Question about Ovens
How do i replace the double grill in hotpoint ew84x cooker
protek480
  • 1723 Answers
SOURCE: Hotpoint cooker, grill doesn't work but top oven does
If the elements 'look' okay, they probably are. The 'infinite control switch' is probably the problem. With out the use of a meter, it's guess work. Unless you can see a connection problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 03, 2009
Testimonial: "very useful thanks"
barkencoa
  • 3463 Answers
SOURCE: how can i mend the grill and oven on my electric cooker?
If the rings work o/k then could be timer if it has one make sure it is set to manual and not auto.
Another thing it could be is a faulty selector switch, which selects the different functions.
Hope this helps.
Plz rate my solution.
Thanks.
Posted on Dec 31, 2008
  • 13 Answers
SOURCE: We have a hotpoint cooker UY46, our electric
You need to replace the element. Very easy job remove the back plate from inside the oven (4 screws) and you will see a circular element held in place by one screw in the centre of the fixing plate. Remove the fixing screw then remove two wires and refit new element job done.
Regards Neville
Posted on Jul 29, 2009
SOURCE: Hotpoint BU62 double oven, no grill functioning
keep turning the oven/grill selector past the temperature settings, it feels like it won't go any further but it does!
Posted on Feb 07, 2010
SOURCE: i have a hotpoint ew 52 cooker and the grill does
I've an EW 71 with exactly the same problem! Thought it was the element but then noticed that there were two elements to the top oven - so very unlikely that both would go at once.<br />Tested to see if the switch was the guilty party by turning it on using the upper oven switch and indeed both elements heated!<br />If yours is doing the same then it's the switch....<br />... So how does one replace the switch?<br /> <!-- from fixya rte -->
Posted on Aug 15, 2010
Can you diagnose the fault & advise me how to fix my hotpoint electric cooker please?
This video shows how to test and replace the faulty heater element on the fan oven on a Hotpoint double oven.
Sep 26, 2015 | Hotpoint Ovens
The grill on my Hotpoint EW 41 Electric freestanding cooker has stopped working after my wife put aluminum foil into the grill pan which then touched the grill element causing it to 'blow' and so...
The grill element should not 'blow' by just touching it - it should be earthed. The elements do gradually disintegrate over time & the inside wire element either fractures or touches the element casing causing the mains to trip. Sometimes this makes it trip just once & then stops working. Replace the element - not usually any fuse in circuit with this. Often held in by 2 screws adjacent to the element at back of oven and conections via Fast-ons- Rick
Jun 12, 2011 | Hotpoint Ovens
I HAVE A HOTPOINT DOUBLE OVEN COOKER EW71. THE GRILL SWITCH IS PLAYING UP AND I NEED A NEW ONE. CAN YOU ADVISE ON THE PART NUMBER PLEASE
The part number you require is----------6204036.
Should you require the knob as well, the number is---------6201888.
These can be ordered directly from Hotpoint.
Please rate my solution.
Thanks.
Nov 22, 2009 | Hotpoint Ovens
Sep 03, 2009 | Ovens
Aug 26, 2009 | Hotpoint UY46 Style Line Stainless Steel...
We have a hotpoint cooker UY46, our electric tripped the cooker off and , now the nob and grill works but the bottem/main oven is turning on and the fan is circulating but not getting hot ? please help ;(
Regards Neville
Jul 16, 2009 | Neff U1721 Double circotherm Electric Oven
CLOCK ON COOKER
You can down load the user instructions from Hotpoint web site.
In your browser bar type in---- hotpoint user manuals
Then in the drop down list click on------ hotpoint manuals and guides
In the search box type in your model number and down load instructions.
Thanks.
Jan 14, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Oven not getting hot
The fan oven element needs to be replaced in the Hotpoint 6150 cooker.
Access is by removing the inner rear cover of the oven, there you will see the element.
Replace with a new one.
It is possible the base element is faulty in the top oven of the Hotpoint EW95,
The other possibility is that the high speed grill element is only part working.You need to check both these elements.
If the fan is working o/k in the main oven , but not getting hot, then you need to replace the element.
If it does heat, then it could be a faulty thermostat or possibly selector switch.
Unless you have a good working knowledge of electrics and know how to use a meter, then I would suggest you call some one in.
Thanks.
Dec 26, 2008 | Ovens
My oven has completely stopped working
hi there as long as your supply to the cooker is ok the problem can only be one of two things the mains terminal block burnt out or the overheat cutout has blown at the back of the cooker
Nov 30, 2007 | Hotpoint UY46 Style Line Stainless Steel...
Ovens Logo
41 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
