Question about Baby Lock Ellure
Loops on the bottom
Hi all of a sudden my overlocker is looping underneath whenever I put elastic in?? Never had a problem before, any ideas??
    Scholar:
  • 65 Answers
Http://www.babylock.com/support/faq/?FAQ=10
may have your answer.... the first thing I can think of is check your threading, if not one of the guides may have been bent, OR
that your lower looper may been knocked a bit loose.
Posted on Jan 25, 2009
Making an elastic waistband? How to.
Hello!
There is more than one way. This is an easy way to make an elastic waistband on mid to lightweight fabric.
Begin by measuring the waist diameter and subtracting 2" from the measurement.
An easy way to make an elastic waistband is to sew the ends of the elastic together, creating a loop with the elastic. Be sure there are no twists in the elastic before sewing the ends together.
Fold the elastic in half using the seam as one edge and mark the other side with a pin. Fold the elastic in half again and mark the two other folds.
Your elastic should now have 3 pins and the seam quarting the circle.
Hopefully your pants have a center, back and two side seams, making the next step easy. If not, fold and mark the front back and sides like you just did with the elastic.
You're now ready to pin the elastic to the OUTSIDE of the pants. Line up the edges of the fabric and elastic. Match the marks on the elastic to those on the pants and pin them together.
Using a quarter inch seam, stretch the elastic between the pins/quarter marks and sew it in place.
IF your machine has a lightening stitch, use that. If not a zigzag stitch will wear better than a straight stitch, which will also work but may snap if used on a stretchy fabric.
After you have attached the elastic fold it to the "inside" of the pants taking care not to fold or bend the elastic. You have just created a nice finished top edge to your pants!
Giving the elastic a stretch so it fits the fabric, pin the front, back and sides like you did before, making sure to pin the lower edge of the elastic.
Stretching the elastic to make it fit the pants, stitch the lower edge close to the edge, again with a stretchy stitch if possible.
Next stitch the top close to the edge from the front. (I know it's already attached, but this will keep the top looking nice.) 1/8" looks nice, but just make sure your distance to the edge is consistant.
Sit back and admire your handy work! You've now got the elastic sewn on and there are no exposed raw edges.
If you are working with a heavier fabric let me know and I can explain how to make a casing for the elastic. The kind you thread the elastic through.
Aug 14, 2017 | Sewing Machines
My Bernina Artista 185 has been looping the top thread on the underneath side. Is this a tension problem? No amount of adjustment seems to correct it. What can I do to correct the looping problem?
It is a tension problem. My advice is always to double check in the manual that you are threading correctly. With loops underneath, your tension is too loose, or the bobbin is not seated properly.
Nov 18, 2015 | Bernina Sewing Machines
How do I sew Elastic waistband with Husqvarna Viking 910 Surger
I am assuming this is a simple stretch waist band with elastic about 2cm wide attached to a skirt or trousers. You need to measure your wist and cut elastic that length plus 2cm. Then join the two ends by overlapping them 2cm and zig zagging the elastic together with regular sewing machine. Now mark the elastic in quarters, ie hold it flat with the join in the middle and mark each edge with chalk or a fabric removable marker. Then put the marks together and mark the edges again so you have 4 marks equally spaced. Now do this for your garment too. It may be bigger in back so mark front and back, then half this to find the side quarters. Put elastic on inside of garment against raw edge and pin the quarter marks on elastic and garment together. Set up overlocker for 4 thread wide seam. Test seam and adjust tensions if necessary. Now you need to serge the edge of the fabric and elastic together, trimming the fabric but not cutting the elastic and stretch the elastic to fit the garment as you stitch. Elastic on top, fabric right side down underneath. Take out pins before you get near them! Start by lifting the front of the presser foot with your finger and placing fabric and elastic under, then start stitching on and straighten up once the seam is onto the elastic. Dont lift the pressure foot, you just stitch, stop, stretch the elastic to the fullness of the fabric, hold it and seam forward a few inches, then stop and repeat the process. Once right round go over your starting point, then turn and serge off the fabric edge and chain off. Cut, pull the chain to pull it flat and tie a hald hitch in it right up close to fabric. Now turn the elastic band to the inside of the garment. You need to secure it. Usually a straight stitch just onto the lower edge of the elastic with sewing machine from outside.
Dec 27, 2011 | Husqvarna Huskylock Computerized 910
I am trying to alter a swim suit, and I need to use a stretch stitch. Does the Singer model 2638 have this feature?
Here is the stitch selection page from your manual
I would suggest that you use the stitch called "elastic overlock" using a stretch needle, you need a ball point tip on the needle to press between the elastane fibres in lycra. A stretch needle is blue, coated with a substance that makes it easier to stitch these types of man made stretch fibres, often size 75. If you can't get one of those, then use a ball point needle, size 70 or 80.
You need a stitch with forwards and backwards movement so that the stitching doesn't break under stress. Your machine also has a stretch straight stitch and this would be a forwards and backwards straight stitch so this will work too but can look a bit 'heavy' sometimes. But even triple zig zag narrowed down will work often.
If you are sewing leg edges with lycra, shop made garments will have clear swimsuit elastic sewn into the seam using a coverstitch overlocker, you'll never get as good a result with a regular sewing machine but you can get a reasonable finish with practice. This elastic is available to buy, you might want to use the overlock stitch to attach it to the fabric edge, stretching as you go, then turn it to the inside and use a stretch twin needle and straight stitch to top stitch from the outside, stretching the fabric as you sew.
Trust this helps you a little, 4 thumbs up if so. :-)
Jul 13, 2011 | Singer 2638 Mechanical Sewing Machine
I've just got janome 634d serger, how can i make the bottom of a T-shirt ? Thank you so much
If you want the bottom of the T to look like RTW with the double row of stitching, you cannot do this on a serger.
You can achieve the effect by using a twin needle, two spools of thread, bobbin and a straight stitch.
Make sure the double/twin needle will pass through the presser foot and opening in the needle plate below the presser foot.
Practice on a double layer of a scrap of the T shirt material as the tension may need to be slightly looser than the normal setting.
Apr 05, 2010 | Janome MyLock 634D Mechanical Sewing...
Brother XL2230 Elastic Overlock function not working properly
First of all check your needle size and utility, for the tension machine it must be the same on top and bottom example pull the top thread and the lower thread they must be the same.
When sticthing the elastic you must devide the amount of elastic versus the fabric : dise the amount before stiching
Hope this will help
Good day
Feb 16, 2009 | Brother XL-2230 Mechanical Sewing Machine
Sewing Machines Logo
46 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Jon Piercy
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
