Question about Yaesu Radio Communications
Icom v100 no rx no tx display keeps flashing
At first my icom v100 operates normal when i keep it in the box. when i plug it on to my power supply after many months of not using it, strange things happen. all channel has no TX and RX and everytime i push the PTT, the display goes flashing. and the local fm station can be heard in all channel. what could be the problem?
SOURCE: general lee no tx or rx
sounds like a cold solder joint on the voltage regulator or the regulator itself.
Posted on Sep 22, 2008
SOURCE: 148GTL Cobra (no tx)
the dx 2527 has a fine ransmitter. it is choked out by the factory to pass FCC reg's. With about $4.00 in parts from the rat shack you can really make it talk. my personal 2527 dead keys around 3 watts with around 45 50 watts on rms with bird meter around 60 with crappy dosey.
Posted on Jan 22, 2009
  • 6 Answers
SOURCE: tx: fine rx : no..
Your power output has blown, they are called your "finals" they can be replaced quite cheaply.
Posted on Sep 05, 2009
  • 773 Answers
SOURCE: Cobra 200GTL: Clarifier affects TX
Unfortunately, most people look to unlock the clarifier in radio's it is locked in.
From what I understand it is possible to lock it in that radio, however I do not know it because I usually unlock it in my radio's.
I also did a search, and asked a few people I know who are also very good with radio's and they do not know either. The only thing I found was this, and you have to pay this shop to do it.
http://cobraworxshopz.com/12.html
Posted on Oct 03, 2009
SOURCE: when i key up the mike the tx/rx light and the ant
your swr setting are off wack fix your swr
Posted on Oct 09, 2009
No prob on 20mtrs but on 40mtrs no power out using rtty setting
check antenna connection and power output of your radio.
Aug 31, 2015 | Icom IC-756PRO Transceiver 002896
Onkio receiver TX-SR 505 DISPLAY tube has 3.8 acv ,is off
Your Onkyo has the 3.8 VAC which normaly is correct for normal operation of the display. Make sure you have a SM to help you troubleshoot the problem.
Jan 10, 2015 | Onkyo Tx-Sr505S 7.1 Channel Home Theater...
How to repair Icom IC-M700 HF transeiver?
Does it have an external speaker plugged in the back? If so try unplugging it see if the internal speaker works, if it doesnt have an external speaker plugged in try one, maybe the internal speaker went bad from moisture.
May 28, 2014 | Icom M700 Pro - IC AT-130 automatice tuner
Icom u16 Rx , but when I Tx , speaker makes buzzing noise , could the antenna connection to the pc board be bad ?
It's possible because this would allow the RF signal to flood the circuit. I would suggest you try another antenna as a first solution. A bad antenna would cause the same problem. Good luck and let me know if it helps!
Sep 18, 2013 | ICOM Informatique Icom Radio U16, IC2GAT,...
Icom m505 no rx
See the sensitivity if it is low then change the filter (wide) of your Radio.
May 23, 2013 | Icom M505 VHF/DSC Marine Transceiver -...
I have an Icom v-8000 radio.The TX is very good with 75 watts out-put. But have nothing in RX.No signal and no audio.
What you have is an amateur band radio, which requires you to be a licensed operator to use it. It is possible that the frequencies have been removed from the eeprom prior to your purchasing same.
You can have Rx only frequencies programmed by an authorised 2-way workshop, but until you become a qualified amateur operator, you will not be able to get Tx frequencies programmed.
For licensing info for Amateur operators visit www.vk6wia.org.
Regards,
Peter
Feb 20, 2013 | Radio Communications
Modify - open rx/tx for all more FQ
You have an Icom IC-4088SR HH radio, that much I can under stand, But the rest is confusing.
Modify - open rx/tx for all more FQ, is very cryptic, and doesn't make sense.
Please provide more info, the more info you provide the better we understand and the quicker we find a solution for you.
Cheers,
Peter
Aug 25, 2012 | Icom IC-4088SR PMR446 Handheld Transceiver
I bought a new logic unit (front face) of Icom F121 and it needs to be restored. How do you restore a logic unit for the Icom F121?
1- You have to to "Reserve" mode.2- Change Set Mode Access: Inhibit to Enable3- Common>>Secutity Change Set Mode Access : Inhibit to Enable4- Enter RX TX frequency and write to the radio.
or you can download version Rev 1.7 from here:
http://www.two-way-radio-tools.com/icom-softwares.html
http://www.two-way-radio-tools.com/icom-radio.html
Aug 27, 2010 | ICOM Informatique IC-F121 VHF 136-174MHz...
How do I reset the F221 to factory settings. I cloned the unit with V1.6 of the programming software with updates that included turning on the user start password and now the box will not communicate with...
F121 VHF, F221 UHF they both use the latest Version 1.7.
For F121 Factory default as follows:Open your CS-F100 software, enter RX TX frequency below, and write to the radio.Ch1: 136.100 MHzCh2: 155.100 MHzCh3: 173.900 MHz
For F221 Enter RX TX frequency belowCh1: 440.000MHzCh2: 460.000MHzCh3: 489.000MHz, then write to your radio
Or you check from this site:http://www.two-way-radio-tools.com/icom.html
HP
Feb 04, 2010 | ICOM Informatique IC-F121 VHF 136-174MHz...
ICOM IC-F21 (400-430MHz): Programming problem
may your software be corrupted.Re-install it
Jan 14, 2008 | Radio Communications
Radio Communications Logo
42 people viewed this question
Top Yaesu Radio Communications Experts
eradiostore
eradiostore
Nyte_Ryder
Are you a Yaesu Radio Communication Expert? Answer questions, earn points and help others
