Question about D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point
The power led will not on
When i connect to adapter the power led will not turn on and device doesnt work
    Sergeant:
  • 366 Answers
Check if adapter is working
try using another AC adapter with same specs
Posted on Jan 11, 2009
  • Pat Batta
    Pat Batta Jan 13, 2009
    meaning? inappropriate to what?
    Could you explain the appropriate solution you get?
My laptop is not powering on help
1.Connect the Ac adapter to a known good power outlet. Check the Power LED indicator on AC adapter (without plugging into the Notebook). We are only checking the power AC adapter to see if that is working.
2.If LED on the AC adapter is not lit (when unplugged from notebook), reseat the AC adapter brick and cable. If still there is no light on AC Adapter replace AC adapter and Power cord.
3.If LED on the AC Adapter goes off only after connecting to Notebook, the issue is with the motherboard. Replace Motherboard, DC-In port (AC adapter connector).
4.If the AC Adapter LED is always ON, take a technician's help and reseat the Power Button Board. You can refer to the Service Manual for details on how to reseat the Power Button Board. (NOTE: Before the notebook chassis is opened ensure all the power connections including battery and external devices are disconnected)
Jun 07, 2014 | Dell Inspiron Laptop 1440
My dell studio1555 laptop is not recognising my mains lead/charger
Plug the adapter into the wall outlet or power strip. If using a power strip, make sure the strip is on. Most laptop power adapters have a small LED light; the light will illuminate when power is being transferred from the outlet to the adapter. If the light illuminates, chances are you have sufficient power to supply your laptop. Wiggle the power cord if the LED light did not initially illuminate. If the light turns on and off when you wiggle it, you might have a loose cord in the adapter, or the outlet could be faulty. Plug the adapter into another power outlet, preferably a different circuit in another room, if the LED light did not illuminate the first time. If it lights up from the second outlet, the first outlet either does not work or other devices were using too much power on the initial circuit. Connect the other end of the adapter to the laptop and turn the laptop on. When the computer starts up, you should see an indication of how the laptop is being powered in the lower right-hand corner. If you see a battery icon, then the laptop is being powered by the battery, not the adapter. Make sure both ends of the adapter are securely connected. If they are, and if the LED light on the adapter is lit, then you likely have a faulty wire that is not properly connecting to your computer. If you see a plug or adapter icon, then the laptop is successfully being powered by the adapter. If the LED light on the adapter is not lit, then the bulb is out, but the adapter is still working.
Jan 20, 2013 | Dell Computers & Internet
My toshiba is charging but onlythe cord out lets bliking what does that mean
Jan 20, 2013 | Toshiba Satellite Pro L300 Notebook
My gateway nv79c54u laptop ac plug doesnt charge just blinks orange
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Sep 12, 2012 | Acer Gateway NV79C54u 17.3-Inch Laptop...
Laptop hp compaq tc 4400 is not charging , during adapter connected to laptop and turning power/standby led ... it doesnt switches on, instead battery charging led blinks 4 times, and doesnt turns on, so...
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Apr 16, 2011 | Compaq tc4400 Tablet PC
My screen is backwork and the arow doesnt work
DO THIS FIRST - Perform a hard reset If a PC suddenly fails to boot properly, you should perform a hard reset as the first procedure.
  1. Disconnect all peripheral devices and remove all USB devices and media cards. You want to test the computer not the accessories!
  2. Disconnect the AC power adapter, remove the battery, and then press and hold the power button for at least 15 seconds .
  3. Reconnect the AC power adapter (but do not connect the battery), Press the Power button, Look for glowing LEDs near caps lock and num lock keys, and Listen for sounds of a disk drive and fan turning.
Actions to take after performing hard reset If no error message is displayed:
Dec 05, 2010 | HP Pavilion dv6000z Notebook
Screen will not work
  1. Connect the AC adapter into a known working AC outlet and to the DC jack on the notebook. NOTES:
    • Verify the correct Sony AC adapter is being used, and not a third-party replacement AC adapter. To determine the model number of the AC adapter for your computer, refer to the specifications available online through the Manuals/Specs/Warranty link on this page.
    • Do not connect the AC adapter to a surge protector or extension cord.
    • If the DC jack on the computer is loose or damaged, the computer may require service.
    • Some AC adapters have a POWER LED indicator and can be confirmed as receiving power by ensuring the LED is lit. If the AC adapter is damaged, or the LED is not lit or continuously flickers when plugged into a working AC outlet, the adapter must be replaced. A replacement AC adapter can be obtained from the Sony® Parts and Accessories Sales Web site at http://www.sony.com/pas or by calling (239) 768-7691.
  2. Attempt to turn on the computer normally.
  3. Press and hold the Power Switch for 5 seconds.
  4. Remove the battery.
  5. Disconnect the AC power adapter.
  6. Press and hold the Power Switch for 5 seconds.
  7. Connect the AC power adapter.
  8. Attempt to turn on the computer. NOTE: If the computer turns on without the battery, connect and charge the battery for 24 hours.
  9. Disconnect all external devices that are connected to the computer. NOTES:
    • These devices include, but are not limited to, a modem, floppy disk drive, network connection, USB device, printer, keyboard, or mouse.
    • On older model computers, the maximum current output from the USB is 500ma. If a connected USB device draws more current than this amount, the unit may not power on.
  10. Attempt to turn on the computer.
  11. Remove any additional Random Access Memory (RAM) that was installed in the computer.
  12. Attempt to turn on the computer. NOTES:
    • The troubleshooting steps listed above should resolve your issue. If you have completed all of the steps and the issue is not resolved, service may be required.
    • When shipping the computer for repair, include all notes of the LED status that display during troubleshooting.
[[DAPC Direct Accessories and Parts Center]] If all the above troubleshooting steps fails, then you will have to ship the Computer to San Diego Service Center.
Jul 04, 2010 | Sony VAIO VGN-CR220E/P Notebook
My Laptop doesnt start at all . I dont know what
1. remove all ext peripherals
2. remove battery
3. check first the ac adapter if it has led on (make sure ac adapter is not connected to the laptop)
4. try any other wall socket check if ac adapter will led stay on
5. if ac adapter stayed on then connect to laptop (without the batter)
6. after connecting the ac adapter to laptop check if the ac adapter led turned off, if yes then check ac adapter laptop pin on the side if is loose or damage.
7. if ac adapter stayed on after connecting to laptop press now the power button on the laptop just once. check if the power led on laptop will turn on (check if power led stays on or it blinks amber)
8. if it blinks amber then remove all CRUs such as dvd drive, memory, hard drive and wireless cards. put them back one at a time. make sure you turn off laptop when putting removed hardware. this will check and isolate which causing the power led to blink.
9. if the power led stays on then turn it off again then wait a couple of seconds then press and hold on Fn key then press power button. wait for about 5 minutes while the power led is steady on, until you hear beeps once you hear beeps it means that LCD has problems. try then connecting laptop to an external monitor if it shows display there. press on Fn + F8 to toggle the display from LCD laptop to the ext monitor. if no display replace the motherboard. if it has display replace LCD.
Oct 15, 2009 | Dell Inspiron 6000 Notebook
My screen doesnt work.
I suggest you to perform these steps.
Test the AC adapter Follow the steps below to determine whether the problem is related to the AC adapter or your notebook system board.
  1. Remove the battery and disconnect all external devices from the computer.
  2. Hold the Power button for several seconds, with all power sources removed. This drains residual power from the system, and may correct many problems.
  3. Connect the AC adapter to a wall outlet and plug the other end into the computer.
  4. Press the Power button to start the notebook PC.
If the notebook does not start or the display is blank then check the power indicator light or power socket LED. I suggest you to connect the notebook to external monitor and check whether its working or not. Then please perform the harddrive self test also.
Jan 09, 2009 | Dell Inspiron 1521 Notebook
Wmp300n auto-off
Is there the possibility that you could buy a more powerful device?
Feb 13, 2008 | Linksys WMP300N Pre-802.11n Wireless...
D-Link AirPlus Xtreme G DWL-2100AP 802.11g/b Wireless Access Point Logo
176 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
