Question about Sewing Machines
How to threading a 3 thread goldex lorance overlocker?
  • Sewing Machines Master
  • 1,564 Answers
All overlocker machines are threaded like this.
1. Upper Looper
2. Lower looper
3. Needles right to left.
Posted on Dec 02, 2012
  • 27 Answers
SOURCE: Threading three thread Baby Lock Overlocker EF 405
Ther should be a color coded threading chart on the front inside cover.
Posted on Feb 23, 2008
SOURCE: Elna Lock L2 I have overlocker rage..... been
Have you made sure the needle thread is the last to be threaded. If this thread is still under the loopers when you rethread, the threads will break .Sewit
Posted on Apr 25, 2009
  • 9 Answers
SOURCE: Bernina overlocker 203 locking thread is not sewing on fabric
You need to adjust the tension for your threads. Use scraps to test sew as you adjust the individual threads to bring them into proper balance. Your manual will tell you how to do this.
Posted on Jun 12, 2009
RickE1
  • 202 Answers
SOURCE: Threading an Empisal Overlocker - Model S4D
All sergers thread the same way and sergers have to be threaded in a certain order. I made a jingle out of it...
upper looper
lower looper
right needle
left
It would be best to have a tweezers handy to help with the thread and threading.
always be sure the lower looper thread goes over the top of the upper looper then out the back. I would be surprised if your thread guides are not color coded.
If you look at the top thread guides or the spools. First from left to right thread the 3rd spool, then the fourth spool. Then you thread the right needle (the second spool) then the left needle (1st spool.
The lower looper can be tricky because you have to thread it from the back of the looper to the front.
Pull the threads out the back from under the foot. Then go ahead and run it slow watching to see if it starts making a chain. It should. If not do it over again.
Good luck
Rick Engel
Posted on Aug 03, 2009
SOURCE: Brother LOCK-523N overlocker threading
Looking for the manual for the brother lock-523
Posted on May 28, 2010
Help plse, after threading it dont make the overlocking stitches. New machine, help with right way to thread machine and the smaller detail of threading.
Your machine is either not threaded correctly, or the individual threads have not been threaded in order. Be sure to ALWAYS RAISE the presser foot when threading the machine. You must follow the instructions exactly or the machine will most likely never work properly. Can you at least get a training class on your machine? A class is indispensable, especially when it comes to using a serger.
Even if it is not the same model, these instructions may be helpful.
Tutorial for threading overlocker
Make It Handmade Threading Your Serger or Overlocker
Need manual for an empisal 754D overlocker can get the tension right and...
Dec 14, 2016 | Sewing Machines
I need help in good tension for rolled hem in empisal 606D overlocker
Your owner's manual should have instructions for rolled hem settings. My Bernina manual has a the following settings:
Medium weight fabric
80/12 Universal needle
3 cones serger thread
Upper looper 3-5
Lower looper 7-9
Left needle (no thread)
Right needle 3-5
Stitch length 1-1.5
Cutting width 2-3
Differential feed N
Can use woolly thread in the upper looper, but the tension may need to be loosened since the woolly nylon thread will stretch.
Dec 19, 2015 | Sewing Machines
Bernina 335 serger won't sew/overlock. carefully rethreaded the serger but that hasn't helped.
The 335 has a two thread chain stitch (stitch type 401), and the overlock side (right needle side), is a three thread plain overlock. If you are describing the plain overlock as the problem, I would first suggest the following in re-threading:
1. Thread the upper looper
2. Thread the lower looper
3. Thread the needle last (important)
If the needle threaded, you cannot re-thread the lower looper without breaking the thread.
In order to thread the lower looper, the lower looper must pass by the needle thus picking up the needle thread. So, instead of threading the lower looper thread underneath the needle thread, the looper would be threaded on top and cannot sew without breaking the thread.
Make sure that the threads are bedded between the tension disks. Check this by stretching the thread fore and aft of the tension disks as well as visually noting that the threads are not accidentally threaded behind the disks. You can also loosen the tension disks when threading so as to allow the threads to bed deeply between the disks.
Please reply with your observations.
Sep 27, 2015 | Bernina Sewing Machines
How do I sell problems
tension on an Elna L4 overlocker (or serger in USA) is controlled with the four dials on the front of the machine, an overlocker has a tension dial for each thread (usually 3, 4 or 5) and the mid range setting will be 5 on each dial. It is critical to lift the thread pole to its maximum height and follow the threading diagram correctly taking the thread from the cone, through the thread eyelets on the pole, then usually a thread carrier on top of the machine, down and around the tension dial, then usually through another couple of thread carriers until reaching the needle or loopers. Many overlockers will have a threading diagram inside the front looper cover and will use colour coding on the components so you can see where each thread goes.
Jun 02, 2014 | Elna Sewing Machines
How to thread a goldex industral 5 thread serger
check for a manual on these sites--you may have to email some of them
industrial
sewingmachineman.com
miamisewing.com
sewingonline.co.uk
sewusa.com
sewvacdoctor.com
a1sewingmachines.com
May 22, 2012 | Sewing Machines
Threading a 5 thread goldex serger
check with these sites about thread information
sewusa.com
sewvacdoctor.com
Mar 30, 2012 | Sewing Machines
Sould i use overlock thead on my brother embroidery/sewing maching
It is, of course, possible to use overlock thread in a typical machine. Generally speaking, you only want to use overlock thread to overlock ("serge"). The reason for this if that while typical all-purpose or sewing machine thread has 3 strings wound together, overlock thread has only 2. When you are using 3, 4, or even 8 threads at a time with a serger, each strand doesn't necessarily have to be as strong as when you are sewing on a machine with only 2 threads. So, you physically could use the thread, yes, but it will not be near as strong, and you will probably have issues with breakage while sewing as well. The cost savings you think you may be saving by using overlock thread (which is, after all, considerably cheaper per yard), well soon be overrun with extra time sewing due to broken threads and overall less quality in your garment as it will be made weaker.
Jun 19, 2011 | Brother Lay-In Thread Serger Mechanical...
I have a husky lock 234D serger and no manual. how do i use 3 thread overlock? which threads do i use?
To use a 3 thread overlock, thread the overlooper; the underlooper and then use ONE of the needles. Removing the RIGHT needle will produce a 5mm or 1/4" seam. Removing the LEFT needle will produce a 3mm or 3/16" seam.
Dec 17, 2009 | Husqvarna Sewing Machines
Thread wont overlock
When the thread breaks too often, try these, that goes for all sewing machines
1. Replace the needles,
2. Loosen slightly the tension of the needle threads.
3. The top threads are to thin,
4.The sewing (rotary) hook or looper, has burs,
5. Wrong threading
May 21, 2008 | Husqvarna Viking 1
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
