Question about Intel Motherboard
No display when i give power to the motherboard motherboard start functioning but there is no sound of display and no display on lcd . enven at the analyser card there is showing voltage ,clock but no frequency is there plz help this problem due to bios if u have the software to repair BIOS through pendrive or any drive plz help me most board are of INTEL DESKTOP BOARD D865GSA. Thank you
  • 1 more comment
  • Anonymous Jan 11, 2009
    when i give power to the motherboard motherboard start functioning butthere is no sound of display and no display on lcd . enven at theanalyser card there is showing voltage ,clock but no frequency is thereplz help this problem due to bios if u have the software to repair BIOSthrough pendrive or any drive plz help me most board are of INTELDESKTOP BOARD D865GSA. Thank you
    the fun continuos runs at it speed .it does not stop. until i put the power off.
  • bingi Jan 12, 2009
    dear sir,
    I have intel DG31PR motherboard. It is working properly, but some times when i tries to switch on the computer it is giving 3 beeps and display is not working.
    I tries to solve this problem, when i remove the cmos battery from motherboard it is working properly. after that i place the battery on board.
    iam facing this problem since 3 months.
    please tell me what the problem it has? and how to rectify it.
    thanking you.
  • Louis Stanly
    Louis Stanly May 11, 2010
    How long does the CPU fan run, does it stop. or does it make any kind of beep sound??
Reply to problem reported on Jan12, 2009
Cheak your RAM slot or right BUs Speed, cheak supply Voltage , if missing change supplyMOSFET.
Reply to problem reported on Jan11, 2009
Cheak for supply voltage for clock generatob IC, Cheak X-Tal 14.318 Nmz, Cheak Free clock signal out at the clock generator CPU Clock out pin, Cheak continuty between clock generator CPU clock out to CPU free clock pin at the CPU Socket.
Posted on Jan 15, 2009
    Sergeant:
  • 270 Answers
It may be the problem of your monitor.check it
Posted on Jan 12, 2009
My motherboard G31M3-F V2 doesn't power on nothing powers on enven the fans but the power supply seems fine what could be the problem
Best thing I can recommend is check your connections. Are all the power supply connectors plugged in? Your P1 connector, your 4-pin (or 6/8-pin) connector for your CPU?
Can you bypass the switch on your case and jump the power button pins on your motherboard to get it to power up?
Grounding could also be an issue.
What about your graphics card? Has it got the power it needs? Try the onboard or booting without it.
Hope this helps!
Mar 11, 2016 | Computers & Internet
NO VGA DISPLAY TOSHIBA SATELLITE M300 FOR VISTA
Hi What precisely do you mean by VGA display, is your laptop not displaying anything on lcd screen,or its having problem giving display on an external monitor connected via a vga port.
if there is no display on the laptop LCD screen, then turn the laptop on and observe for beeps sounds and hard disk spinning sound if still no display is available plug the laptop to external monitor and again restart the laptop. if there is no display on the external screen and laptop is displaying well in LCD, Then most probably you need to press some keyboard combination on laptop keyboard eg: Fn + f4 , refer to your laptop manual also.
Mar 21, 2011 | Computers & Internet
Compaq F700 not functioning
Hi. Try to drain the electrostatic energy of the motherboard. Please see procedure below.
Take out the battery
Unplugged the power adapter
Push and hold the power buttong for 30 secs
Put everything back in
Power on the computer
If same issue will happen. I suggest to contact your computer manufacturer and have your LCD repaied since computer is still powering on this could be LCD problem.
Jul 25, 2010 | Compaq Computers & Internet
CP-X260 LCD Projector: when i connected to my laptop the projector does n...
By nothing do you mean it does not power on? Is your laptop on? Does it have an image on the screen?
Most of the time, this is easily fixed by holding down your function key and pressing one of the F keys. Different laptops use a different key, but you are looking for the CRT/LCD key.
So, press and hold function + CRT/LCD and you should notice a change. Be patient as it sometimes takes a moment. There are 3 settings here. One will give you a display on your laptop but not the projector. One will give you a display on the projector but not the laptop, and one will give you a display on both. So if the first time you press function + CRT/LCD you get a change but it's not what you need, try it again and cycle through until you find what you want.
May 16, 2010 | Hitachi CP-X260 LCD Projector
No Display
could be mother board or hard drive
Aug 11, 2009 | Intel D945GCL Motherboard
Compaq V5005us is weird. Powers on with black screen and freezes
It sounds like your Video card and/or motherboard are starting to give out or your LCD is giving way. Try plugging the laptop into an external screen and see if it still acts strangely or even displays on the external monitor.
Mar 18, 2009 | Compaq Presario 2100U Notebook
Not display matherboard
Most probably your motherboard has malfunctioned. Just to give it a try Pull the CMOS battery ( CELL) out of board and then start the computer.
Nov 22, 2008 | ASUS M2N-MX Motherboard
No display for intel board
i want to VGA driver for ACER MOTHERBOARD
Aug 28, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
IT USED TO RESTART ABRAPTLY BUT NOW NO DISPLAY
Hello Arua
I would suggest you get your hands on a 4 digit post card to diagnose the problem
heres one
http://cgi.ebay.com/PC-DIAGNOSTIC-CARD-4-Digit-PCI-ISA-POST-Code-Analyser-N_W0QQitemZ130196339829QQihZ003QQcategoryZ162QQcmdZViewItemQQ_trksidZp1742.m153.l1262
  • Determine defects by difference sounds coding with build-in speaker.
  • It can diagnosis the motherboard signal which show the problem of CPU, Memory, video card, etc.
  • The POST code display is made up of a dual, dot matrix hexadecimal read-out that display's Power On Self Test (POST) status codes
  • Support the power source working indicator -- +5V,+12V,+3.3V and 12V(When indicator LED is on to indicate its respective power is fine, otherwise to indicate its respective power is failure.)
  • Fully compatible with any kind motherboards which has the PCI and ISA bus slot.
  • If this solution was any help at all please press accept or ask more questions with the other button.And if you need anything else let me know, you can ask me 24/7 by clicking
    on the ask me button, I will ansver in most cases within 24hours.
    Thanks and good luck!
    May 05, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
    Screen Don't Comes On Anymore
    Have you tried plugging an external monitor into the VGA connector on the back? This would narrow down the problem to either the video card/motherboard or the LCD display itself.
    There are several possible defects- as above, the display, motherboard component, video section.
    Also, first check the LCD/CRT switching function. On many laptops, there is a function (FN) key which is pressed at the same time as one of the number/function keys (the uppermost row of keys), and this combo will switch display from LCD to CRT & both.
    Feb 28, 2008 | IBM ThinkPad T42 Notebook
    Intel Motherboard Logo
    127 people viewed this question
    Top Intel Computers & Internet Experts
    Tony
    Alun Cox
    David
    David
    Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
