Question about Vacuums
Brushes stopped spinning
Steam vac brushes on hoover Dual V carpet cleaner F7410-900 stopped spinning. Can't find the screw location to take the bottom to check if its a belt or something else. Already replaced a leaking tank, that works fine. What would be the main reason the brushes stopped spinning and how to fix it since we just invested $60.00(+) dollars for the tank.
  • Vacuums Master
  • 18,392 Answers
Go here for manual > http://hoover.com/file/593/
Posted on Dec 02, 2012
reddevil6
  • 1673 Answers
SOURCE: Problems with the Hoover Steam vac Heated carpet cleaner
This happens when the filter on the inside of the lid for the dirty water tank is pushed all of the way up. You need to leave a 1/4 in. gap from the top to the top of the filter.
Posted on Jan 10, 2008
  • 12 Answers
You'll have to go into the turbine assembly and check the bearings. Mine stopped spinning and this solved that problem. I simply began working the seized bearing until it rolled again, packed it in grease and reassembled.
Posted on Feb 09, 2008
SOURCE: hoover F7431-900 steam vac brushes wont work
the brushes are activated by suction, my berings and gears froze up, i took it apart, kinda hard to figure out, but not as bad as it looks. i lubed the berings and the gears, then i took an air compressor to the activation fins and let it spin, lubed again then hit it with air again, now works better then new.....GL
Posted on Jul 29, 2008
  • 3 Answers
SOURCE: Spin brushes on Steam Vac
The cover is only secured by 3 screws. One on the top, and two other on the underside. The two on the underside are located on the black plastic and are deeply recessed. After removing these 3 screws, on the top there are 2 snap in post. Simply squeeze these posts inward, towards the center and the cover should lift off.
Posted on Aug 28, 2008
  • 157 Answers
SOURCE: hoover steam vac legacy
Hello tmc68cam. I will need the Mgfr., model & serial# to research for the part or parts you may need.
Posted on Oct 06, 2008
My brushes wo't spin on my spin vac dual v carpet cleaner
Solution: Remove the clear plastic cover located in front of the brush control switch (I used a butter knife). Locate the small screen and remove the dirt and hair from it with your fingernail or an old tooth brush. Restore the cover and you should be good to go.
Nov 22, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
MY HOOVER DUAL V STEAM VAC CARPET CLEANER BRUSHES WILL NOT SPIN! WHY?
There are three things to check:
Is the switch on the hood for brush speed set to full, or may it be set to OFF?
Remove the brush block from under the unit by pulling it down and unlatch each side. Is there a 1/4 inch square drive pin on one brush, about two inches long? It connects the brush to the drive mechanism.
Lastly, the drive mechanism in the base may be bound-up, and not spinning. If so, the unit needs disassembled to repair or replaced.
Oct 28, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
I own a hoover steam vac model f5915-900 and i currently have two problems. 1. the brushes are spinning at a much slower speed. 2. the steam vac is not picking up the water it leaves on the carpet....
the reason the brushes are not spinning is because the belt is slipping, the belt is the bad that connects to the brush to a shaft that makes it spin. Next problam is it is probobly clogged. so water is not going through all the way
Sep 08, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Brushes won't spin on hoover steam vac
Hello tmc68cam. Most vacuums have a belt driving the rollers/brushes. Unplug unit and remove the housing screws to view internaly. If a broken belt note your model# and search for a local applance repair shop for a replacement. IF not I will need Mgfr.,model & serial# to research to futher assist in the repair. Good Luck.
Oct 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac Spin Scrub
Remove the brush block, is the shaft on it or broken off. Replace the block if broken off. Turn unit over, with brush block removed, handle tilted back, is the square hole turning, if not then the turbine is bad, this is what turns the brushes.
Sep 01, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover terrain steam cleaner, brushes wont spin
The primary problem is that the turbine is seized. One way to verify this is to try to manually move the brushes by hand (with it off, unplugged). If not then your problem is with the turbine. This usually requires professional service. I would recommend to take it to a trusted vac shop which is familiar with these cleaners. or go to the hoover web site to locate a hoover dealer near you.
Jul 15, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vac Spin Scrub Carpet Cleaner won't suck
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=728884
Hoover Steam Vac Spin Scrub Carpet Cleaner won't...
Posted by hoofbeats1 on Jul 01, 2008
My machine is a little more than a year old. I have used it about 5 times. It started leaking the third time I used it. The fourth time I took it out, the brushes would not spin (I did clean them and rinse them after use each time).
Now the engine screams and won't **** anything up. Do you have any suggestions? My last Hoover Steam Vac was great and lasted for 3 years! Hi,
I have a Hoover Dual V SteamVac F7425-900 that the brushes won't spin. The lint screen is clean & the brushes switch is in the on position.
It dispenses & sucks up the cleaning solution & water; just no brush action. Help
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The only thing that I can recommend is that you may have a bad switch, some vacs may have a broken belt or the drive mechanism inside the Hoover Dual V SteamVac F7425-900 in or by the brush assm section and is need of repair. Please check the trouble shooting section of the owner’s manual if you’re needing help and to save money. If you don’t have one then contact the Hoover factory cust serv. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
The first thing to check is the filter on the inside of the lid to the recovery tank, if it is all of the way up to the top, it can cause variouys problems, it should have a 1/4 in gap from the top. The other thing is the turbine, that is what drives the brushes. If the brush block is ok, then most likely the turbine is bad and will ahve to be replaced. Part # for the turbine is 43191006 and sells for about $60.
Nov 18, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Nov 18, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
229 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
