Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Check water light is on
The check water light is on and the dishwasher is not draining. we have emptied the dishwasher manually and cleaned the filter. It seems blocked some where inside the dishwasher. What can i do?
  • Anonymous Jan 29, 2009
    Check Water Supply display lights up.
    Tap is on, filter cleaned, hose not kinked.
    Mine is Bosch SGU53E75AU
I had the same problem! First disconnect mains power, then switch off the mains water to the water input hose, and disconnect the hose. Disconnect the waste outlet hose from your drainage. ( this will release some water from the hose ends, so a washing up bowl would be handy ) You will need to tip the dishwasher on to it's back, be carefull not to damage the waste outlet hose, and watch out from more water spillage. Next remove the two screws on the base metal cover, and spring out the cover from the two side clips, the cover can then be removed, you should have a screw holding an earth lead remove screw and lead from cover.
Inside the bottom of the dishwasher you will see a small electric pump fitted to the side of the dishwashers drain, it has two wires with spade connector on them, disconnect these from the pump noting colour of the wires for reassembling. The pump has the same diameter hose as the outlet hose. Next carefully remove the rubber elbow pipe from the pump and hose end this will need to be washed with clean water. Then to remove the pump, press and hold down the locking tab, where the pump is fitted to the drain, and twist the pump anti-clockwise. The pump will then release from the drain. Inspect the pump impellers for damage, and that the pump has free movement, also check condition of the rubber O-ring. Inspect inside of drain for broken bits of china and glass, remove and clean, also check the outlet hose for any blockages.
( run some water though the hose backwards from the water tap and collect it in a bowl from the pump end of the hose ) Reassembly is the reverse of the above, check electrics inside have not got wet, if ok switch on. The check water light should now be off.
Alan
Posted on Jan 17, 2009
Kenwood KID60B12 Dishwasher F2 Fault code
it seems you a blockage.. can you hear the pump running?if you can you will need to unstop it I have done it with just a cloth hanger coming from the front in put side
Jan 01, 2016 | Kenwood KID60B12 595 mm Stainless Steel...
Dishwasher won't empty water and stops with 1, 3 & 4 lights flashing.
It could be your drain hoses are blocked . damaged or kinked . Also the strainers may need a clean and when you take the stainless plate out you have easy access to pumps to give them a clean as well
good luck
Aug 11, 2014 | Fisher and Paykel Dishwashers
Hotpoint fdw85 does not drain
sounds like the pump is not working
Jun 11, 2017 | Dishwashers
Dishwasher will not drain. Can hear it making a sound but water will not empty. Tried some liquid plumer but that does not seem to be working. When we try to drain there is a funny sound.
Hi
This draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 13, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Jenn-air quiet series Model JDB8910AWW Dishes seemed to wash OK, but did not rinse. There is water (soapy) in the bottom. What do I do?
It is likely the drain function did not work.
Empty the dishwasher and clean the filters at the bottom. You will need a small container to empty the water and also use a towel to soak the remaining water.
If cleaning the filters does not help then there may be a blockage in the drain hose (check the kitchen sink side also). You may want to also confirm if the drain pump is operating at the right time in the cycle.
you could refer to this diagram for the parts involved.
Good luck.
May 13, 2011 | Jenn-Air 24 in. JDB1100AW Built-in...
Water in the bottom drawer
Take a glass and empty as much as possible. Take out the racks and get a towel to soak up the rest.
Take the washer arm out and detach the filter plate collar. Also take out the drain filter and clean everything. You could take the washer rotor out and clean the rotor cavity.
Put everything back and start the dishwasher on fast cycle. If water is still not draining and provided the pump is running, then you have a blockage in the drain hose or the kitchen sink end. If you are using inskerator then make sure it not blocked.
Jul 09, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hello , The inlet/drain light on my dishwasher is flashing , I have mislaid the manual can you explain how I can rectify the problem please , I am assuming something is blocked. Regards Georgina Cooke
My G892SC is almost 10 years old and recently had the same problem. The machine seemed to be stuck in the drain cycle and the intake/drain light flashed. I called Miele and ran through a few diagnostic tests but nothing worked. I had a Miele certified technician come out to look at the problem and he told me the drain pump needed to be replaced and that it would cost about $500 for the part and labor. While researching the cost of a new dishwasher, I stumbled on some online discussions about this problem and someone suggested pressing all 4 lower buttons on the control panel at the same time. I tried it last night and it worked! I only ran the wash & hold cycle but will try a full cycle tonight.
Jun 24, 2009 | Miele G892SC SS Dishwasher
Bosch dishwasher not draining-I have cleaned the filters, checked the hoses. No know plumbing problems what's next? Is there a reset button?
make sure there is not air in the line and that the cage where all the water drains down into in not blocked or clogged. so first take the drain line out and completely empty it out. next ck the inside where the water falls down into to drain and ck for stoppage.
Apr 28, 2009 | Bosch Evolution 500 SHE55M05UC Stainless...
Whirlpool dishwasher ADP905
Depress start button till start light goes out. Close door, drain pump should run for a while. Wait for end of program, rer-try a new program start. This process is re-setting memory.If this fails to sort problem then start checking components, ie: fill valve water on? heaters open circuit/down to earth, drain pump, is it emptying, wash pump.
Jul 31, 2008 | Whirlpool 24 in. ADP6940 Dishwasher
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
755 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
