No power to washing machine there is no power to my washing machine I have checked the socket and the fuse
  • 15,935 Answers
The ECU needs to be checked for power.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 10, 2010
Daewoo washing machine is plugged in but power button wont work
Check if there is power at the socket, or fuse may have been blown
Oct 21, 2016 | Daewoo Washing Machines
My Bosch 1244E will not go on I plug it and no power?
Washing Machine Won't Start - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 21, 2013 - If wall socket & fuse are OK but washing machine won't start ... didn't work - so I tried plugging my Hoover washing machine into another plug and all systems are go! ... I have a bosch washing machine which is 16 months old.
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine will not start, no power. ... So begin at the plugand make sure that there is power to the socket and that the fuse is okay ... I have aBosch washing machine which is leaking from underneath and the water is coming out the front at the bottom. .... It washes but won't go into rinse or spin.
Washing Machine Will Not Start - What To Check - How To Fix
removeandreplace.com/.../washing-machine-will-not-start-what-to-check...
Apr 10, 2015 - Be sure the washer is plugged into the electrical outlet in the wall. ... If the lid switch is faulty, then the washing machine will not start. ... If the lid switch is being pressed but no power is being supplied to the washers motor, ..... October 28, 2014; Bosch Washing Machine Error Fault Codes October 28, 2014 ...
Dishwasher Will Not Turn On - How To Fix ...
Jan 19, 2016 | Bosch Washing Machines
Machine has no power, it is plugged in and the fuse has been changed, there is power to the socket,
IF there is no power going to the machine.possible fuse not properly mounted.Try to check using a tester if power is flowing to machine.From the socket,use an extension wire and check if power is flowing within the circuit if it is the problem is in the machine.Did the machine blown out?
Jun 21, 2011 | Washing Machines
Have a GE Select washing machine that won't start or operate ? Can you help ?
Hello there and than you for choosing fixya
Washing machine is dead, wont start Obviously the first thing to check is that the socket is supplying power by plugging another appliance in such as a lamp. It is less likely to be the socket but you'd be daft not to check it out before calling an engineer as it does occasionally turn out to be a faulty wall socket. This is only necessary though if there are no led indicator lights lit up on your washer as any light that's on shows that the machine is getting a live and neutral supply from the socket.
The second thing to check is the fuse in the plug. Either put the fuse into something else and check the appliance still works or try another fuse that you know to be OK in the washer. Make sure you use a 13 amp fuse and never by-pass a fuse! If both of those are OK, then the most common cause for a washing machine that wont start is the door interlock, particularly if the mains lights on the washing machine has come on, but nothing works. However, the fault could also be in wiring to the door interlock or even the door catch not activating it properly, or the on off switch or the main control module. With some Indesit and Hotpoint washing machines even an open circuit heater or motor can cause the entire washing machine to stop working except the led lights.
You need to know what you are doing to trace this type of fault so if it isn't the wall socket or the plug you'd be better getting an engineer to trace it. Do not work on a live washing machine. Engineers should use a continuity test meter to trace faults with the washing machine unplugged and never test with a live washing machine.
Feb 06, 2011 | Washing Machines
Washing machine wont work at all
Mar 19, 2010 | Washing Machines
Candy GO1482 washing machine blows house fuse
u have an earth fault on mc caused by damp or water across the neutral check for water on electrical components
Nov 18, 2009 | Washing Machines
Hoover visionhd no power
Check wall socket , Check machine door interlock switch, you may need multimeter to do further checks....
Oct 04, 2009 | Washing Machines
Had power cut now machine wont work changed the fuse still nothin
check power from the wall socket if its ok the doorlocks and motors are prone to blowing the circut board can be expensive
Jul 30, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
My whirlpool washing machine wont turn on. I checked the fuse and the socket which are working perfectly well. It doessnt seem like there is any power in the machine.
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Jun 17, 2009 | Whirlpool Washing Machines
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
