Question about LG Refrigerators
I have a GR-542 wf and the fridge is not cooling
The freezer is cooling but not the fridge
watugot
  • 290 Answers
SOURCE: hot areas around doors on LG fridge
This is usually caused by a dirty condenser coil or a stalled condenser fan.
Remove the cover from the rear of the fridge and see if the fan is running. If not, make sure nothing is stuck in the blades keeping it from turning. If it turns freely you probably need a new fan motor but you would need to check the voltage to be sure.
Post back if you have any questions.
Posted on Nov 18, 2007
docjohn174
  • 943 Answers
SOURCE: My lg gr-222sbd fridge/freezer is
hi thanks for the question it sounds like the compressor is trying to start your problem is the relay or a bad compressor replace the relay and see if this solves the problem if it does not then a faulty compressor thanks please leave a positive feed back the appliance doc
Posted on Sep 24, 2008
  • 68 Answers
SOURCE: my freezer is working perfectly but the fridge is not
The channel in the back were the cool air comes down from the freezer to the fridge may be iced up. Try defrosting the fridge/freezer for much longer than usual, all day if necessary.
Posted on Aug 30, 2009
heatman101
  • 43501 Answers
SOURCE: I have acquired an lg
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 31, 2010
SOURCE: Toshiba Refrigerator GR-H37ST not cool
The thermostat for the fridge is operated using a spring mechanism and it is different from the thermostat for the freezer. To fix this, open the 2 screws covering the thermostat for the fridge and pull everything out. You can see a block of Styrofoam. Pull it out carefully and you can see there is a small hole with a white thin plastic covering inside it. That is the thermostat. It may be stuck, so I recommend you to put something inside it so that the plastic covering won't block the square hole. Put everything back together, and the problem is fixed. Except that you can't control the temperature for the fridge anymore.
Posted on Feb 27, 2011
I have LG Electrocool GR-252SQ(Double door).the freezer is very cool but the lower fridge section is not getting cool.Plz guide.
i have same fridge and my problem is that the water from freezer is not going out pf the fridge, instead it comes down to fridge section through condensation
Mar 24, 2013 | Refrigerators
Lg express cool turbo gr-t452gva water build up in fridge
Drain pipe is in the freezer below where the fan(s) are. You may need to take a cover off to get to it.
Mar 20, 2013 | Refrigerators
We have a lg gr-s592gt and we noticed the frezer is working fine but the fridge wasnt cold. i noticed that the two fans that controller the temp in the fridge arnt working but everything seems fine , this...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Ice build up and stops the fans...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 11, 2010 | Refrigerators
My freezer is working perfectly but the fridge is not
Aug 30, 2009 | LG LRTP1231W Top Freezer Refrigerator
My LG LRBN20514ST Fridge is not cooling
where to look for the defrost timer on the LG top freezer modle
GR-S392GCA
Aug 26, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Refrigerators Logo
75 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
