Pioneer dvdr3432v after 5 replacement units my latest pioneer dvdr3432v is less than month old and is displaying the message blocked and the dvd wont eject unfortunately pioneer are now saying it is 1 week out of warranty be great full any help scott
ctf1800
  • 4402 Answers
SOURCE: phillips 33805 dvd recorder showing blocked
sounds like a belt is slipping or broke, if it's slipping just keep on trying to eject it, if it's broke you will have to open it and manually push the cdrom draw out
Posted on Dec 03, 2007
SOURCE: Phillips DVD Player / Recorder
Slot under front edge of player will allow you to eject by sliding lever with a small pointed object
Posted on Jan 13, 2008
The DVDR 3355 at my home had the same problem and thanks God I found the solution. It's on this same forum at this address http://www.fixya.com/support/t353456-dvd_player
Posted on Oct 08, 2008
SOURCE: lg dvd drawer opens by itself and wont stay closed
I tried the solution documented at
http://www.ifndef.altervista.org/index_eng.html
3:rd Loader repairing
Posted on Jan 28, 2009
  • 4 Answers
SOURCE: only says loading when started, does nothing
Hi, your problem is the laser lens, it went sour. This device is coded to read only region 1 disks, when U attempt to read other regions disks it will read them once, 2 or 3 times but then... it will stop reading any disk regardless the region they are. Regions codes were implanted on disks to control piracy, so USA has region 1, Mexico 4, Asia I believe is 3 and so on. There are a total of 6 regions worldwide, U have to get disks matching the region U are from or, better solution... get a multi-region DVD player.
Posted on Jul 04, 2009
Pioneer cd player pdc-q180 wont turn and ejects disc, any advice??
have a look inside to see if any forien objects are in the area.otherwise the unit needs to go to a specialist.internal driver unit could be faulty.
Aug 14, 2014 | Televison & Video
I have a 5 month old Alba DVD Tv combo model number LCD22ADVD. The DVD has stopped working and when DVD input selected, instead of showing the usual DVD home screen, it now shows a bright blue screen. The...
Sometimes a dvd can be ejected manually but mostly the unit must be partially dismantled but if you try to do that you will invalidate the warranty - at only 5 months old it will be the responsibility of the supplier/retailer to cure the problem. I suggest you re-read the instructions and then contact the supplier without delay.
Then you should contact the dvd rental company and tell them what is happening.
Sep 28, 2017 | Televison & Video
My pioneer dvdrw dvr 107d door wont open when i press button /have cd stuck inside (worked 5 mins ago) can still view dvd content/ will driver update fix ? please help
The drive may have come loose in your pc and is stopping the door to open.Hold open the front flap and press the eject button. If it wont eject your disk straighten out a paperclip and holding the front flap open look at the front of your drive and you will see a small hole.Push the paperclip through the hole and it will release the catch and eject your disk, You may have to push hard .Hope this helps you.
Regards Bill
May 04, 2010 | Pioneer DVR-107D DVD±RW Burner
My JVC TH-G30 gives me a locked message when I try to open the load tray what should I do?
hello Setting the disc ejection lock
You can lock the disc tray to prevent the disc form
being ejected.
When the main unit is turned off, hold down the STOP
key at the front panel for 5 seconds
If you attempt to open the disc tray by pressing
OPEN/CLOSE key, the disc tray does not open and
“LOCKED” appears in the display window.
To cancel the disc ejection lock, hold down the STOP
key at the front panel for 5 seconds again when the
main unit is turned off.
“UNLOCKED” is displayed in the display window.
Note:
Before the main unit is turned off, DVD/CD function
should be selected.
Mar 29, 2010 | JVC TH-G30 Theater System
Panasonic dmr-ez47v won't recover from u61 code faul. Unit keeps ejecting tray and switching off.
no solution sorry, I have same problem. any one else with same prob?. Thought panasonic was a good make, 18 months old and now knackered.
Dec 01, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
"No Disk" message on front display
If when you insert the disk you hear a whirring and clicking noise, CD spins, and does not read, then that is a problem with the DVD lens.
The DVD lens try to focus on the DVD track, by moving lens pickup and spinning the disk, but cannot read the tracks because the lens is dirty or defective.
Try first cleaning the lens with a DVD cleaner disk. And also if you can see the lens from the outside try blowing some canned air on it.
If this still does not help, then the lens pickup may be faulty, in this case you often replace the whole DVD drive unit inside the DVD player.
Dec 27, 2008 | Pioneer DV-343 DVD Player
My pionner avhp5700 dvd keeps coming up with error
I have the same issue with my unit but it seems to be worse in summer months. I don't leave cd/dvd in unit and have considered removing unit.
Nov 02, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Built in dvd player will not let me insert dvd
The LCD/DVD may need a reset. Unplug the unit for 10 sec then plug back in. Instead of power button, push eject button. The blue DVD screen should appear. This worked on my unit which I had for only 2 months. If not call customer service.
Oct 23, 2008 | LG 32LG40 32 in. LCD HDTV
Repairing disc message won't go & DVD disc won't eject
By pressing the Power button for >10 seconds you can force the unit to turn off. Immediately as the unit does, press the disk eject button and the defective DVD can be removed. Don't put it back in, or the problem may repeat!
Nov 17, 2007 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
