Question about Westinghouse Refrigerators
Fridge not working, freezer is.westinghouse BJ425S
Fridge has stopped cooling but freezer is still working? power is still working on fridge
SOURCE: Fridge stopped cooling
We had the same problem today and it was because I had not closed the freezer completely a week ago and the evaporator coil in freezer was completely iced up. A blow dryer defrosted the coil quickly. It is best to empty the freezer first and shut fridge off. You need to defrost the coil enough so air will flow through the coil. To cool the fridge cold air is drawn from this coil by an evaporator fan located above this coil behind the removable cover at rear of freezer. IF you remove this cover and this fan is turning check for ice on coil. That is probably the problem. Evap. fan is about $100 - ouch. The other thing you can check is the fridge damper control at top rear of fridge. This failed on us 13 months after we bought fridge so no warrenty. Part was $44 plus service of $100. Now I fix this fridge myself. If you remove damper cover you can cycle thermostat and see it open and close. If it is not opening replace it. You can probably find the part cheaper that $44 at an apliance parts store.
Posted on May 19, 2007
woodchuck789
  • 4070 Answers
SOURCE: zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Posted on Aug 24, 2009
SOURCE: westinghouse silhouette frost free 522 fridge is
The heating element, located behind the back plate of the freezer, is probably not working. A failed heating element leads to a build up of ice around the evaporator coils in the rear of the freezer. If the back plate of the freezer is removed (ONLY DO THIS WITH THE APPLIANCE UNPLUGGED FROM THE POWER SUPPLY) and there is a large build up of ice around the evaporator coils then it's a fairly good indication that the heating element is not working. The heating element comes on periodically to defrost/de-ice the evaporator coils. Heating element is often activated by a small timer switch which turns the heater on for a set time every 24 hrs or so. Heating element may be open circuit or timer switch may not be operating. Most likely to be open circuit heating element.
Posted on Jan 01, 2010
SOURCE: Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Posted on Feb 20, 2010
  • 670 Answers
SOURCE: I have a Westinghouse frostfree
I am not sure if your freezer is working correctly if the fridge compartment is not at the right temperature. The way refrigerators work is that the fridge compartment is indirectly cooled by the freezer. The evaporator coils that cool the freezer, also cool the refrigerator. There is a fan in the freezer section that draws air from the refrigerator and blow them over the coils. The vent to the refrigerator could be blocked by debris or ice build up if the defrost circuit has failed. In order to check, you need to remove the back panel from the freezer section to check the condition of the coils/vent. Also check the fan in the freezer and see if it is operating. If the coil is encased in ice, then the defrost circuit has failed and that needs to be fixed otherwise the freezer will not cool to the correct temperature.
The way the defrost circuit worksis that normally the compressor has power for 8 hours, then the timer cuts power off and sends power to the defrost heater for about 45 minutes. The heater is attached to the coil and warms up the coil to melt the ice. When the coil reaches about 40 deg F, the thermostat which is in series with the heater, opens up cutting off power to the heater. This prevents the freezer from getting too hot. After the 45 minutes are up, the timer switches the power back to the compressor again to restart the 8 hour cooling cycle.
Any of the three components can fail causing you not to get the defrost cycle to work. Typically the timer stops advancing so you either stay in permanent cooling or defrost mode. Or the heater burns out so it can
Posted on Mar 13, 2011
Testimonial: "didnt know where to start at first, but this was enough info to help me out and fix the fridge. thanks."
Looking for user manual for Westinghouse Fridge/freezer BJ425S-R
I found some online
http://www.manualsonline.com/support/westinghouse/refrigerator/manual-5078270
Sep 28, 2017 | Westinghouse Refrigerators
Westinghouse virtuoso the alarm keeps going off fridge not cooling freezer is not freezing. Help!
Try adding refrigerant or freon. The Alarm just warns you that it's not cooling or freezing and your food is thawing out. Check the fan if you hear the fan running it should be the coolant needs to be put in it. Or it could possibly be both.
Apr 26, 2017 | Angelo Brothers Westinghouse (r) Savona ES...
Ihave a Westinghouse BJ434V-R and the bottom freezer is working perfectly, but the top fridge just stopped cooling, is this a thermostat problem if so howis it replaced, Alan
Is the fridge part a separate system? More likely a fan stopped blowing cold air through from the freezer section. If Separate, Thermostat knob prises off end and you will see where wires and sensing phial are located.
May 19, 2012 | Westinghouse Refrigerators
Westinghouse virtuoso fridge freezer on top has stopped cooling frreezer alarm goes off every now and then. have defrosted freezer as suggested. freezer still not cooling.
you have a piece of electronic installed in the cooling freezer it must be the problem if there is nothing so it will be from the behind side you must change it
Oct 13, 2010 | Westinghouse Refrigerators
Not cooling or freezing
bimetal switch not working. change it.
Aug 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Westinghouse virtuoso fridge/freezer has stopped cooling. How do we check the fuses etc? seals on the doors are all fine.
I have the same fridge (stainless steel virtuoso) and when the fridge section stops cooling you have to turn power off. Then remove everything from the freezer including the shelf. Next get a pointy object and remove the two plastic screw covers located on the back inside plastic freezer panel, Next remove the two phillips head screws securing the panel in place. Next (and this is a little tricky) get two solid forks and lever the back interior panel off, thereby exposing the cooling system of the fridge. Next get a hairdryer and completely defrost this item, and then reassemble. Switch power back on and your fridge will be fixed, and cooling like a champion! plus you have saved hundreds by not paying ripoff "technicians" I have to do this every six or seven weeks because of the high humidity here in Darwin, the freezer is "frost free" but the cooling system still ices up, and this is what blocks airflow and stops the fridge cooling.
Aug 03, 2008 | Refrigerators
Westinghouse Fridge problem
-Try defrosting the unit. (force defrost)
- Check air vent if air is present.
- Check if the unit is not overloaded with stocks or air vent block with stocks.
- If no air is present in vents then check your blower inside if operating.
Feb 29, 2008 | Refrigerators
Refrigerators Logo
54 people viewed this question
Top Westinghouse Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
