Question about Microsoft LifeCam NX-6000 Webcam
I am facing a critical problem. I am using WinXp and couple of days back I installed My NX6000 cam in laptop (Pariso V3000 model) which was working absolutely fine. Then after that I installed Logitech Cam in my laptop without uninstall my NX 6000 software and Logitech was also working fine. Then I uninstall Logitech and try to run NX6000 it was not working. Then I uninstall NX6000 driver completely and Installed as a fresh .. but still it unable to detect the Cam,when I try to click the cam application ,it showing error : "Problem occur during hardware installation, plz chech audio video setting". I checked the setting option from cam window / interface and audio ( speaker / mike) is working properly. The main problem is System unable to detect the hardware. I also tried to clean registry and uninstall NX6000 driver and again reinstall it... but every time it gives teh same error "Problem occur during hardware installation ". i WILL be thankful if someone can suggest....any workarround,,
  • sghosh Jan 17, 2009
    Dear yooperbud
    Thanks for ur answer, but unfortunately this solution not worked.
    i did everything as you mentioned.
    The main problem is that soem registry file was altered. Now u will ask me how i know that, when I unable to install my cam then i did a simple trick, just restore my windows setting couple of back date and my cam starts working with the old setting.
    So I confirmed that somethg altered in registry setting.
    But the problem is that with my old windows restore setting CAM is working but WI FY wireless not working, so again I restore my windows setting to current date and now Wi fy is working but cam again not working ... as before.
    I thought let me apply a another trick for this, I installed MACAFE and there is a utility in MaCafe for cleaning of REGISTRY, i clean the registry via MaCafe and again try to install Cam, but unfortunately this not worked.
    So currently now I unble to install my Cam. And frankly speaking I dont have much knowledge in Windows Registry, so I did not do any further Research on it.
    The main problem in detection of Hardware, after installation my system unable to detect my CAM, its not a problem with Skype / Yahoo. even when i try to run my cam program.. it unable to detect my cam and no picture. I search in Device manager and found CAM is marked as YELLOW colour, i.e unable to detect.
    I hope you now coem to know full story...
    Any further suggestion regarding this will be highly appreciable.
    Thanks a lot in advance.
  • 8,637 Answers
Normal 0 Did you install the software with the camera connected to the computer? Disconnect the camera from the USB port and reinstall the software. When the program asks you to connect the camera, do so, and it should work. Hope this is of some help. Bud
Below is info for setting up Audio & Video to chat on line after you install , either Skype or a messenger program.
Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
C. Windows Live Messenger:
  1. After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
  2. Then on the Windows Live messenger window on the right side, click on “ “Show Menus.” And then click on “Show the Menu Bar”.
  3. Next go to the Menu Bar on right side, click on “ “Action.”
  4. Go to “TOOLS” and click “Audio and Video Setting” and follow the instructions.
NOTE: You audio and video shoud work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Posted on Jan 15, 2009
Facing Problem with compac v3000 no display
First see if any monitor will work, plugged in at back? If works, check, just isn't been LCD monitor has been disabled by a key command, then if NOT work, it is probably Video card. OR actual LCD, OR the LCD power supply and/or Inverter? may also be bad connection to MB? Or Broken ribbon in lid, or case. Faulty sleep open/close LCD switch? Try those.
Mar 02, 2010 | Compaq Presario 2580US Notebook
Not able to install Conexant High Definition Audio driver
go to download your Conexant driver and fax modem driver for your model onto a flashdrive and install it on your laptop that way..another thing check your updates. microsoft has an audio conexant driver in the custom downloads...
Sep 01, 2009 | HP Compaq Presario v3000z Notebook
Network adapter not working
your network adapter driver is not installed. Install it and then have a look . open device manager and in that look for network adapters if u can see there then ur driver is installed successfully..
Aug 26, 2009 | Compaq Network adapter
If your v3000 only shows leds but no video you need to replace your GPU(graphics processor) Hp has an active recall for this problem for certains models, you can check if your v3000 qualyfing for this recall in
The manner that we resolve this issue:
you need to remove your MoBo completely from your laptop, remove your heatsink and coller from your Cpu/Gpu, with a heat gun(similar to hair dryer) reheat your gpu, this will cause that your gpu re-soldering and will function very well.
If you think this is so hard to you you can send your laptop to: VCRTECH
10001 buckwood Av. 79925 El Paso Tx
We repair your laptop in 2-3 business days and we charge $80 usd for this repair.
Please give me your feedback
Apr 21, 2009 | HP Compaq Presario V3000T Notebook
Compaq presario v3000 (v3322tu) turns on but appears dead
According to your question ,there is a problem with RAM of laptop ,bring it out again install it properly.
if it not work you to replace it with new one.
Apr 06, 2009 | HP Pavilion dv6000z Notebook
Error Msg: Problem occure during Hardware installation
Having Nero installed can cause this problem. This is from the Microsoft Knowledge base. There are some other programs that can cause this problem. Search "Lifecam Program" I believe I have tracked the problem down to this. I have not uninstalled Nero yet, But Nero crashes when trying to launch it video utilities. So at this point I am presuming that tere is a conflict.
Jan 11, 2009 | Microsoft LifeCam NX-6000 Webcam
I need lan driver for v3000 laptop
There are several versions of a Presario V3000, nevertheless, pls try here and select your model.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 11, 2008 | Computers & Internet
Cant load xp on compaqv3000
Hi Syed rambo,
you need to go in bios then look for boot up system then disable your hard drive to none and all other one to none just keep your cd drive as able then save then exit bios reboot system with your vista should stat to boot up then when it load up the system will reboot again before it starts up loading winxp get back into bios agian then able your hard drive and all to able them exit save and reboot that should load up your winxp.
Jan 15, 2008 | Computers & Internet
Microsoft LifeCam NX-6000 Webcam Logo
151 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
