I have a Gateway 300x Micro-Tower case circa 2002 and I can not open the case, without breaking it. I'm trying to install a new audio card and can't get at the 300x innards. Help!
    President:
  • 373 Answers
Most of these towers are vertical style, therefore the big button is just to the left of the Gateway symbol. Push it in and pull the left panel away from the case.
Posted on Jan 11, 2009
    Genius:
  • 1,239 Answers
Hi
1.If the keyboard has a CD/DVD Eject key, press it. The Eject key is usually placed by the volume knob and is marked by a triangle pointing up with a line underneath.
2.Double-click My Computer .
3.Right-click the icon for the CD, CDRW, or DVD drive that is stuck, and then click Eject.
4.If the CD or DVD drive door button is a long clear plastic bar on the front of the PC, press firmly on the right side of bar. Some models have a button on the front panel of the PC to the right of the hinged door. Press the button to eject the drive.
5.If the drive door button is part of the PC case and is covering the actual drive door, open the door that is part of the PC case and press the Eject button on the faceplate of the drive.
6.Restart the PC and press the Eject button on the front of the drive when the first screen appears (before Windows launches). If the drive door opens this way but does not open in Windows, another software program is taking control of the CD driver. Try shutting down or configuring any software programs that create discs or monitor the CD or DVD drive.
7. If the door still does not open, do the following:
1.Close all programs and shut down the PC.
2.Unplug the power cord from the power outlet.
3.Look for the small hole on the faceplate of the CD or DVD drive. This is the manual release. The location of the manual release hole will vary (see Figures below for possible locations).
NOTE: On some models it may be necessary to remove the front panel to expose the manual release hole. Check the documentation that came with your PC for information about removing the front panel.
  • ABHISHEK.C
    ABHISHEK.C Jan 11, 2009
    NOTE: On some models the release hole and the drive activity LED look
    similar and are about the same size. Do not force the paperclip into
    the hole if it does not go in. Make sure that the hole is not actually
    the LED.
    Figure 1: Possible location of manual release hole
    Picture showing possible location of manual release hole
    4.Straighten the paperclip and insert it into the manual release hole until resistance is felt.
    5.Once the resistance is felt, keep pushing the paper clip until the drawer opens a little.
    6.Remove the paper clip and gently pull out the drawer until the disc is accessible.
    7.Remove the CD and turn on the PC.
    8.If the tray still does not open, do the following steps to check the
    power cable for the drive. Work on a hard flat surface over a
    non-carpeted floor:
    WARNING: The edges of metal panels can cut
    skin. Be careful not to slide skin along any edge of the computer's
    interior metal.
    CAUTION: This product contains components that are
    easily damaged by ElectroStatic Discharge (ESD). To reduce the chance
    of ESD damage, work over a non-carpeted floor, use a static dissipative
    work surface (like a conductive foam pad), and wear an ESD wrist strap
    that is connected to a grounded surface (like the metal frame of the
    PC).
    1.Turn off the PC.
    2.Unplug all power cords from the back of the PC.
    3.Press and release the Power button on the front of the computer.
    4.Remove the side panel.
    5.locate the power cord that connects to the back of the CD or DVD tray that is having the problem.
    6.Unplug the power cable and wait five seconds.
    7. Find a different power cable that is not being used, plug the
    different power cable into the back of the drive, making sure that it
    fits firmly into the socket. If a different power cable is not
    available, replug the original power cable into the back of the drive,
    making sure that it fits firmly into the socket.
    8.Replace the side panel and plug in the power cord.
    9.Turn on the PC and press the eject button on the front of the drive.
    If the optical drive does not have the manual eject feature and the CD
    tray will not open by using the steps in this document or if a disc has
    shattered inside the drive, the CD, CDRW, DVD drive may need to be
    replaced.
  • 679 Answers
There should be 2 buttons you can press near the side panels and then they just slide right off.
  • rockfixya
    rockfixya Jan 16, 2009
    let me know for further assistance.
    Thanks for using FixYa.
    Brigadier General:
  • 5,158 Answers
Look for tabs that move out from the front of the case
  • Roberta Smith
    Roberta Smith Jan 11, 2009
    Press two buttons, and the chassis--which holds all the system components--slides out smoothly like a dresser drawer.
Trying to remove the case of the es2 300x
Look for a Black button on the front of the case (Not the power on button) push it, And the top of it should pop up, If it doesn't pop up lift it up.
Mar 28, 2014 | Computers & Internet
I have an older Gateway PC. Model 703GE that has always worked pretty good. Two days ago, out of the blue, the audio quit. I checked Sounds and Audio devices and see the message that the Audio Device
it would seem that your audio card or audio processor chip has died. If this is a desktop (or tower) pc, you may have an audio card plugged into the motherboard (mainboard). This can be removed and replaced. If the audio plugs come directly out of the motherboard you should still have open slots on the motherboard where you can plug in a new replacement sound card. what you need to do is determine what type of slots you have open, they are most likely standard PCI slots. You would need to go to a computer store like Best Buy and ask them to point out a new audio card to install in your system it should come with a disc which includes the drivers needed and installation instructions.
Dec 03, 2013 | Computers & Internet
Will; a radeon hd 5450 work in a gateway 300x desktop
Ummmm, no.
The old Gateway 300X desktop computer has only white PCI slots, to install a graphics card in.
http://pcworld.about.net/news/Jan082003id108534.htm
More info on PCI technology,
http://en.wikipedia.org/wiki/PCI_local_bus
The ATI Radeon HD5450 (No matter who remakes it. VisionTek, Sapphire, etc) uses a PCI-Express x16 slot, on the motherboard,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6671719&CatId=3670
More information on the PCI-Express technology,
http://en.wikipedia.org/wiki/PCI-Express
From the link above's info on the Gateway 300X, it uses an Intel Pentium 4 at 1.8GHz, and uses old SIMM ram memory. (Single Inline Memory Module)
Not EVEN a gamer computer for today's games, no matter how you upgrade the graphics card.
(Not trying to be harsh, just telling it like it is)
For additional questions please post in a Comment.
Regards,
joecoolvette
(If you want to upgrade the graphics, use a PCI graphics card, IF there is any open, available PCI slot on the motherboard.
A) BEFORE you install the graphics card, stick that CD that came with the graphics card, into the optical drive. (CD/DVD drive) F-I-R-S-T.
Load the software on the disk.
B) Now turn the computer off normally, then unplug it from power.
Observe Anti-Static Precautions.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit) the delicate hardware components inside a computer.
1) Work on a table. DO NOT work on a bed, couch, or directly on a carpet floor. These are HIGH areas of Static.
2) Computer unplugged from power, computer case open.
TOUCH the metal frame (Unpainted surface) of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
C) Install the graphics card into the computer. Close the computer case, plug into power.
WAIT 1 minute, turn the computer on.
{Don't forget. You have to plug the monitor cable into the graphics card now, not into the computer's I/O area }
Aug 24, 2011 | Gateway 300 X PC Desktop
Ok! I have an ak32 shuttle mother board I'm wanting to upgrade. Over the years I've added newer graffics, audio, extra usb ports,and earthnet card. I built the pc in 2002. I had a cooling fan recently go...
the case isnt amd athlon 2100 xp, thats the processor, the case is either a atx or micro atx case, so refer back to the case and find out if it is a atx case or a micro atx case, then find a micro atx or atx motherboard so you dont have to replace all of your components
Jan 05, 2010 | Computers & Internet
Open the tower
Check the case to see if there is a button at the bottom of the back of the case. Sometimes the thin cases like that, similar to dell, open like a book.
Jul 26, 2009 | Gateway 300 X PC Desktop
I have a gateway 300x micro tower a I think the fan in the front has gone bad and is now giving off a burning smell. How can I replace this fan?
You should disconnect the fan from the system. Take it out and try to find a replacement or buy one that is phsyically and electrically similar
Apr 07, 2009 | Computers & Internet
Dec 18, 2008 | Computers & Internet
No sound
you have to get an additional wire to run from the drive's audio out to the sound card's aux in
May 29, 2008 | Gateway (1529603) Internal Drive Case
Open Gateway ES2 300X case
Apr 30, 2008 | Computers & Internet
Computers & Internet Logo
850 people viewed this question
David Payne
David Payne
