Question about Brother MFC7360N AllInOne Laser Printer
MFC 7360N Is printing faded on one side
I did put a while ago near a radiator, does have anything to with it?
  • Leo Leilles Dec 03, 2012
    I moved away from the steam but so far no improvement. Any suggestions?
3 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Posted on Mar 10, 2009
SOURCE: My Brother MFC-9420CN isn't printing
You can try cleaning the glass and scanning mirror and unplug your printer for 24hrs if still not fixed you have to replace the camera.
See if the paper cutter is seated right and is not defective. You can try cleaning the cutter and lubricating it, even then issue not resolved replace the gear train.
Posted on Dec 10, 2010
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
Jan 14, 2015 | Brother MFC 7360N - Multifunction fax /...
My MFC-7360 says NO PAPER, but there is paper.
Most probabply will also say Please put paper in the MP tray ?
Sep 23, 2014 | Brother MFC 7360N - Multifunction fax /...
Reset brother toner counter mfC 7360N
If you are using refilled products then your re-manufacturer needs to reset the cartridge. For these there is a particular gear placement to allow the toner sensor to reset. If you are using Brother Original products then the brother helpdesk should talk you through this.
If you are filling your own cartridges well any issues you have with this reset process are at your own risk.
Once you have completed the reset process go to the brother website and download the latest firmware update for your machine as this will alleviate most of the issues with cartridges not being correctly set.
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-style-parent:""; font-:10.0pt;"Times New Roman";}
  1. Open Front Cover.
  2. Display reads "Front Cover Open"
  3. Press the 'Clear' button
  4. Display reads "Replace Drum"
  5. DO NOT RESPOND TO THIS MESSAGE. Press '*, 0, 0' on the keypad.
  6. Press 'OK'
  7. Close Front Cover.
your machine should now be ready to print.
Aug 31, 2014 | Brother MFC 7360N - Multifunction fax /...
Why does my Brother MFC-7360n Does Not Pick up paper?
Leave the machine and attend to it at a later time repeating all you initially did.
Aug 28, 2014 | Brother MFC 7360N - Multifunction fax /...
Faded print on right side of page. When I copy/print in black, why is the black print faded on the right side of the paper?
Your toner cartridge may be the culprit.
Take the cartridge out and shake sideways and up/down. Reinstall it and try again.
If it's still printing faded side, replace the cartridge.
Jul 30, 2014 | Brother MFC-9840CDW Laser Printer
Why brother mfc 7360n printing envelopes wrinkle paper
Do U mean wrinkle the envelopes?,,,,I can solve some MFC-9840-CDW issues, but the 7369N is a guess. Read your manual or do a google search.....There maybe a setting in the 7360N that adjusts printing for card stock and envelopes....
Jul 01, 2014 | Brother MFC-9840CDW Laser Printer
Brother manual feed insert paper
I am a Brother employee working for the software technical support department.
We have a solution for your printing issue posted on our solution site.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000016347
Description of Problem 100000012720
When I try to print from Microsoft Word or another program, I receive a message stating: Manual Feed, No Paper, or Load Paper XX. What can I do?
Brother Software Technical Support
Jun 29, 2014 | Brother MFC 7360N - Multifunction fax /...
Outlook won't print to Brother MFC7360N AllInOne Laser Printer
Must be set on Brother MFC-7360N series. Set on PC-FAX will not print with all programs, as it is printing with an output through the fax. Go to control panel, select devices, printers to change to pc-7360 series. This should print on all programs.
Mar 17, 2014 | Brother HL-5240 Laser Printer
Open Questions:
See all Brother MFC7360N AllInOne Laser Printer Questions
Brother MFC7360N AllInOne Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
