have a compaq s5000nx that keeps shutting down and restaring after 20 min have not done any thing to it
Open the case and blow any dust out of the heatsink (under the cpu fan). Overheating is the main cause of sudden shutdowns. You may also want to apply fresh thermal paste between the cpu and heatsink. Please let me know if this helps or not.
-Joe
Apr 17, 2012 | Compaq Presario S5000NX PC Desktop
I havemy s5000nx keeps shutting down and restarting after 20 minutes what could be the problem
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU make sure its securely seated and has thermal grease might be getting to hot
another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit
hope this helps you
How do I open my pc to add a board
Hi You can see some screws on the back side of cpu remove 2 screws on right side from back then you can pull the cover from it. After removing cover you can see motherboard installed there if you want to install new motherboard remove all screws from motherboard and disconnect all connection from motherboard then put new board then install processor and it's fan connection all connection. Then you can use computer with new board. Let me know if you need further assistance. Thanks for using FixYa.
Aug 29, 2010 | Compaq Presario S5000NX PC Desktop
I have a Compaq Presario S5000NX Desktop Computer and i need the original drivers and software for this computer i installed windows xp home edition from a dell cd and now i need the correct drivers and...
Here is the Compaq site with the XP drivers. Just check and make sure that this is your model.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=359576
Oct 13, 2009 | Compaq Presario S5000NX PC Desktop
Compaq s5000nx does not boot up. Blank screen. No
Here and here are a couple of links from HP that may help. And here's a great article for troubleshooting startup problems in general. Also helpful may be links at this site.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 11, 2009 | Compaq Presario S5000NX PC Desktop
Cd burner
it could be conflicting with the harddrive. If the hardrive is set to master then set the cd drive back to slave and try again.
Oct 25, 2008 | Compaq Presario S5000NX PC Desktop
Dell Inspiron 8100 laptop cooling fans
All fans for cooling cpu plug into a small 2 or 3 pin socket usually white on the motherboard near to the heatsink your fan should have the lead coming from it
fans for video card sometimes takes the power from card or connect to board same as cpu fan but near video card
Aug 08, 2008 | Dell (6F858) Cooling Fan
Compaq Presario 5000 PC Desktop Logo
59 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
