Question about Garmin Nuvi 1300 4.4 in. Car GPS Receiver
Nuvi 1300 torx
What size torx screw holds screen in place
2 Suggested Answers
  • 29 Answers
SOURCE: what is the torx size to remove the screws in the
The torx screws are only the first part of a delicate procedure. Once the screws are removed it still requires special tools etc to open the unit without damaging it. Once it is open there are very small and extremely fragile connectors that are easily destroyed if you try to disconnect them the wrong way. If there is a problem with your unit I highly recommend not trying to fix it yourself, it is well worth the $ to have it done by an expert. There are several post-warranty repair companies out there but the only one I recommend is www.sharcnet-usa.com.
Posted on Jan 10, 2010
Troy-bilt pull rope torx screw: Is there a trick to remove the torx screw in the center of the starter spring housing?
There is no trick, you would just use a torx screw driver. If your spring isn't broken don't do this. If your rope is broken you can fix easily. Replace old rope with new rope of equal size, place rope into spring wheel and turn counter clock wise holding the spring wheel. place other end of rope thru hole in shroud, remember to hold tight you have a lot of tension there. Pull rope thru enough to tie a knot, replace your pull handle , untie the knot and you should be fine. GOOD LUCK.
Aug 12, 2011 | Troy Garden
Tip
Garmin Nuvi 1300 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1300 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1300 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Webupdate
on May 13, 2010 | GPS
Tip
Garmin Nuvi 1300 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
I hope that helps.
on May 13, 2010 | Garmin nuvi 1300 Car GPS Receiver
1300 nuvi screen comes up loading maps and stops
A Garmin Nuvi 1300 that freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
May 19, 2010 | Garmin nuvi 1300 Car GPS Receiver
How to remove rechargeable battery for norelco 7864
hi minglim, welocme to the forum!
    Replacing a Norelco Shaver Battery Things You'll Need:Torx screwdriver set Rechargeable Ni-Cd AA battery 1)Slide up the sideburns trimmer on the shaver .2)Try the various torx head screwdriver sizes to find the fit for the two screws holding the top of the back shaver cover on. Unscrew the two screws that are under the sideburns trimmer that hold the back of the shaver on. On some Norelco shavers, the back will now slide off if you apply downward pressure on the shaver's back. Other Norelco shavers have one or two torx screws on the base of the back cover on the shaver; if so, unscrew them also. Place the screws in a safe place. 3)Take the back cover off the shaver. Some shavers may have a strap fastening the battery down. Unfasten the strap if there is one. Take out the battery. 4)Replace the old battery with a new rechargeable Ni-Cd AA battery. Re-fasten the battery holding strap if there was one. 5)Replace the back shaver cover and re-screw in all the torx screws,
May 20, 2010 | Norelco 7800XLCC Electric Shaver
Garmin just shows its loading maps and then screen goes blank and it repeats this even when I hold down the button for 10 seconds to reboot Why is it not turning on?
A Garmin Nuvi 1300 freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
May 20, 2010 | Garmin nuvi 1300 Car GPS Receiver
My Garmin gets stuck on the garmin screen saying loading maps. I have tried to the reboot option of holding down the right corner power on and then click yes to erase maps however when i click yes nothing...
I hope that helps.
May 15, 2010 | Garmin nuvi 1300 Car GPS Receiver
What is the torx size to remove the screws in the
Jan 09, 2010 | Garmin n vi 360 GPS Receiver
I have a garmin nuvi 1300 and then i turn it on
it should show "loading maps" try reset by holding down finger on bottom right hand corner of screen before you power up, and go to www.garmin.com for software update, if not contact supplier for fix/replacement
Nov 03, 2009 | Garmin nuvi 1300 Car GPS Receiver
Battery replace
Flip the unit over so it is resting on th screen with the on switch at the top you will see the reset and S/N tag. Pull this plastic tag off with twezzers or a knife. This will expose 2 torx screws size T-5. After removing the torx screws, right under the S/N plate sticker is a mount hole, locate this then pry apart with screw driver, be careful prying apart as there is a flex cable taped down to your pcb board. Remove the flex cable by opening the latch for it, there are 2 latches one small and one large and the cables are taped to the pcb board. Remove the speaker jack wire with tweezers.Next with a small jewlers screwdriver remove 3 phillips screws size ph00 from pcb board. Lift the pcb board out and disconnect the battery wire underneath. Next remove battery, it is stuck down with double sided tape and takes quite a bit of force to remove. It is a Garmin LI-ion 3.7v, 1.25 AH battery.
Aug 28, 2008 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 1300 4.4 in. Car GPS Receiver Logo
35 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
