Question about NetGear DG824M Wireless ADSL Modem Gateway Router
Wireless connection for laptop and pc through netgear DG824M
How do I connect my laptop through my computer with netgear dg824m
  • Harshit Kumar
    Harshit Kumar May 11, 2010
    first of all tell me that which windows operating system ur using on ur computer and have u successfully configured the router?
  • 854 Answers
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Aug 16, 2009
Dell inspiron m5030 netgear router
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Jan 23, 2013 | Dell Inspiron Computers & Internet
Unblock the netgear firewall
You will need to get into the router first Start Menu > Control Panel > Network Connections > Right Click on the active connection > select Status > Support tab > and you will see the Default Gateway address.
take the gateway address into the browser navigation bar then enter your user name and pass word after you have logged in look for the security tab when it opens you will see the firewall with two dots next to it click on disable go to the bottom of the page and save settings now you can exit out of the router and it is done
Sep 01, 2011 | NetGear DG824M Modem
Cant connect to the internet and the internet light is red not green. we unplugged the router before the problem happened
It can be an outage but there prob is a issue at the nod or something local... check at your local office, as it might be upgrades or just a simple problem.
Jan 02, 2010 | NetGear DG824M Modem
Netgear DG824m Disconnecting every few mintes
There are a few things that can cause you to lose wireless connection with your wireless router.
1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from walls and if possible locate the wireless router higher up.
2. Have you secured your wireless router from people near your from unauthorized access? ie. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router.
3. You could be getting interference from electrical sources such as air conditioners, arid welders, washing machines etc. If so the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply)
4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Nov 17, 2009 | NetGear DG824M Wireless ADSL Modem Gateway...
I have a netgear wireless adsl modem gateway dg824m which i am using to crate a wireless sinal that i can recieve in different rooms. I am running this direct from an ethernet socket in the wall, one...
Is this a four port device? Please tell me what cables you have in the back of the router. There should be at least ....
1 x ADSL
1 x PSU (External power)
If you are connecting via wireless you do not need ethernet cables. If you want to use wired ethernet you would only need one CAT5 (or similar spec) between one of the spare ports on the router connected to the eth0 port on your PC/Laptop.
Fire up a DOS window on the PC and type "ipconfig -a". This should report that the PC has a valid IP address from the router in the format 192.168.0.x. If so you should be able to ping the router.
ping 192.168.0.1
If *this* works then you should be able to put the IP address into a browser and get the admin screen up.
Cheers,
Ripface.
Sep 27, 2009 | NetGear DG824M Wireless ADSL Modem Gateway...
My netgear will not let me connect to the internet via my wireless connection my main computer has internet as it is connecter via the yellow cable to the netgear my other computers have a netgear adapter...
Open Zonealarm, choose Firewall, Zones.
Add >> IP Range set your IP range eg 192.168.0.1 to 192.168.0.254
This should allow connection between Router and Wireless Laptop/Desktop.
If your wireless PC cannot see the router, check your router setting to see if you are transmitting a SSID
May 18, 2009 | NetGear DG834G Router
Modem is not working
the fact that the computer and modem are not in contact with each other, means that we really don't know that the modem is not connected to the internet. i'll assume you've tried all lan ports on the modem.
did you attempt a connection with another computer? another modem?
Mar 31, 2009 | NetGear DG824M Wireless ADSL Modem Gateway...
No connectivity to 2nd desktop or laptop - although worked before
Hello....sudden loss of wireless on two computers, in the same home, may indicate that a powerful source of wireless interference has just arrived (since your wireless router light is still on).
1) Does the signal improve if you move the router, or move the laptop closer to the router?
2) Have you had any success with changing the channel on your router? (Login to router > select Wireless Settings > Channel)
If you have not moved furniture yourself, or installed a device which could interfere with the signal (eg a DECT phone), it's possible a neighbour's new router may be the culprit.
Please come back to Fixya if this does not help.
Jan 11, 2009 | NetGear WGR614 Router
NetGear DG824M Wireless ADSL Modem Gateway Router Logo
88 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
